Team Magic E4 Thread
#931
Super Moderator
Ok....between E4FS and E4RS, the different are the follows...
(1) Rear ARM are different on FS, front both use the same arm
(2) Ball diffs F/R on FS, Ball diff R on RS and Spool on F
(3) 3 degree on RS and 6 degree C-hub on FS
(4) Single steering pod on FS and Dual on RS
(5) Upper and lower chassis different between the 2. Thicker on FS
(6) Mid pulleys are diff....same on side pulleys
(7) No bumper steer spacer on FS, 5mm on RS
(8) Steel front alum rear CDV on RS, both alum F/R CVD on foam
Can someone point out what else are different...? Other internal or chassis different between the 2?
Apparently, WOLF is probably the only place in the planet earth has FS parts and kits, not even Team Magic Base in Taiwan has 1 single parts and kits. And by adding the above parts together....buying a kit is a lot CHEAPER then upgrading/stocking the FS parts............is that correct?
Thanks everyone....
Thanks everyone....
The FS internal ratio is 1.8 i think and the RS is 2.059
#933
What store in europe or overseas I can find pieces to E4RS (E4RS top deck and RS motor mount)?
THANK
OLIVIER
#934
http://demonpowerproducts.co.uk/index.php?cPath=94_117
Not sure if they have what you are looking for but he carries most things.
#935
no parts for e4rs in stock
#936
In Rcshopping or Wolfhobbies, is possible, but is you like i talk with Spanish distributor tomorrow, because the friday he said me, the next week arrived more parts. Maybe it is better to buy a whole car, because you have all parts, new parts and spares.
In other hand, yesterday and today, i make more hours of testing, some work and others no, for me.
In first, the rear hubs (kfactory 1.5º), are a option to have, the car is more planted with 3º rear.
Now the anti-squat rear, work best, the car is more easy when brake, and have very good aceleration.
In front, the same, the car is good enter to the turns, have more steering, but with the rear most caught.
Definitely, for me, work best the HB stabilizers, front and rear, i feel the car more roll, is more round into the turn.
I use, HB springs, too, but this is more personal, the Lbs are the important thing.
There is one thing, which was not explained, in the front rear pivot block, the ball conector support seems to work slighty better, pointing up rather than put a 1 mm washer below ¿...? .
Finally, i test the Marcos, 2º setup, and the word is "smooth" , but for me, the lap times are slowest, is possible my skills are not than good, i haved to change some things.
In front, i put a 1.4 stabilizer, and 1mm F - 1.5mm R, below pivot blocks.
In rear, ball conectors up and 0.5 below, and 1mm rear.
With this changes, for me, are 0.3 - 0.5s, faster lap, but i use Sorex 36, because is the control tyre, for races here, and i need to adjust the car to this tyre.
Well, with this setup i put the rear hubs 1.5º + 1.5º in pivot block, (3º in total), and put 2 mm below upper link, front and rear, and the car are more fast, the grip in the track are slighty best, too.
Is normal, one setup is not possible to work perfect all people, the driver, the track, the grip, ...are more factors, but this setup work good, and helped me, thank you very much.
I hope, help to others TM drivers.
Here a photos, with 5300 Nosram Lipo, and HB stabilizers fit front and rear.
Greetings Luis C.
Greetings Luis C.
#937
MP luis
you have a spool jasmin product? its nice
you have a front Turnbuckles AE?
#939
Mp reply, thanks Marcos. The turnbuckles are HPI titanium, i have from Cyclone car, is not special, is because i have a tool for this turnbuckles, and is more easy to adjuts the camber.
Greetings, Luis C.
Greetings, Luis C.
#940
How do you adjust the lower roll centre settings? ie; kick up/anti dive - anti squat/ pro squat settings.
Also how is the rear toe angle changed?
Cheers
Aaron
Cheers
Aaron
#942
Hey guys just a quick question. I've been following this car for awhile now. I just have a couple of questions.
what the difference in all the different models. I think the RS is the top model for aphalt racing.
my next question does the Rs, comes with a spool or a one way or??
just curious know that you guy's been running the car for awhile. how does it stand up to breakage.
and If one should go to the car. what would be the import spares to carry on hand.
I was thinking on going lipo but don't want to butcher my 415 mre.
I race mainly stock and 19. 90% on Asphalt. on a small to medium track with sugar water layed down.
Thanks for any info.
#943
#944
My lightweight E4!!!
My ESC(MK03) is 20g more heavier than LRP TC.
My LRP TC ESC is die!!
#945
1330gr ouawwwwww
my e4 is 1450gr
my e4 is 1450gr
