CRC 1/10 Pan Car
#1352
Spec Tires
So far, I have only done purple/pink when the asphalt surface has been sealed.
Bill
#1356
the tires are compounds you can see then in the attachment,the spec tire is the same compound that each manufacture uses just like having a spec esc there all supposed to be the same,as for the car it is personal preference they all work well i live 10 min from BMI and friend with the owner
#1357
Would suggest that you compare results for the Copperhead 10 and Gen-X 10 LE cars at your local track and determine that for yourself. CRC is more prevalent at my local carpet track; but, BMI is based in Florida where you reside.
Bill
#1359
Hi guys,
We have indoor carpet rc track & shop in Chino CA.
CRC Gen-X 10 Le kit, parts and tires are back in stock.
Click Here to check out.
Thanks.
Thanks.
#1362
I'm trying to find a heavier spring for the Encore shock (CRC Gen-X 10 LE) and unfortuntately I can't figure out CRC springs. Is a black VCS/Encore spring 11 lb ? It has #11 in the description ? I can't find anything anywhere indicating what weight each spring is. At this point I'm using an Associated Copper (heaviest available for the 12R5) spring which is 16lb and want to try something in the 18lb to 22lb range. Are any of the CRC springs this heavy ? Are there other springs that could work ? Thanks.
#1363
CRC Blue = Assoc Silver.
CRC White = Assoc Blue
CRC Red = Assoc Gold
CRC Green = Assoc Red
CRC Purple = Assoc Copper
CRC Black = stiffer than copper
#1364
I trimmed the back side of the bumper for weight savings.
dumper
#1365
Hi all,
Just got my GEN-X 10 LE today. Along with the kit are pairs of Purple foam tires (front JAC2125 and rear JAC2143) from JACO and a 200mm DB-9 World GT (#10225) racing body with wing from Parma. (I hope I ordered the correct stuff for the 10 LE). I am into 1/10 touring cars and planning to introduce the 1/10 pan car racing here in my local racing club.
Can you guys give me a couple of assembly tips, do's and dont's before and while assembling this great car? I want to get it right for the first time.
Any piece of advice will be much appreciated.
