Old 01-17-2011, 10:57 PM   #1456
inconceivable's Avatar
Originally Posted by Still Bill View Post
Risers? If I am understanding correctly, #4262 Front Ride Height Shims will allow you to set your front height to just over 4mm. If you only run smaller front tires (54mm and under), you can get by with one set. Otherwise, think about having two sets to work with.Bill
Actually I meant Riser Plate ? It's listed on the setup sheet and people tend to put yes or no (Wynn = No). Not sure what this is or what affect it has on the fornt end. It's not the ride height shims, it's apparently something else ?
For the record, I run on carpet but was really just interested in these setup options and what affect they may have. These really aren't explained in the manual and other than track width, I really had never run accross these options.
Still Bill - Your other comments are much appreciated, exactly what I was looking for .... Thanks !
"And now the Matador shall dance with the blind shoe maker"
"America is all about speed. Hot, nasty, badass speed. - Eleanor Roosevelt, 1936"
inconceivable is offline   Reply With Quote
Old 01-17-2011, 11:30 PM   #1457
Still Bill's Avatar
The Riser Plates were used on the original Gen-X 10 Pro car. You can find them pictured on Page 10 of the Gen-X 10 manual that is available on the CRC website. They are not used on the LE; so, all setup sheets for the LE would indicate "No". Like you, some people won't know what these plates are; so, a "Yes" could only refer to having the washers described below in place.
Basically, the eight (8) gray #4 washers shown on Page 10 of the LE Assembly Manual replace the Riser Plate by bringing the Front End Plate up above the chassis plate for larger tires on the car.
Because I run smaller sized front tires all the time, I don't use these 8 gray washers. My LE's Front End Plate rests directly on the main chassis plate.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 01-18-2011, 03:20 AM   #1458
Default CRC 1/10th pan car for sale
Just wanted to direct your attention to this.
CRC 1/10th scale pan car
woodys3b is offline   Reply With Quote
Old 01-18-2011, 05:15 AM   #1459
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
Lol @ rug muncher.
Originally Posted by joeymdz View Post
what are you trying to achieve? are you a rug muncher or road rash racer? 1s or 2s? 10.5, 13.5, or mod? (info info info)
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
check out the new 12th scale GT class! https://www.facebook.com/groups/148391312353349/
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 01-18-2011, 06:42 AM   #1460
Make sure you run in the axles in the trailing position. Pick up the kydex and foam bumpers. Also make sure the car is balanced out, it is much more important to have it balanced than trying to get it to the 930 grams min. weight. When it comes time to race make sure your tires are small, as it really makes a difference. One last thing is to have extra kingpins on hand, they tend to bend or break. If you break one you will lose your spring too. It's a really a great car, easy to drive and fast.
chuck
mackin is offline   Reply With Quote
Old 01-18-2011, 06:48 AM   #1461
Kwikvdub's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Kwikvdub
Thumbs up
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 01-19-2011, 08:05 AM   #1462
spring71's Avatar
Smile
2011 1st TQ Pan Car Grand Prix is up this Sunday.
Track will be open at 9am, Race will start 12pm.
We will have Trophies for the winners and Raffles for every racers.
Pre-Signup racers will get one more raffle ticket, click here for pre-signup.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
[email protected]
spring71 is offline   Reply With Quote
Old 01-19-2011, 09:54 AM   #1463
Just reading some of the posts above, and noticed someone saying to have the axles trailing. I have the original X-10 and run outdoor on Medium/Low traction. I run in-line axles per manual. What effect does flipping them have?
Agama A8 Evo | GRP .21 | Spektrum | Savox
My car just hit 88mph. I hope it comes back soon....
JR007 is offline   Reply With Quote
Old 01-19-2011, 10:23 AM   #1464
Still Bill's Avatar
See Dumper's post on Jan 5 in this forum where he comments about trailing axles on carpet.
I usually like more aggressive steering on all asphalt; so, I do have them in-line for that. Would typically have the wheelbase as long as possible at the front end too.
Old 01-19-2011, 01:19 PM   #1465
Try it out! Run them one way and then try them the other way. Neither way is going to be horribly undrivable. The worst that is going to happen is that you are not going to like how it feels. It is all driver preference. I am actually playing with the inline axles now.
Get out there and test! That is part of the fun of this hobby.
Looks like a fast field of cars are going to be running at Snowbirds. It will be a very good test of the stuff that I have been testing.
dumper
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 01-19-2011, 02:42 PM   #1466
I'd LOVE to get out there testing. Get the violins out for this bit. I have a wife and kids, full time job, and am 30 minutes from the track, so i'm lucky to get one practice session between our monthly meets.
I do have 2 sets of front ends, so I may set them up identical except for the axle and then it will be a quick swap. Although, for now Ii'm probably better off getting my consistency better, then start tweaking stuff like that.
On the plus side, I raced last weekend with a couple of other guys at a new track, and my car was the only one that didn't look like it was racing on ice. Was nice to be the guy with the money set-up for a change!
Old 01-19-2011, 08:31 PM   #1467
Default Traction roll!
Any help or suggestions will be appreciated..
Gen X- 10 with Mikune chassis 17.5 1s open ESC
1/12 - 50 front springs
30,000 in the tubes
White side springs
Side wall glued front and rear, CRC purple spec foams
Med - to high grip carpet
First heat the car is pretty good, second heat as the traction comes up the car wants to traction roll?
Thoughts?
Bobinmt is offline   Reply With Quote
Old 01-19-2011, 08:43 PM   #1468
Still Bill's Avatar
Your track at www.crccc.co.nz is a monster layout. I would have trouble just "seeing" the track.
Are you running the 235mm wide configuration with a CanAm body?
Old 01-19-2011, 08:50 PM   #1469
Still Bill's Avatar
30,000 in the tubes
White side springs
Thoughts?
Nice setup. What is your front camber setting?
Bill
Old 01-19-2011, 09:10 PM   #1470
Still Bill's Avatar
Originally Posted by bsmooth View Post
Ok,
here's a (dumb) question:
where do I slide the gauge in to check front ride height?
I try to get it as close to the front kingpin as possible, but the visibility is bad.
I feel like i'm somewhat guessing half the time.
Thanks in advance.
-Steve
Steve,
I pretty much just use the gauge behind the front suspension.
Tend to run my car pretty flat; so, 4.2-4.4mm behind the front suspension means that nothing up front is under 4.0mm.
FYI...For me, going less than a 4.0mm ride height results in too much chassis drag through the corners.
Bill
