Old 02-02-2010, 12:33 AM   #1096
Default Snowbirds
Would be interesting to hear about CRC team races at Snowbirds. Troy mentioned two drivers but I believe there was more ;-) .
Audrius
www.rc-cars.lt - offroad in Lithuania
www.lasa.lt - onroad in Lithuania
audriusv is offline   Reply With Quote
Old 02-02-2010, 02:06 PM   #1097
bsmooth's Avatar
Trader Rating: 17 (100%+)
Default Diff woes
So,
i'm putting my diff back together after sitting for a few months, and something is amiss. I think the silver collar (that rests against the bearing) shrunk!! I dropped on the aluminum collar, then the conical washer, tried to tighten it down, and it bottomed out on the carbon part of the axle! For some reason there is more of the carbon axle exposed which keeps the nut tightening fully.
I'm not sure what the heck happened. I ended up using the plastic collar from my 12th scale car to make it work (coller is thicker, or wider than the aluminum one).
What am I missing here? The only thing I can think of is the spur gear is thinner, but I think its negligible.
Are any of you using a thrust bearing? (like Slapmaster)
Hope this makes sense. Any ideas would be appreciated.
Thanks,
Steve
bsmooth is offline   Reply With Quote
Old 02-02-2010, 02:54 PM   #1098
adamge's Avatar
bsmooth, are you the pancar version of Mcsmooth?
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 02-02-2010, 07:43 PM   #1099
Still Bill's Avatar
Originally Posted by bsmooth View Post
So,
Thanks,
Steve
The threaded rod is pulling out of the composite axle as you tighten the nut. CRC warranteed such issues because they sent me a free replacement axle over a year ago. I believe that they initially got a bad batch of axles.
Yes, I do use a Slapmaster. They come in a specific size for certain 1/10th scale cars. Always have one in my pan cars.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 02-02-2010, 09:18 PM   #1100
bsmooth's Avatar
Bill
I'll be dammed. That makes sense. Thanks Bill. Is there any shops that carry Slapmaster stuff, or do we still need to order direct?
Oh, and how did you get CRC to warranty the part?
Maybe I'll see you at Norcal Thursday night.
Thanks again.
-Steve
Old 02-02-2010, 09:29 PM   #1101
Still Bill's Avatar
Thanks again.
-Steve
I believe I saw Slapmaster at either A-Main Hobbies or Nexus in the past month. Make sure that you order the correct one for your assembly. That info about the different models is on the Slapmaster website.
It's been a while; but, I believe I e-mailed John at CRC to get the replacement unit.
Bill
Old 02-02-2010, 10:36 PM   #1102
bsmooth's Avatar
Bill
I'll try it.
thanks again.
-Steve
Old 02-02-2010, 10:49 PM   #1103
joeymdz's Avatar
Send a message via MSN to joeymdz
slapmaster thrust bearing is a must! you can order directly from Brian's site:
http://www.slapmastertools.com/thrust-bearings.php
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 02-02-2010, 11:01 PM   #1104
Still Bill's Avatar
This is the correct one...#120 will fit: CRC GenX10 WGT
Old 02-04-2010, 04:04 AM   #1105
rsperson's Avatar
Default why 1/10th pan???
Originally Posted by Ike View Post
I've just never quite understood the appeal of this class over 1/12th scale. Seems that I'm not alone either since this class died once and has failed to be resurected at least a couple times that I know of. At least now the one advantage it has is the ability to use Lipos. Would be fun to have one to play around with but a 1/10th scale pancar is was down in my list of things I want to buy for RC.
have you ever wanted to run your 1/12 scale outside? 1/10th pan can be used inside and out. Can use touring car bodies. simple and much less expensive. Run your 4 cell battery and a 19 brushed and be just as fast as a touring car at one third the price. Use modern brushless, lipo and have a missle that will chase down 1/8 nitro cars (almost) and still run on the carpet
rsperson is offline   Reply With Quote
Old 02-04-2010, 08:58 AM   #1106
PDX-Spike's Avatar
+1
How about 2S and 5.5 outdoors? Don't blink.
Roger Christal - Team Timezone (Hooligans), Rose City Scale Racing, ROAR Member until 9/16/2012
Support the locals: Timezone Raceway, Timezone II, R/C Plus, Portland RC Raceway
McKune Design, Slapmaster Tools, Houston's Engine Service
PDX-Spike is offline   Reply With Quote
Old 02-04-2010, 11:11 AM   #1107
ChadRacing's Avatar
Im not a Team CRC driver but i did use the Mckune chassis and finished 3rd in the C-main. But im also not a high caliber driver. And this was my first time racing a WGT Car.
ReVtech / Trinity / EAMotorsports
HotShot RC / Nexus Racing
Xray T2 '009 w/Exotek Chassis, BMI DB12rr, Tamiya F104X1
Team Durango DEX210
ChadRacing is offline   Reply With Quote
Old 02-04-2010, 01:13 PM   #1108
tim fry's Avatar
Lots of people ask me why I run WGT and not touring cars anymore (Not 12th I know) but I have found that you can be competitive with fairly cheap gear. I also like the fact that parts are dirt cheap and upgrades are not really needed although I have bought a few mainly better screws and fittings.
My Genx10 has been almost bullet proof since I have had it the only problem I have had has been the thread pulling out of the rear axel and the racing has been really close. If I was still running touring I would have probably broken more or worn more parts which would have needed replacing.
tim fry is offline   Reply With Quote
Old 02-05-2010, 07:10 PM   #1109
Hi ,
I'm thinking about getting one of these to race at the local track and with some m8's , The local track runs carpet and I usually race my M8's from work on smooth asphalt in our office parking lot. How well does this car run on asphalt and how well does it hold up? I want to get it because I like the simplicity, speed and style over TC's and minis I just want to make sure that I'm not going to wreck it on parking lot asphalt.
Steve
mrrc is offline   Reply With Quote
Old 02-05-2010, 08:44 PM   #1110
Still Bill's Avatar
Originally Posted by mrrc View Post
Hi ,
Steve
I use mine on asphalt during that time of the year. Runs great and is most durable with a foam bumper in place.
Bill
