Team Magic E4 Thread
#827
Just ordered me a 503002-C1 - 1/10 E4FS/C1 Rubber Tire Spec Electric Touring Car. It's the E4FS Rubber Conversion with (convertable) front 1 way option.
I plan on running it on a large outdoor asphalt track.
Also will have the following setup on the car:
- Mamba Max with 7700 BL motor (equivalent to 7T)
- Orion 4800 Lipo
- 110T spur 64 pitch
- Internal ratio is 2.0588
- Tires are Jaco greens (Rubberz)
My question is what size of pinion should I be using ?
Any suggestion on color springs to use ? I ordered the G4 spring set.
Also running with a Mazda 6 Blitz body.
Look forward to some help here
- Orion 4800 Lipo
#829
Congratulations, Gansei. I finish 4º in Final A, in the Nationals Cup of Champions, this weekend with a pretty similar components, E4 (with chassis and top deck from RS), Nosram 4.0, Nosram Istc, and Vtec 4600.
Only 2 TM E4, and the 2 cars in Final A, 4º and 7º, very good performance.
Greetings, Luis C.
Greetings, Luis C.
#830
#831
HI
luic you have a PM
luic you have a PM
#832
The motor mount plate, is the same, but is lightened. And the left support for center axle is the same.
Greetings, Luis C.
#833
#834
Super Moderator
- Orion 4800 Lipo
- Orion 4800 Lipo
about a 24t pinion (for a 9.43FDR) but i would get an assortment of spurs and pinions its alot easier to find the ratios that you need with the minimum space to move the motor.
I would start with about 19lbs in the front and 17 lbs rear depending on the grip.
I have a few set ups that work very well a few pages back
#837
OK guys here is the set-up I built for my E4 this weekend, its not perfect but its a whole lot better then what I started with. I set the track record this weekend and ran away from a JRXS. Anyway here it is.
