Old 10-05-2010, 10:17 PM   #1171
superspeed's Avatar
world gt class for this chassis or straight 1/10 pan class?
superspeed is offline   Reply With Quote
Old 10-05-2010, 10:22 PM   #1172
Still Bill's Avatar
WGT
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 10-06-2010, 05:26 AM   #1173
nitrobeast's Avatar
Trader Rating: 40 (100%+)
Originally Posted by Still Bill View Post
Got an e-mail from Frank today saying the WGT conversion kits are now available for $99.99. Go to their website.
Cant find it...
Rui Goncalves
Reds Racing USA|Hot Race Tyres USA|Team CRC|Team Trinity|
Jackson RC|Horsham RC|Floyd Bennett|Blue Diamond
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 10-06-2010, 09:31 AM   #1174
al dente's Avatar
Originally Posted by darcydawg View Post
I have a question about installing the encore shock on my Gen X10. Should I change (lower) the ball stud on the rear pod?
Thanks,
Carter, who is waiting for the LE conversion.
depens on your car. the early versions had taller stand offs for 2s lipos. if you car has these you may not need to. the reason that the encore needing to be flatter is because the ball cup hits the hex portion of the ball stud. that is what you need to look for.
Originally Posted by shaggy1 View Post
what wt. oil and spring were guys using in vegas in thier encore shocks?
stock oil, purple spring for me in 13.5
Team CRC / Dumper's Speed Shop / Team Scream Racing / Black Art
RC America / FB/FX / Colorado On Road RC Club / Manutech
5280 Raceway (5280raceway.com) home of the MILE HIGH INDOOR CHAMPS April 20-23, 2017
al dente is offline   Reply With Quote
Old 10-06-2010, 10:22 AM   #1175
The conversions are in stock! I just packed up a ton of them. Part #1713. If they are not on the website yet, you can call us and order one. I am off to TimeZone, so I am leaving in a few minutes to catch a plane, but there are people here to take your order.
In Vegas, I ran stock 30 wt oil (that is all we run 10th or 12th all the time) and I ended up with a CRC purple spring. I tried CRC red, green and purple, and ended up staying with the purple.
I am going to be testing some setups at TimeZone this week, if I come up with anything new I will be sure to post it on here.
Thanks for the support guys, we are trying to keep you guys as fast as possible!
Brian Wynn
Team CRC
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 10-08-2010, 04:08 PM   #1176
Default Minimun front tire diameter
Is there a minimum front tire diameter where performance starts to suffer?
Thanks,
Carter
darcydawg is offline   Reply With Quote
Old 10-08-2010, 04:50 PM   #1177
NiMo's Avatar
Thanks,
Carter
For me it is when the plastic starts showing
NiMo is offline   Reply With Quote
Old 10-08-2010, 07:48 PM   #1178
Still Bill's Avatar
Pretty much the same for me as long as the traction is high. Run them to the rim.
However, if traction is not high, you would want some amount of foam on the rim available for traction compound. Can say...less traction...more foam.
Rim diameters can vary slightly between manufacturers, so one brand cut to a certain size may have a tad more or less foam than another brand.
Bill
Old 10-15-2010, 01:42 PM   #1179
spring71's Avatar
Smile
1st TQ Pan Car Grand Prix is UP this Sunday.
Track will be open at 10am, race will start at 1pm.
3 Qualifies and 1 Main, 1st,2nd and 3rd winner will get the trophies and raffles are ready for the all racers.
You will get one more raffle ticket for the pre-signup.
Click Here for Pre-Signup
90X45 track size indoor carpet racing track in Chino, California.
For more information Click Here
Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
tq@tqrcracing.com
spring71 is offline   Reply With Quote
Old 10-15-2010, 08:53 PM   #1180
Still Bill's Avatar
Thanks.
If I had only known....I could'a been a contender!
I'll get there someday...
Bill
Old 10-16-2010, 06:00 AM   #1181
Default In need for Left Side Pod Plate part number #3338
Hi,
need Left Side Pod Plate part number #3338. Can not find it anywhere with shipment to EU...
Audrius
www.rc-cars.lt - offroad in Lithuania
www.lasa.lt - onroad in Lithuania
audriusv is offline   Reply With Quote
Old 10-25-2010, 02:31 PM   #1182
Photocycler's Avatar
Trader Rating: 33 (100%+)
Anyone running the McKune Chassis with the CRC Encore Shock? I need to know how the rear top battery brace is mounted?
Are the mount holes closer to the rear pod or closer towards the front of the car?
Photocycler is offline   Reply With Quote
Old 10-25-2010, 04:14 PM   #1183
Capt'N_Slow's Avatar
Need to have the holes mounted towards the rear pod. Use the second hole or the furthest one away to get the shock to have the correct amount of droop.
To make sure the shock cap clears on compression I put an additional 1mm washer under the pivot ball (CRC13615). On the pod end I used a red ball stud (CRC1409) and the locknut used on the 12th scale.
Have tried running the Green and Purple springs and found them to have a tonne of steering.
Micah
Capt'N_Slow is offline   Reply With Quote
Old 10-26-2010, 08:29 PM   #1184
So how many others run these with 2-cell Lipo? Running it with a 13.5 and turbo is wicked fun
We just had a good race meet with a handful of pans on our large asphalt track. The car drove fantastic considering i'm new to pan. Our lap times are almost the same as the touring cars we used to drive, and we've only been running pan for a few months. The car was on rails, powering up while still coming out of the corner was no problem.
Does anyone know if the rear pod loaded with a brushless motor is balanced left-to-right? I have the whole chassis balanced, but want to make sure i'm not counter-tweaking the front to make up for an imbalance on the pod. I don't have scales, so it's screws and the old eye-ometer to set my balance
Agama A8 Evo | GRP .21 | Spektrum | Savox
My car just hit 88mph. I hope it comes back soon....
JR007 is offline   Reply With Quote
Old 10-26-2010, 08:45 PM   #1185
Troy Mckune's Avatar
Trader Rating: 38 (100%+)
Yes,
To run the Encore shock on the Mckune Chassis turn the shock mount plate around. The two hole should now be toward the rear. Mount a pivot ball (Same as side links) in the front hole.
I will post some pictures soon.
Troy
Mckune Design / facebook page / RC America / XRAY / Lunsford Racing
Mckune Design is a custom manufacturer of CNC machined carbon fiber, G10, & composite laminate parts for RC, Aerospace, medical, and high tech industries.
Troy Mckune is offline   Reply With Quote
SEO by vBSEO 3.5.0
