Old 05-13-2009, 03:25 AM   #841
espresso1967's Avatar
Trader Rating: 18 (100%+)
Call Crc for a replacement. It is a known issue. They have new ones in stock that will not come loose.
[/I]
Originally Posted by tudor_47 View Post
hi!
A friend had his adjuster threads came loose from the rear axle shaft during assembly! tightning by hand only! now the diff is loose. Is there a replacement diff axle? Can he use an axle from other brand of pan-car? It is now glued back in, but still it feels unsafe that it comes loose so easily.
Any good fixes out there?
Thanks!
/Johnny
www.cityofangelstshirts.com
espresso1967 is offline   Reply With Quote
Old 05-13-2009, 04:54 AM   #842
s13evo's Avatar
Originally Posted by espresso1967 View Post
I have tried the lola, p905b, corvette and just painted up a Mulsanne for tomorrow and see how that handles.
any pics and video soon?
s13evo is offline   Reply With Quote
Old 05-13-2009, 01:19 PM   #843
I would have had a good video but the guy that I asked to do a video never hit record
New Mulsanne
Old pics
Old 05-13-2009, 02:00 PM   #844
tudor_47's Avatar
Thumbs up
Nice work with the Mulsanne body!
I hope it drives as good as it looks!
I will contact CRC for a replacement! Thanks!
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 05-13-2009, 04:14 PM   #845
JayL's Avatar
I had heard some guys are running the irs axle...anyone have a part #? bill....
espresso: nice! I like the body and your colors
JayL is offline   Reply With Quote
Old 05-13-2009, 06:15 PM   #846
s13evo's Avatar
wow i want to get one muslane body now but dont want to go back too 200mm. man i wish there were more 235mm bodys out there.
very nice tho.
Old 05-13-2009, 07:32 PM   #847
Originally Posted by AndyBird View Post
The bodyshells a BMW M3 200mm, probably not ideal to be fair but ordering a new one this week.
Whats shells would you recommend ?
Mulsanne, or Sophia would be my choices for 200mm.
I run a 935B Medium downforce body (235mm) , with extensions on the wing to give it more downforce in the rear, and better stability down the straight.
But if your problem is right as you exit a corner, or from a start, then aerodynamics havnt come into play yet. If your at speed when the problem happens, then it could be aero related.
Shawn.
Shawn68z is offline   Reply With Quote
Old 05-13-2009, 10:18 PM   #848
Still Bill's Avatar
What I did with Dave Irrgang at IRS was pretty convoluted because they didn't have the complete Gen-X 10 axle assembly available in their on-line ordering catalog at the time.
Dave had me order any complete axle assembly for $61.95 and then describe in the Special Instructions what I actually wanted as described below.
Ordered
"Item Ref. Price ea. Qty. Description
__________________________________________________ _________
irs2133 $61.95 1 1/10th Assoc. Style Axle Kit for Non-Offset Pod
Special Instructions:
Dave, Per our telephone telephone conversation
today, please switch the axle kit I ordered above
for the IRS2138 axle kit to fit my CRC Gen-X 10.
Many thanks. Bill"
It worked; so, what can I say. Otherwise, I recommend that you talk to Dave at IRS. Hopefully, the Gen-X 10 axle assembly in now shown in their offerings.
www.teamirsrc.com
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is online now   Reply With Quote
Old 05-14-2009, 12:52 AM   #849
the p905b works great for me on a large track but since I have been going to this smaller indoor track I had to go back to 200mm set as the turns are much sharper and the 235mm setup does not work for me. Now that I have the Mulsanne which ran well tonight next on my list is the Sophia. But I must say I have a lot more fun with 235 pro 10 style large track. Oh and I went from 3.5r to 10.5 for the small track so really feels different and getting use to it as well.
Shawn.
Old 05-16-2009, 09:28 AM   #850
thanks for the help guys got my car all sorted now handling great. Need a little front end grip now so now I will get a better shell..
We've also just started a 1/10 200mm Pan Car League 10.5 Motors with Lipo so if anyones intrested let me know.
Andy Bird
Race Opt MST T^2 , RGT PRO G2 , Xray T4, Xray X10 2015, XB4
Team Driver (Team Powers HK), RaceOpt , RCHalt
Team Driver (Team Powers UK)
RcDisco Team Driver
AndyBird is offline   Reply With Quote
Old 05-17-2009, 03:44 AM   #851
tomracing's Avatar
so what was the main solution to oversteer coming out of the corner?
Tom van den Brink
RC Crewchief - setup software for racers
tomracing is offline   Reply With Quote
Old 05-17-2009, 04:54 AM   #852
Well done a few things
1) re-aligned the centre football - Thats seems to have stopped the pull.
2) The Calandra spring (not sure what lb it is if anyone knows) slacken it off a lot and seems to now get the power down better. Could do with a longer spring and softer to give a better range of movement now
3) Purple springs on steering , lost a bit of steering so now looking to either changing shell (bmw one) to a proper on 1st. Then consider droping to the green springs (1 down)
4) re-balanced car and move weights around.
Thats pretty much it.
I'll fill in a setup sheet might be an idea for us all to post them help each other out and bounce ideas across.
Andy Bird
RcDisco Team Driver
Old 05-19-2009, 02:41 AM   #853
Does anyone know the lb value of the middle shock spring as I want to soften the rear of the car.
Was going to use and associated blue (17.5) but could do with knowing what the current one is please
Andy Bird
RcDisco Team Driver
Old 05-19-2009, 02:59 AM   #854
If you are talking about the rate on the Losi JRX-S center spring on the Gen X 10, the one I got had a sticker on it with 25 rate but someone on here mention theirs came with a 30 rate spring.
This is the one that came with my kit.
http://www.amainhobbies.com/product_...ducts_id/22127
Old 05-19-2009, 09:02 AM   #855
markf3x's Avatar
I race the Losi sedan and happen to know the wire thickness of the 10mm springs. Just get out some calipers..
12.5lb= .047 inches
15lb = .052 inches
17.5 = .054 inches
20 lb = .056 inches
25 lb = .060 inches
There's more, but I don't happen to know them, since I don't use them on my sedan.
markf3x is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Still Bill
