Old 01-09-2011, 10:07 AM   #1411
gijoe64's Avatar
Trader Rating: 26 (100%+)
Selling my LE with exxtra mckune chassi.
CRC GEN-X LE 2 Maxxcell 5200mah more
Raymon Robinson
ARC, LRP Go Blue!!
gijoe64 is offline   Reply With Quote
Old 01-09-2011, 05:22 PM   #1412
V12
V12's Avatar
there are 2 different one-piece side link versions #3280 normal version and #3281 XL version. How much is the difference in length?
V12 is offline   Reply With Quote
Old 01-09-2011, 05:26 PM   #1413
JEFFs SC10's Avatar
Trader Rating: 15 (100%+)
So is/was that originally a CRC Gen X LE?
I might be interested.
offroad - AE B44.3 / /Serpent SRX2 MM / /
onroad - 21.5 TC AE TC7// VTA AE TC7 // XRAY 2017 T4//CRC Gen X SE- WGTR
support your local tracks- Beachline Raceway-Revolution RC-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 01-09-2011, 07:36 PM   #1414
Would there be any gain by running a smaller spur gear, like going from 90>72tooth.
Friulimotosport is offline   Reply With Quote
Old 01-09-2011, 07:53 PM   #1415
Still Bill's Avatar
For WGT?
For what motor? Ramped or not?
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 01-09-2011, 08:02 PM   #1416
17.5 ballistic and open esc.
Old 01-09-2011, 08:06 PM   #1417
Still Bill's Avatar
Should have asked...Because I ran 17.5 2S at one time....Is it 1S or 2S?
Old 01-09-2011, 08:12 PM   #1418
1 cell
Old 01-09-2011, 08:34 PM   #1419
Still Bill's Avatar
#3280 is the 55mm link (optional longer link for older Gen X-10 Pro) vs. the #3281 65mm link (for both 1/12th XL and Gen X-10 LE).
Old 01-09-2011, 08:39 PM   #1420
Still Bill's Avatar
1 cell
And what rollout would you be trying to achieve?
Old 01-09-2011, 08:49 PM   #1421
Just looking to see if by running a smaller spur there would be any advantage?
Old 01-09-2011, 09:03 PM   #1422
Still Bill's Avatar
For gearing purposes, I like my spurs to be as large as possible; so, my gearing ratio increments are are small as possible for fine tuning the gearing. Therefore, all of my ramped setups have used a 100T spur. For non-ramped, I use 88T.
A Kimbrough 88T is the smallest spur gear you can use their dust covers with. Great for outdoor racing.
Old 01-10-2011, 06:54 PM   #1423
Default roll out
Hi, can you tell me how calculate the roll out on a CRC genX 10.
Thank you, Alain.
1/10 Durango DEX 410 V3
Alain Patry is offline   Reply With Quote
Old 01-10-2011, 07:23 PM   #1424
Thank you, Alain.
Pinion x tire dia. x 3.14 / spur=rollout
Old 01-10-2011, 09:27 PM   #1425
20 SMOKE's Avatar
Trader Rating: 100 (100%+)
spur /pinion=fdr
tire diameter x 3.14 = tire circumference
circumference / fdr = rollout
example
100/40= 2.5
tire size 52mm x 3.14 = 163.28/2.5 =65.31
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
SEO by vBSEO 3.5.0
