Old 02-22-2010, 04:28 AM   #1141
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Originally Posted by Still Bill View Post
Do you clean your tires (with lighter fluid) between runs? Otherwise, your traction compound probably builds up too much as the day goes on.
Hey
Yes i use lighter fluid. I guess what i should be asking is how can i free the rear up or get more steering? Will using harder damper tube fluid give more steering and how about harder tweak springs? Thanks for the help guys
Rui Goncalves
Reds Racing USA|Hot Race Tyres USA|Team CRC|Team Trinity|
Jackson RC|Horsham RC|Floyd Bennett|Blue Diamond
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 02-22-2010, 06:08 AM   #1142
CypressMidWest's Avatar
Originally Posted by nitrobeast View Post
I only do half of the rear already. Its almost like the rear is way too planted and needs to be looser or i need to get more steering to swing it around.
What's your battery position? If you're not all the way back try moving it back some.
Go up in center shock spring one rate, and run a bit thicker shock oil. That should get you a bit more steering, especially if the car is tight from the center of the corner on out.
Stiffer side springs and more tube damping may help, but that would be my second step.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 02-22-2010, 06:23 AM   #1143
nitrobeast's Avatar
Yup, battery all the way back. I wanted to try the harder center spring this weekend but left them at home with my touring car stuff (losi).
Im running 30wt losi and a 20lb spring now. Is going harder still ok?
Rui Goncalves
Old 02-22-2010, 06:45 AM   #1144
I'd try a 25lb spring and 35 wt. oil. That should keep the car from dumping weight to the rear as hard when you get back on power.
Old 03-29-2010, 07:59 AM   #1145
JJC
Default Servo?...
Does anyone know if a low profile TC servo such as a Futaba 9550 will fit the CRC Gen-X 10? Or will I be needing a 1/12 servo like a Futaba 9602?
JJC
JJC is offline   Reply With Quote
Old 03-29-2010, 08:55 AM   #1146
Trader Rating: 36 (100%+)
JJC
I couldn't find a 1/10 servo small enough to fit. The 1/12 servos fit perfect.
EVILGRAFX is offline   Reply With Quote
Old 03-29-2010, 12:49 PM   #1147
Trader Rating: 27 (100%+)
Send a message via AIM to John Stranahan
I use a wide BLS 451 servo on one of my Gen X 10. Instead of using the normal Servo mount mounting screw, on the right side, I use the servo plate mounting screw direct into the servo mount (the angle red aluminum part). You lose side to side adjustability but the servo saver is well centered. I use the half height Hitec 2431 the same way. It is off center but only the tiniest bit. Not enough to notice on the track. So yes.
JohnStranahan@aol.com
TeamCRC.com Mikes-HobbyShop.com
John Stranahan is offline   Reply With Quote
Old 03-29-2010, 01:27 PM   #1148
fpart's Avatar
Trader Rating: 38 (100%+)
Send a message via Skype™ to fpart
Default Conversion
Does anyone know if someone makes a conversion kit to convert a Gen XL 1/12 to the Gen XL 1/10 car. I want to convert my 1/12 car to wgt. I see there is a 1S Lipo chassis but I wanted a complete kit.
Thanks in advance.
teamTrinity.com Sweepracingusa.com
スクービーは私のヒーローです!
Why is Scooby so slow, you might ask?
fpart is offline   Reply With Quote
Old 03-29-2010, 05:04 PM   #1149
There is no kit to convert a 1/12 to 1/10 Gen X 10. These are the parts you need. Gen X 10 axle, left hub, right hub, X brace, Top plate, Bottom plage, Gen X 10 chassis, new minimized left side hub if you are not equipped with that, longer 1/10 kingpins. Longer 1/10 steering arms, Battery Top plate, Battery side mounts, metal 4-40 inserts for side mounts, four hex standoffs long and mounting screws. battery tray set, new center pivot molded Plastics, longer front and rear body posts, front bumper, Servo mount plate and screws, Rear Hourglass standoffs (4), Rear Side Plates, Long side damper set. I think that covers it. I have all the http://www.stranahan-rc.com/Catalog_c362901.html.
however it is probably cheaper to buy a new kit at Stormer. Heck of a good price there.
Old 03-29-2010, 06:11 PM   #1150
fpart's Avatar
John, Thanks!
スクービーは私のヒーローです!
Old 06-24-2010, 11:17 PM   #1151
bsmooth's Avatar
Trader Rating: 17 (100%+)
Default asphalt setup
Does anyone have an asphalt setup they can share? There's nothing relevant on the CRC website of course. I'm running 1s/ 13.5.
Thanks,
Steve
bsmooth is offline   Reply With Quote
Old 06-25-2010, 04:13 PM   #1152
Here is my asphalt setup.
CRC Battle Axe, GenXPro 10, 1/10th pan, Brushless, Lipo,4c, Road, Oval,TipsandTricks
Old 06-25-2010, 06:10 PM   #1153
Still Bill's Avatar
Thanks,
Steve
bsmooth,
John's setup above is what he uses for 2S. Totally different animal in my book. Sorry John.
Ask Scotty Barnes for his X-10 setup at Speedworld. Should be close to mine.
Place your ESC on the left side...Not behind the battery pack...You need weight transfer from side-to-side when on SW's asphalt. My 1S pack is about 1/2" from the front of the tray.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 06-25-2010, 08:15 PM   #1154
bsmooth's Avatar
bsmooth,
Bill
Thanks Bill,
i'll do that and send Scotty an email as well.
-Steve
Old 06-25-2010, 08:35 PM   #1155
Still Bill's Avatar
Thanks Bill,
-Steve
And if you come to the Asphalt Nats at NorCal in August, the CRC team will likely have some setup beyond your expectations. Like they did for me for the carpet at the 2009 IIC.
Bill
