Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-03-2009, 06:45 PM   #2641
cheehtae's Avatar
Originally Posted by Solara View Post
Thanks for all the help....found out, it is the SIDE BELT. Even my belt tensioner on the side is WAY down already. Ended up using a bigger bearings so the side belt can be push down(tighten) a little more...
The side belt need to be a tad SHORTER...or I have to use the FOAM side pulley instead and get my final drive all screw up...LOL.
Beside the belt skipping....my E4RS is only OK (1st ever running on carpet after the full summer on outdoor). Using Boost 17.5 with the TEKIN PRO...car is SLOW...turn like a BOAT, very slow and retard on turning. So I am going to use 40 oils, Tamiya blue springs, .5mm sway front and rear and STOP the car rolling like a boat...that roll causes me at least 1~1.5 second per lap. I am using Tamiya Blue shocks with AE TC5 lower shock cap with regular lenght springs. I really like this setup on the E4, at least, on outdoor, it is gold.
Also...6.0 final drive, it is NUTS, anything higher (like 5.9 and smaller), car is SUPER SLOW...I really don't like these speedo software technology, totally screw up all the final drive setup from the old time...anyone run RCGT or Stock on E4RS on carpet? Or with TEKIN speedo with 200 software?
If you don't like the v200 version, try going back to the older version which is 198....
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 11-05-2009, 06:32 AM   #2642
Slideaway's Avatar
Hi there,
A E4RS'09 review has been post on a Thai RC website (text in both thai and english). This way !
Enjoy.
Slide
No matters the speed you get into a corner, only the speed you get out with does...
Slideaway is offline   Reply With Quote
Old 11-05-2009, 07:14 AM   #2643
Originally Posted by Wolf Hobbies View Post
We understand that people like to use a certain brand of spring (we used associated springs back when we were running Losis and Schumachers) but we do standardize on the TM springs for our published setup sheets. We have also found that the pink and purple springs (in different combinations) are great for just about any condition on asphalt or carpet. Our stanrd setup for new E4XX drivers is pink in the front and purple in the rear.
the pink spring has the no.TM502136? and the purple TM502138?
SebO is offline   Reply With Quote
Old 11-05-2009, 01:24 PM   #2644
The pink spring is P/N 502137 and the purple spring is P/N 502138. These are 11 and 16.4 lb respecively. Whenever I show up at a new track or am having trouble with a required spec tire I always use these as a "good foundation" It makes the car very stable and predictable. FYI: the stock silver springs are 10 lbs.
We have some new items on our web site. It is a set of burgundy (same as the limited edition cars) anodized bulkheads. P/N WH18110 is all the bulkheads. WH18111 is all the bulkheads plus the toe in blocks at both ends of the chassis. This is a great way to "tune up" a car if you have any bent bulkheads or if you have an E4JS or E4JR it is a great upgrade over the plastic bulkheads. Of course the real reason for this is that it makes the car look awesome!! The kits cost less than the price of 2 plain bulkheads. These are in stock and ready to ship but are limited supply.
Wolf Hobbies Your Source for Everything Team Magic Kfactory and H.A.R.D. in the USA www.wolfhobbies.com info@wolfhobbies.com
Wolf Hobbies is offline   Reply With Quote
Old 11-05-2009, 02:54 PM   #2645
TENCHO's Avatar
Default E4FS for sale
Hi all TM E4 fans! i have a NIB E4FS for sale...$250 shipped to anywhere in US. $300 shipped to overseas. I bought new from Wolf hobbies, but now i don't plan on running this car. it's never been ran, NEW in BOX!
anyone interested can e-mail me at jesus.sierra@rocketmail.com
TENCHO is offline   Reply With Quote
Old 11-05-2009, 03:01 PM   #2646
Solara's Avatar
Originally Posted by wyd View Post
If you go with the HPI side belt you won't need so much tension and it won't stretch as much as the stock TM ones. I forget the part number but its easy to find in thei thread. I think it is A748 but just search for HPI belt and you should find it. Great working side belt.
Using the K-Factory one (pulled from my Foam car)...it is alot better.
Schumacher USA, Speed Passion, Core RC, Top Speed RC, R-Hobbies and Gifts, BLEE Racing, RC Manufactory, Team Magic Model, G4RS, Team Al's - Al's Hobby Shop @ Elmhurst, Illinois 60126
Old 11-05-2009, 03:10 PM   #2647
Solara's Avatar
Originally Posted by Slideaway View Post
I guess there's no miracle to expect with a 17.5, whatever the speedo you use...
It is probably the radio, tekin speedo software setup combination that I really need to work on....I mounted my speed passion GT2 speedo with the same car and motor and everything it just went fine....just I won't have the TURBO thing. That Tekin Turbo thing is just insane but I have no idea what happened to the rest of the stuff...
Originally Posted by Pro10noob View Post
Hmmmzzzzzzzzz what am i doing wrong that i can't get my belts to skip??
At the moment i am running LRP SPX stock spec with GM 13.5 and lipo with a FDR of 5.05 indoor and no skipping is present from any belt.
Don't use the front belt tensioner and moved the front tensioner bearing to the side to get it more losen up and still no skipping.
Other car is with GM 10.5,GM 90 with 8 into 3 mode and 5 cell and a FDR of 4.54.
This car is ran outdoors and for the first time i ripped a front belt but that was due to small debree comming in the front spool poelie.
Runs very fast and also no skipping of belts???
@ Solara, try the TM springs and then purple front and the pinkish at the rear for indoor.
Lots of tracktion and no roll if you use the front swaybar.
I use Tamiya 400 oil in the shocks front and rear with standard pistons in the shocks,epa off steering at 65% and sorex 28 front and sorex 24 at the rear.
If you can use it prepair your tire with tracktion fluid on the rear complete and at the front just the inside part of the tire and i also use tire warmers when permitted.
You then have tracktion from the beginning till the end
cheers Roy
I ran the car full summer outdoor and the side belt was OK...but once it is back to indoor carpet, with the extra traction, and because it is indoor and smaller, I think I can actually hear the belt skipping...so I changed to the K-factory one and problem solved.
Also, I am using Tamiya Blue shocks, with all the regular springs collection I have from Tamiya, Xray, Schumacher...etc, as long as you are using the TC5 spring lower plate, all the regular springs will work.
I have to trouble shooting about what is going on with the speedo/radio setup...other ppls with 200 is a rocket, mine (I have other ppl drove my car) is totally unacceptable...they all say it is something wrong with the speedo setup (it is the setup from the electronics, not that the speedo is broken cause that TURBO WIND sound is not even funny if I keep holding the throttle for more then 2 seconds...)
Old 11-05-2009, 05:20 PM   #2648
Novaks new ballistic motors fit perfect in all of the E4's tons of room for sensor wire harness
Ambush Rc Factory Team Driver
Mbx6t, Go-Tech, Dynamite, JR racing
Trinity Platinum, Protek, GMK
rkhess is offline   Reply With Quote
Old 11-05-2009, 05:29 PM   #2649
it would be awesome if you had a sring rate chart (in LBS)for all TM springs on wolfhobbies website
anybody know what TM springs are equal to AE blues and greens ...but shorter in length
my car is dialed but a little high on ride height
Old 11-05-2009, 05:39 PM   #2650
05forfun's Avatar
Trader Rating: 31 (100%+)
I guess any brushless motors whose cans are not straight to the end cap (rounded or chamfered) will 100% fit into E4RS. I am using Trinity duo and speedpassion in my E4RS, they don't have chamfered end but still fit and leave enough space for adjustment. My E4JS, on the other hand, only works with Novak and LRP motors cause their cap side is chamfered.
Team Magic E4
HB Cyclone Touring
05forfun is offline   Reply With Quote
Old 11-05-2009, 05:50 PM   #2651
05forfun's Avatar
I used to have AE springs, if I remember correctly, the green is softer than blue, and I guess AE green is probably equivalent to TM green and AE blue is equivalent to TM pink or purple.
Team Magic E4
HB Cyclone Touring
Old 11-06-2009, 03:16 PM   #2652
Evoracer's Avatar
Hey All, new to the E4 and looking for setups. Are there good websites, forums, blogs, whatever where people are posting setups that have worked ?Looking for asphalt and concrete track advice. Looking forward to getting this car and I'll be spending some time sifting through this thread. Thanks
Brevard Electric Auto Racers / www.bearrc.com
Proudly Sponsored by Space Coast Harley-Davidson, Palm Bay, FL
RCGT all the way !!
Evoracer is offline   Reply With Quote
Old 11-06-2009, 03:28 PM   #2653
First of all hello to the E4 scene
What are you running??
5 or 6 cells,lipo,what motor?
What type of E4 your running???
For starters with 5 cells and 10.5 stock you can try toe in at the rear 2.5 degrees,camber 3 degrees,front camber 1.5 and zero toe in.
400 Tamiya oil in shocks and you can use the stock springs but they are a bit soft at the front.
Are you running a spool,one way or diff at the front??
If you have a new car the first thing you have to do is remove all bearings and clean them with alcohol and put some good silicone oil in them or replace them with the K-Factory items.
This will free up your drive train a lot.
If you drive 5 cells you want to move them to the forward position to give you a balanced car.
If you then have to much steer try to move them to the back so you get a bit less steering and more pressure on the back wheels.
This all is for tarmac.
For concrete i don't have a clue
cheers Roy
2x TM E4FS,GM90/Tekin RS PRO,GM 10.5/LRP 10.5,TM E4RS,LRP SPX,GM 13.5 Suzuki Swift stock,LRP Runner II
Pro10noob is offline   Reply With Quote
Old 11-06-2009, 03:28 PM   #2654
Cammer's Avatar
http://www.wolfhobbies.com/content.c...=1&pageid=2456
Cam Mayor
Dyno Twister Motors and Batteries
Cammer is offline   Reply With Quote
Old 11-07-2009, 10:32 AM   #2655
Evoracer's Avatar
Just got my E4JS in the mail. This may be the basic chassis but WOW. Very light, very nice quality. Gonna try and get her on track tomorrow. Oh crap it's gonna be another late nighter. Could run the car thats already to go but.......NAH !!!!!
RCGT all the way !!
Forum Jump
team magic m1b pitdog Nitro Off-Road 444 06-08-2009 03:11 PM
FS: Team Magic G4 - LRP Z12R Team Spec 2 - Add RX/TX LogiK Australia For Sale/Trade 1 08-03-2007 01:00 AM
Brian Berry Joins Team Phenix/Team Magic Motorman Nitro On-Road 27 03-07-2006 04:51 AM
Team Magic G4 JBrake R/C Items: For Sale/Trade 0 10-07-2004 06:56 PM
Team Magic G4 "Black Magic" tennessee Nitro On-Road 32 04-20-2003 10:40 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
