Old 01-11-2011, 09:25 AM   #1426
joeymdz's Avatar
Send a message via MSN to joeymdz
also www.gearchart.com (after inputting your info print off some cheat sheets)
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 01-11-2011, 10:29 AM   #1427
al dente's Avatar
there is also a great app for your cell phone called gears. i use it constantly. for andriod users, just search "gears". it will calculate fdr and rollout.
Team CRC / Dumper's Speed Shop / Team Scream Racing / Black Art
RC America / FB/FX / Colorado On Road RC Club
5280 Raceway (5280raceway.com) home of the MILE HIGH INDOOR CHAMPS April 20-23, 2017
al dente is offline   Reply With Quote
Old 01-11-2011, 11:49 AM   #1428
joeymdz's Avatar
hey mario are you coming for the TZII national event?
Old 01-11-2011, 12:24 PM   #1429
al dente's Avatar
whats up, sleepy? i am not sure..... trying to get there, but that week is my kid's spring break, and the next week we have a drag race in vegas.
Old 01-11-2011, 04:40 PM   #1430
joeymdz's Avatar
sleepy? it was more of a cat nap.... haha owwhh that was a ruff day!! lessson learned
Old 01-11-2011, 06:42 PM   #1431
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
I'm getting my CRC Gen-X LE next week! I got a great deal on a used one.
**Doin the Happy Dance!! **
I need to d/l a instruction manual and get a setup for an outdoor asphalt track, do you guys know where you can point me?
Thanks!!
offroad - AE B44.3 / /Serpent SRX2 MM / /
onroad - VTA AE TC7 // XRAY 2017 T4//CRC Gen X SE- WGTR
support your local tracks- Beachline Raceway-Revolution RC-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 01-11-2011, 06:48 PM   #1432
Manual http://www.teamcrc.com/crc/downloads...0LE_manual.pdf
Setups
http://www.teamcrc.com/crc/downloads...sVegas2010.pdf
http://www.teamcrc.com/crc/downloads...eveland_10.pdf
VORRA; www.RVAHobbies.com; www.ashfordhobby.com; www.tqwire.com
bgrick is offline   Reply With Quote
Old 01-11-2011, 06:51 PM   #1433
JEFFs SC10's Avatar
Big Rick you are the man!!
Old 01-12-2011, 07:29 AM   #1434
Default CRC GT10
Just aquired my first CRC GT10 with the Mckune chassis conversion.
Has the short arm front end.
Have a few questions.
1.Front brace yes or no If yes ,is one available.
2.Plan to run 1S lipo 10.5 bl is rollout the same for GT10 as 1/12th
3.Tyres diam front rear.
4.Tyre grades for carpet
5.Tyre grade for asphalt
as regards set up , springs ???? ,shock oil ????? Droop damper oil ???
cheers in advance vinny
MB Models Leeds,RC4LESS,Troy McKune
V-DEZIGN CR5 ,LRP SXX, CRC cells,
tellan is offline   Reply With Quote
Old 01-12-2011, 01:07 PM   #1435
tim fry's Avatar
Not sure if the Mckune takes the front brace but defo fit it if you can it goes across the lower front of the chassis. We run 55mm tyres and only run the lilac specs on carpet as it takes the choice out.
Rollout will be roughly the same as 12th. I run standard centre spring but use 12th front king pins and springs and heavy side damper fluid. Oh and wide front end and middle on steering arm. Works great
tim fry is offline   Reply With Quote
Old 01-12-2011, 01:32 PM   #1436
joeymdz's Avatar
McKune chasis has the exact same hole line up so yes it will fit a front brace
Tellan,
look on the crc manual down loads and look at what the Pro guys are doing... thats always a great starting point.
1.Front brace yes or no If yes ,is one available. (crc lower brace, mckune upper or lower brace, manutech)
2.Plan to run 1S lipo 10.5 bl is rollout the same for GT10 as 1/12th (no its different.. go to www.gearchart.com)
3.Tyres diam front rear. (club racing or competition?)
4.Tyre grades for carpet (depends on the class spec)
5.Tyre grade for asphalt (depends on the class spec)
Old 01-16-2011, 11:13 AM   #1437
tim fry's Avatar
After running the car today the rear seemed really locked in but generated some push . I havent changed my setup for a while and we cannot change tyres as we run the control lilacs. I need to get more steering off power I am running 10 deg caster and all spacers behind the arm for maximum corner entry.
Old 01-16-2011, 12:05 PM   #1438
NiMo's Avatar
Move some weight forward, like maybe the RX over the front axle, works wonders for me outdoors.
NiMo is offline   Reply With Quote
Old 01-16-2011, 12:47 PM   #1439
BCbud's Avatar
Trader Rating: 37 (100%+)
Good day!
If you add a little chassies roll you will get more traction on the front outside tire. This can be done several ways, softer front springs, backing off on the side springs or using softer side springs, lighter tube oil. You can also chaing how you use traction wash, more on the front and less on the rear.
All these changes should add more steering / loosen the rear traction. Try one at a time and see how it works for your track and driving style.
Xray NT1 - Xray T4 2013 TC - Xray T4 2013 VTA - CRCgenX10 - CRCgenX - CRCgenXi - Slash 4X4 with LCG conversion -Associated RC8Be - Xray XB4 - DX3R PRO
Recycled teenager.
www.irocc.ca ; www.corvictoria.com ; http://www.wcics.ca/
I will not send Pay Pal as a gift or add fees to the price so DO NOT ASK!
BCbud is offline   Reply With Quote
Old 01-16-2011, 06:40 PM   #1440
bsmooth's Avatar
Trader Rating: 17 (100%+)
Default front ride height
Ok,
here's a (dumb) question:
where do I slide the gauge in to check front ride height?
I try to get it as close to the front kingpin as possible, but the visibility is bad.
I feel like i'm somewhat guessing half the time.
Thanks in advance.
-Steve
bsmooth is offline   Reply With Quote
