Old 05-19-2009, 08:36 AM   #856
NiMo's Avatar
Originally Posted by markf3x View Post
I race the Losi sedan and happen to know the wire thickness of the 10mm springs. Just get out some calipers..
12.5lb= .047 inches = 1.1938mm
15lb = .052 inches = 1.3208mm
17.5 = .054 inches = 1.3716mm
20 lb = .056 inches = 1.4224mm
25 lb = .060 inches = 1.524mm
There's more, but I don't happen to know them, since I don't use them on my sedan.
Just to help us Europeans
NiMo is offline   Reply With Quote
Old 05-19-2009, 04:49 PM   #857
rack's Avatar
Trader Rating: 64 (100%+)
I am setting up my gen x 10 I will be running 17.5 hacker lrp spx at setting 8 I have 100t spur and 2.160inch rear tires . So what would be a good pinion to start with for a med size track.
rack is offline   Reply With Quote
Old 05-19-2009, 07:16 PM   #858
Still Bill's Avatar
What battery?
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 05-19-2009, 08:18 PM   #859
rack's Avatar
smc 5200 40c 7.4v
Old 05-19-2009, 08:27 PM   #860
Still Bill's Avatar
Originally Posted by AndyBird View Post
Does anyone know the lb value of the middle shock spring as I want to soften the rear of the car.
Was going to use and associated blue (17.5) but could do with knowing what the current one is please
Mine came with the Losi 25 lb spring too. Currently using an Xray 07 shock with the Associated Blue spring (17.5) for asphalt racing.
A little Losi label came in the bag for the spring that confirmed "25" lb.
Bill
Old 05-19-2009, 09:20 PM   #861
Still Bill's Avatar
smc 5200 40c 7.4v
I am using a 33T pinion for a longer asphalt track with 2.2" rears. Sounds like you would be a similar pinion with 2.1" rears on a medium asphalt track (maybe 32T on med carpet).
Did you do anything with the timing of the Hacker 17.5? Mine remains untouched at their stock setting.
Old 05-19-2009, 09:26 PM   #862
You might want to find a really small spur gear. Say around 72 tooth. It should allow you more options for the pinion size.
I have only run 13.5, and 10.5's, but I would start around a 55mm roll out, and work up from there based on temperatures. (150F is ideal). Which would be a 33 tooth pinion.
Highly recommend 48 pitch gears! they are more stout then 64P.
Shawn.
Shawn68z is offline   Reply With Quote
Old 05-19-2009, 09:28 PM   #863
Still Bill's Avatar
Not sure if we posted this before; but, I initially had issues with the Losi shock that came in the kit. It was not very smooth in its initial action (specifically its first 1/8" of travel).
Someone told me to clean up the flashing on the piston and things would improve. It was recommended to mount the piston on my Dremel and clean it up using fine sandpaper. That took care of it.
Regardless, I still switched to an Xray shock with Associated springs. Even though I had not used either part before.
Bill
Old 05-19-2009, 09:30 PM   #864
Bill
Mine came with a 30lb. (had a 30 sticker in the bag, thought it was for the shock fluid.) Currently running a 20Lb Xray spring.
I think I am going to buy a set of the Windtunnel Barrel main springs though. I think the dual rate of the springs might be the key to good bite out of the corner, but without making the car overly soft.
Shawn.
Old 05-19-2009, 09:37 PM   #865
Still Bill's Avatar
Shawn.
I did get a complete set of their barrel springs some time ago; but, have not tested them yet.
Will be interested to see what you think.
Bill
Old 05-19-2009, 11:54 PM   #866
rack's Avatar
thank you bill
Old 05-20-2009, 04:51 AM   #867
I've got a spare xray 08 shock i'll give that a wirl as the losi one has a lot of play where the screw goes through it.
Just curious how many of you guys are xray TC Drivers as well
Andy Bird
Race Opt MST T^2 , RGT PRO G2 , Xray T4, Xray X10 2015, XB4
Team Driver (Team Powers HK), RaceOpt , RCHalt
Team Driver (Team Powers UK)
RcDisco Team Driver
AndyBird is offline   Reply With Quote
Old 05-20-2009, 05:20 AM   #868
rack's Avatar
I have a 008 xray tc and I love it and a serpend 1/12 both are good cars.
Old 05-21-2009, 11:50 AM   #869
NiMo's Avatar
got a chance to test with the 17.5 2S today.
Gearing was a real surprise.
Tried to run with the gearing I ran on with the 20T Saturn motor and it just did not feel right, so I geared down 3t on pinion and it had something but was still wrong, so went 3t the other way and it felt flat, so i decided to really drop the gearing.
So running 59mm rears, I have dropped from 28/90 to 23/100, and there i was thinking I needed to gear up for a Brushless?
Just need to see how it performs in traffic
Old 05-26-2009, 10:31 PM   #870
espresso1967's Avatar
Trader Rating: 18 (100%+)
Looks like my CRC is going to see some carpet action, new track in town.
Thanks to Joel Navarro (Radio Control Car Action Contributing Editor - www.rccaraction.com) for the video.
OCRC Onroad Racing
+ YouTube Video
www.cityofangelstshirts.com
espresso1967 is offline   Reply With Quote
