Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 10-12-2009, 01:33 AM   #1036
RossoTorro's Avatar
Wish i have known they had metric, i got myself the US version.
Need to stock up on other tools.
But anyone would help me with my questions?
Hug that inside white line like it's your favourite granny! - Martin Brundle
RossoTorro is offline   Reply With Quote
Old 10-12-2009, 08:46 AM   #1037
Originally Posted by RossoTorro View Post
Hello, I am about to get me a CRC Gen X10.
What spur is in the kit? What pinion do i need?
I also see there are many different compounds of tires to choose from in color coding. Have no idea about what that means either, would much prefer them to be shore rating. Our track is medium traction carpet. Will the spec WGT tires do from Jaco?
Jaco World GT Spec Tire, Front (Lilac)
Jaco World GT Spec Tire, Rear (Lilac)
Have ordered 3 Protoform bodies, Corvette, Sophia and the Mulsanne.
For wheels you cant go wronge with WGT wheels on all four corners. They get good bite, and wear very well. As for the spur gear, I believe it was a 96T 64P gear. You will probably find that the gear will be the wronge size for your motor.
What type of motor/ESC are you going to be running?
Shawn.
Shawn68z is online now   Reply With Quote
Old 10-12-2009, 09:17 AM   #1038
liljohn1064's Avatar
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
Shawn.
+1 on the Lilac spec CRC Wheels and tires. Premounted and precut, they last forever. I have not worn one out completely yet. I did cut the rears to 2.1 and the fronts to 2.0 though just to drop some weight and lower the rotating mass. I like to keep the shoulder rounded about 1/8 to 3/8 inch to on the rears to keep from traction rolling when traction goes way up.
USVTA Rules http://www.usvintagetransam.com/
MRT Personal Transponders http://www.rclaps.com/
USVTA - WGT - F1 - 17.5 Sedan/RCGT
Just race.
liljohn1064 is offline   Reply With Quote
Old 10-13-2009, 09:19 AM   #1039
RossoTorro's Avatar
Shawn.
I'm going to run 13.5T or a simple 13T EzRun if i'm allowed to compete in F1/Group C class at our track.
The seller said the kit included a 105T spur, and i belive a 5 or 5.2 gear ratio is wanted. I have not found any gearchart on the car yet.
Old 10-14-2009, 01:52 PM   #1040
tim fry's Avatar
Hi all
What 1s lipo packs fit the GenX best and what tray are you using to hold them in place?
tim fry is offline   Reply With Quote
Old 10-14-2009, 04:25 PM   #1041
oops
wait a minute is offline   Reply With Quote
Old 10-14-2009, 09:10 PM   #1042
Still Bill's Avatar
Originally Posted by tim fry View Post
Hi all
ThunderPower 5000 1S pack fits in the Gen-X 10 solid plastic tray just fine. And I cut up the other slotted plastic tray and glued those remnants into the solid tray to hold the pack in place (front to back). The SMC 4900 should also be a winner.
Bill
Who will be the next Matt Francis?
Corally Φ and CRC Gen-X 10 guy
Still Bill is offline   Reply With Quote
Old 10-15-2009, 03:20 AM   #1043
Benzaah's Avatar
Trader Rating: 9 (91%+)
Im after some advice guys. Ive just picked one of these up second hand and im wondering what tools i will need to service this car. I have metric tools for my xray so ill need to get some imperial drivers and a socket for the diff maybe? And ill be running on a medium traction technical asphalt track with 2 cell lipo 17.5. Probably stick to the spec crc tyres as they are recommended a fair bit in this thread. Some advice on any spare and tuning parts id need to get. Want to keep it simple as im no A grade driver
A.E.R.C.C.C. #76
Xray★Tekin★Fantom★Thunderpower★KoPropo★Sorex
Benzaah is offline   Reply With Quote
Old 10-15-2009, 04:26 AM   #1044
nitrobeast's Avatar
Trader Rating: 22 (100%+)
Hi all
Im using the smc 4900 with the flat try. I tape the battery to the tray..works fine
Rui Goncalves
EB Mods|www.tqhobbies.com|Team Epic
Jackson RC|Horsham RC|Blue Diamond
Have you checked your droop today?
nitrobeast is offline   Reply With Quote
Old 10-15-2009, 05:22 AM   #1045
Hi all
You can use basically any 1s pack, Thunder Power, Epic (Trinity), SMC, or Reedy.
For Vegas what I did was remove the standoffs and the silver nuts that the top deck bolts to, and replaced them with CRC part# 13333 (2 packs). These are a shorter stand off that hold a 1s pack perfectly. Leave the foam on the bottom of the top deck. Also I used the stock Lipo tray that comes with the car, and attached the battery to the tray with 2 thin strips of servo tape. Between the servo tape and the lowered top deck, that battery is not going anywhere.
Hope this helps.
dumper
www.teamcrc.com, advanced electronics, www.teampowerpush.com, www.crcraceway.com, www.spektrumrc.com, www.dynamiterc.com, dumper's speedshop. moby graphics, G2 Designs - Check them out in the painting thread!
***2008 ROAR 1/12th Scale Stock National Champion*** Now what were the odds on that in Vegas? 38.4mm>38mm end of story.
dumper is offline   Reply With Quote
Old 10-15-2009, 04:26 PM   #1046
RossoTorro's Avatar
Originally Posted by Benzaah View Post
Im after some advice guys. Ive just picked one of these up second hand and im wondering what tools i will need to service this car. I have metric tools for my xray so ill need to get some imperial drivers and a socket for the diff maybe? Some advice on any spare and tuning parts id need to get. Want to keep it simple as im no A grade driver
+1 more
Old 10-16-2009, 01:08 PM   #1047
RossoTorro's Avatar
This thread is slow to get replies on, no one races the CRC Gen X10?
Where are good places to get spare parts?
Amainhobbies seems to have some, but lots missing. CRC website is hard to browese and almost no spares for X10.
I am missing CRC 1380 and the balljoints for it.
Seems i can't find them anywhere.
There was a option that i could buy but also out of stock.
Old 10-16-2009, 01:13 PM   #1048
Right from CRC! Or Horizon Hobby.
Just race.
Old 10-16-2009, 01:33 PM   #1049
NiMo's Avatar
I have not yet had a problem getting a part, not that I need many.
yes the CRC site is a little confusing, and so are others when they mix the 10th and 12th parts in the same list.
But i am here in England, and use sites in Holland, Hong Kong and 2 sites in America, Nexus and CRC, unfortunately anything that comes direct from America gets hit with a hefty customs and duty tax, so it at least doubles the price, yet Hong Kong and Holland is customs and tax free.
There is a supposed UK dealer (action model centre), but they always appear to have just sold out of the item you request, and can take many weeks to deliver (7 months for Corally tyres), and my local dealer is unable to get a response from CRC so he deals only in Associated and Xray pan cars, hence so many Associated cars at my track (no one likes the Xray).
http://www.aldershotmodelcarclub.net/ : Next club race meetings - February 7th / 21st
Classes run: EP Touring (10.5 / 13.5 / 17.5)
Pan Car : GT1 (1s 10.5) : GT2 (2s 17.5 / 4c 10.5) : GT3 (2s Saturn 20T)
GT1 - McKune Gen-X10 / 1s 10.5 : GT2 - Calandra Gen-X10 / 2s 17.5
NiMo is offline   Reply With Quote
Old 10-16-2009, 01:53 PM   #1050
Here is my setup from Vegas.
http://www.teamcrc.com/crc/downloads...ICsetupWGT.pdf
Any questions, feel free to ask.
dumper
Forum Jump
Powered By: vBulletin v3.7.6
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
