Team Magic E4 Thread
#3002
Tech Legend
Trader Rating: 51 (100%+)
I am selling my E4RS DE level 3 with 3mm chassis, original 2.5mm chassis, new Lipo top deck and spacers, and many spares and NIP parts.
Check it out at:
http://www.rctech.net/forum/r-c-item...level-3-a.html
Check it out at:
#3003
#3005
Tech Legend
#3006
The E4 at the Coliseum in Frederick, MD = fun! As traction came up I had more traction rolling but before that the car was very fast and very smooth. I got many compliments. I smoked a motor but it was fast before then . Duos surely do not work as I had to get a specific spur to make gearing work.
#3008
Isaac ,step away from the Tekin software please !!!!!!!!
#3009
#3014
Tech Legend
Isaac as long as the end of the motor is rounded like the old Novaks, LRPs and the newer Novak motor you shouldn't have any fitament problems. IF the motor end is like the Tekin or Trinity where it is perfectly squared corners then it will require you putting the motor in the way I sugested and then a good amount of dremel action on the belt tensioner.
It took me about 20 minutes or more to really dremel my side belt tensioner down but once done I gained alot of motor movement. I just never had time to really make a new side tensioner so I could remove the plastic one all together.
Isaac check with Wolf at Wolfs Hobbies as I thought he was in the process of making a new side tensioner back when I had mine. Maybe he has some newer ones that are cut to give more room.
