Old 09-04-2016, 08:07 PM   #661
So ... FF masters ... I've got my MTS FF setup pretty nicely now! Can power it around the bends. How can I be sure that when I'm accelerating I'm not wheel spinning like crazy? Running 10.5T as that's what I have spare at the moment and not really fancying buying another 13.5T.
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P10 & P12 & F1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
ST - Losi 22T 2.0
WagwanBumba is offline   Reply With Quote
Old 09-12-2016, 07:55 AM   #662
zephuros's Avatar
Default Wheel hop
Hey guys,
Took my TOP FD2 put to the track today after quite a few years and was sorely disappointed at the way it drove. Basically I was getting some very severe wheel hopping at the rear of the both on and off power. Anyone have any ideas why this is happening? Rebuilt the shocks with 600 and 400 Front and rear and the springs were standard TOP 324 and 289. Any ideas? Anyone? HELP!
zephuros is offline   Reply With Quote
Old 09-13-2016, 07:06 PM   #663
greasy geek's Avatar
Default Fwd setup help
I have a MTS FF V2. Does anyone know where I can get some info on how to setup FF. I love this car. I race it at my local club track, and won. But it is a handful. Would like to how to set it up. Our track is high traction. Rear end is real loose. Running 21.5 in usgt. Does the same rules go for FF, like a 4wd (also have 2 MTS 4wd). If all the weight is in the front how do I get the weight transfer. Any tips would be appreciated
Www.dischargerc.com
greasy geek is offline   Reply With Quote
Old 09-13-2016, 08:22 PM   #664
Www.dischargerc.com
Laydown rear shocks, try softer rear springs, add weight to the rear
I broke a golden rule of setup because the back end on mine was SUPER loose and did all of the above in 1 go, but now the rear end is solid. I can't get it to step out at all!
try the softer springs first then laying the shocks down and preferably don't add weight. I've removed mine but yet to get to the track to test it out.
ST - Losi 22T 2.0
Old 09-13-2016, 09:12 PM   #665
patorz31's Avatar
Change the chassis stiffener rods to the softest ones. Lighten the springs to the softest you have. There is very little weight back there. Also try softening the oil in the shock.
Northern Alberta Scale Car Auto Racers Pres. and Promotions
TEAM POWERS, RACE-OPT, SCHUMACHER RACING,R-Factor, Bezerk RC
patorz31 is offline   Reply With Quote
Old 09-14-2016, 04:33 PM   #666
Thank you for your help. Can't wait to get to the track to try them setting
JOHNNY Q
Motiv /Gravity /Discharge Rc/ ARC / Sanwa / Hudy / Hobbywing
Old 09-17-2016, 10:21 PM   #667
For High traction I run 2deg camber at the rear,and for any other track, 0.5 camber as you want the tyres to have as much contact with the surface. I also pre warm the tyres to 60deg and use FX or Paragon ground effects at the rear only!
benTC5 is offline   Reply With Quote
Old 09-18-2016, 03:17 PM   #668
longuylander's Avatar
I just finished assembling a 3Racing Sakura FF2015 and gave it a quick test with old tires, no body, and a half charged battery. It was initially uber-loose, but with a quick swap of the stock front springs to Tamiya extra hard (white) springs and turning the dual rate down to 70%, it became much better to drive. I'll save all other adjustments until I get the body finished (ABC's '98 Acura Integra Type-R).
Beyond that, my only other FWD car, a Tamiya FF01, is clearly outgunned already. The Sakura is lighter and has a gear diff in front with 500k oil in it. I guess that's not surprising, given the 20 years that have passed...
longuylander is offline   Reply With Quote
Old 09-24-2016, 09:00 PM   #669
tony gray's Avatar
For anyone who might be interested in what most people consider is the Holy Grail of FWD Touring Cars, I have one of my NIB YR-F2 SP kits on ebay right now...
Wow...it sold in like two minutes.. my second one is listed now..yes, I had two.
tony gray is online now   Reply With Quote
Old 09-27-2016, 08:13 PM   #670
BoneCrusher's Avatar
Default MTS FFv2 Pro
My MTS FFv2 Pro kit build (sort of) and first drive:
MTS 1/10 Electric FFv2 Pro Car Kit
Ivan
ARC R10, 12R5.1, Tamiya Mini, MTS FFv2 Pro, Exotek F1
carcar.ca
BoneCrusher is offline   Reply With Quote
Old 09-30-2016, 09:20 PM   #671
LAG
My Tamiya FF01 almost fully modified and restored with Tamiya, Kose, and Tech Racing hop ups.
I had this car for almost 18 years since I was 15 years old. Before I started restored it was my basher with a Trinity D4 6X1 turn motor. It was a beast. It took 2 to 3 house length for the car to actually hook up. Started restored it 8 years ago. Still working on finishing the Body.
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF-ff01.jpg   FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF-ff01-2-.jpg   FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF-ff01-5-.jpg   FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF-ff01-6-.jpg   FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF-ff01-accord.jpg
LAG is offline   Reply With Quote
Old 09-30-2016, 11:41 PM   #672
fyrstormer's Avatar
Man, you need some better tires if it took 3x the length of a house before the wheels stopped slipping.
Honestly I think slipper clutches should be allowed in FWD touring cars. It makes such a huge difference in controllability with my XV-01 FF, even with Pro compound tires.
Check out Fyrstormer's Garage in the Chat Lounge.
fyrstormer is offline   Reply With Quote
Old 10-01-2016, 11:33 AM   #673
heretic's Avatar
Very nice.
I love wedge bodies. I love dish wheels.
heretic is offline   Reply With Quote
Old 10-02-2016, 05:43 PM   #674
Default How do I correct a off power push
Had club race today. Had a off power push with my MTS FF v2. I put .5 degree of camber in rear. The rear end was stuck. I liked it. I could get the front to grab. Gave more rear droop. Softer fronts 2 degree of camber. Any advise would be great
Old 10-03-2016, 08:38 PM   #675
LAG
Probably the one of the worst FWD ever the Hpi Switch.
Since I'm a Hpi guy its my current project trying to improve the chassis faults the steering and drivetrain. I like a challenge what can I say. My inspiration is my old Tamiya FF01 I posted above that has been restored and retired.
Current Mods
Turnbuckle front and rear
Aluminum shocks
Aluminum motor plate
Bearings for steering assembly
Cup Racer universal shaft
The current mod is the Novak Ballistic 8.5T. Yes I know is to much motor but will see how long the drivetrain last. I added Cup Racer universal shaft,
shims to the Gear diff and heavy duty grease also installed aluminum hex.
FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF-switch-2-.jpg   FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF-switch-.jpg   FWD TOURING CAR FORUM - Tamiya FF01, FF02, Yokomo YRF-2, Kyosho Mantis FF-switch-3-.jpg
Kyosho Inferno MP9 1/8th Buggy ★★★★★ HOT ★★★★★ Mike Schumacher Nitro Off-Road 3 05-14-2008 06:30 PM
★★★ BRAND NEW LOSI EIGHT-T RACE ROLLER $415 SHIPPED! ★★★ Chris Furman R/C Items: For Sale/Trade 10 04-28-2008 09:24 AM
★★★ HUDY 1/10 TOURING SETUP STATION ★★★ Chris Furman R/C Items: For Sale/Trade 21 03-19-2008 10:06 PM
★★★★★ TrakPower 4900mAh 7.4V LiPo Battery & Balancer ★★★★★ Mike Schumacher R/C Items: For Sale/Trade 10 02-25-2008 04:17 PM
★★★ Active Hobby A210SS 1/12 Mini Touring Car ★★★ Mike Schumacher Electric On-Road 5 12-30-2007 10:26 AM
