CRC 1/10 Pan Car
#886
#887
Try running the car with a softer motor and then show it off to the others.
Here in the UK (and more so at my local club) we found that running with mega power and speed looked spectacular and was a blast to drive on the straights, but new comers to the class could not find the patience to get used to the totally different style of driving, now that have been running a softer motors (1S Lipo 6.5 / 4cell 10.5 / 2S Lipo 17.5 / 2S Lipo HPI Saturn 20T (#1136)) we have found similar speeds and easier cars to drive, and more interest and cars competing.
#888
I do have a 10.5, 13.5 and 17.5. I went from 3.5r large track to running the 10.5 which was cool and was even considering dropping to the 17.5. I can give it a little more time and see if more people show interest on a carpet track over a large track but I am eager to get my tc5r up and running as well. I am in no hurry to sell it though.
#889
Interest is still growing here in England, and plans are now starting to get a National Champoinship going for next year.
There is plenty more to explore.
And if anyone is planning a visit to England, our track is about 30 miles from London Heathrow Airport, and about 40 miles from Central London, and the track surface has good grip (in the dry).
#893
Well my tc5r just arrived and wanted to share my joy as this is only my second rc kit to play with. Picked it up for $260 with everything pictured from a racer up north with extra TC5F chassis and upper deck if I ever wanted a TC5F setup.
extra parts that came with this package:
Currently on car.
ITF chassis (near mint)
ITF upper deck ( mint)
Reinforced kydex bumper protector
RPM heavy duty ball cups (my personal favorite)
6deg hard castor blocks
0deg stock rear hub carriers
Hard steering blocks
Hard front arms
Hard rear arms
Slipper spool
Acer Ceramic diff balls (super smooth)
Complete set of new bearing (one race day on them)
Rick Howart '08 IFMAR Worlds set up.
EXTRAS:
1 painted Mazda Speed 6 body
1 painted Stratus 2.0 body
TC5F chassis (slightly thicker than ITF chassis) ( mint. No scratches)
TC5F upper deck (Slightly thicker than ITF chassis) ( new)
Front Oneway with pulley (new, never used)
Solid spool (as opposed to the slipper spool that's on the car) used.
0.5deg Hard rear hubs
0.5deg standard rear hubs
0deg Hard rear hubs
6deg standard caster blocks
New Steering blocks standard
Used hard steering blocks
2 sets 4deg hard castor blocks
4deg standard castor blocks
Graphite Battery brace and post and hardware
1 complete sets of roll center blocks used ( #1, #2, and #3's)
1 new complete sets of roll center blocks ( #1, #2, and #3's)
10 new associated ball cups (still on parts tree)
New Rear Arms (stock)
New Front Arms (stock)
Used front arms (stock) (still in excellent condition)
Complete set of wheel bearings used
Front roll bar silver (medium)
Rear roll bar black (soft)
T-nut and diff bolt from tc3 (new and installed. More heavy duty than stock tc5 t-nut)
4 sets new in package Drive shaft protectors
New set of diff rings (still in package)
Shock foam (new in package)
New Complete set of servo arms (will work on almost any servo on the market)
New set of #1, #2 and #3 associated pistons (still in package)
Associated blue springs (front)
Associated silver springs (rear)
Currently on car.
Hard front arms
Hard rear arms
Slipper spool
EXTRAS:
0deg Hard rear hubs
#894
Espresso-a-go-go...........not
Wow! Good deal!
OK, enough with the TC cars kiddo...back to pan car business...
#895
Tire diameter and roll out
Guys,
I have bought a Hobbywing combo to use with my CRC.
It is a Xerun 120A with a 8.5T motor.
I have bought some pairs of CRC front and rear tires, the question is how much I have to take from the tire diameter and how can I set the roll out correctly.
#896
Someone knows how the CRC rear sidesprings are rated?
#897
What we need is for a pan car to be forced into a TC class and clean up on 'em, then there would be interest!
PM me when/if you typically practice @ OCRC, when I get rolling I will be needing more of that than racing.
#898
Don't sell the pan car, prolly more will show when racing gets up and going.
1s LiPo with 6.5 BL, 4cell NiMh with 10.5 BL, 2s LiPo with 17.5 BL.
And if you get enough interest then an LMP class with 7.4v max, no motor limit and max 235mm width.
Who needs Touring classes?
#899
Just keep running the pan car during all practice's, many will see and start wanting.
You can't ignore it's coolness, speed and price
That's what is happening at my track
#900
Hi folks! need a suggestion: just finished the car with new esc and motor,i'll use it outdoor on nitro tracks (everything is nitro over here!) but i'm a little confused about a proper gear ratio to start from.This is my set up:novak 7,5L/SpeedPassion GT2.0 LPF/trackpower 4900 2SLipo.
I'm a total noob about rollout measurements,and thought it would be better to use 48pitch gears outdoors,so wich pinion & spur gear do you guys reccomend me to start with?
Is there any kind of lexan/plastic spur gear cover in the market?
Where can i find cap tires? Are these any good in rain ?
Thanks!
Thanks!
