Team Magic E4 Thread
#3496
Perhaps not in lap times but how about maintenance?
The shorter the track is the less difference it makes.
I know on our track it makes a difference of 2 to 3 tenth per lap if you got clean and/or new perfect bearings.
We have a track with laptimes between 23 seconds for the slower drivers to low 21 to high 20 for the faster drivers.
This is in the stock 13.5 class.
regards Roy
regards Roy
#3498
My bearings are starting to sound like they have gone square. Has anybody purchased the ceramic set from ABEC35.com?
http://www.abec35.com/p3296/Team-Mag...duct_info.html
#3499
hi,
if I use 2.0 internal drive, what will be better? or what effect will it have?
#3500
#3502
#3503
Good bearings are everything..
h
#3506
Had a indoor race last weekend and managed to do laptimes that where only 2 a 3 km slower then the mod guys out there.
There wern't enough 13.5 stock racers so we ended up in the mod.
Managed to finish 5th overall and was the first stock driver out there
Running a lap time of 15.145 as fastest and that was a big improvement over last year on that track.
Funny thing is that i didn't use the best ESC and motor i had.
Used the old LRP SPX SS and a GM13.5 with a FDR of 4.588 so i had some speed out there.
Overall i am happy with the performance of the car last race.
regards Roy
regards Roy
#3507
Team magic E4 chassis have the best layout, balance overall, very easy to drive and it's not prone to tweeks but i do like to see a new chassis design with even cut outs and new top deck for low grip asphalt, new front and rear bulkheads were you can adjust the belt tension without using a belt tensioner.
What is lucking on the car is the rip of the two belt driven car however if you can free it up more it's achievable.
#3508
regards Roy
regards Roy
#3509
Yes you can only not on a form as for some reason it won't work for me
Here it is:Front
Trackwide front 186
Rollbar front:stock
Toe angle front +1
FF Hingle Pin Mount:1.5-2.5 ><
Mount shim: none
1mm shim on bulkhead underneeth turnbuckle front
Front axle: Spool
Camber front: 0
Ride height front: 5mm
Caster front: 3 degrees
Downstop: -1
Steering system: single K-Factory
Ackermann: outside position and on topdeck rear position
Shock position front:Lower arm outside position and on tower also
Tires front: LRP CPX no tire tracktion applied
Shocks front are Top Photon with TM 1.4 springs and 3 holes and 600CPS oil.
Rear:
Trackwide:190MM
Rollbar: None
Toe angle -3
RR Hingle Pin Mount: 1.5-2.5 <>
Mount shim: None
RF Hingh Pin Mount: ^^
Camber: -3
Ride hight: 5.5MM
Down stop: -3
Rear hub: K-Factory 1.5 degrees
3mm spacer under turnbuckle on bulkhead on the inner position
Turnbuckle position on rear hub: Inner position
Shocks Rear: Top Photon with TM 1.3mm spring 3 holes piston and 600CPS oil
Shock position on tower: Inner hole
Shock position on lower arm: outer position.
ESC: LRP SPX SS Mode 8,no drag brake and no auto brake
Motor: GM13.5 stock spec,no timing.
Tires Rear: LRP CPX tire traction on full tire
Robitronic 5000MAH 40c Lipo
Body Dodge Stratos.
Hope this is to any use for some one as i have often heard that am way off what normally is used.
regards Roy
Here it is:Front
Trackwide front 186
Rollbar front:stock
Toe angle front +1
Mount shim: none
Front axle: Spool
Camber front: 0
Downstop: -1
Rear:
Trackwide:190MM
Rollbar: None
Toe angle -3
Mount shim: None
Camber: -3
Ride hight: 5.5MM
Down stop: -3
Body Dodge Stratos.
regards Roy
