Then, just go to A-Main Hobbies in Chico. The owner, Kendall, has a Gen-X 10 and is pretty fast with it. They have a wonderful carpet track at their warehouse too. And they don't charge racers to run on it...Wow!
Being a major mail order house, they also have the most complete r/c inventory in all of NorCal.
Should be in your neighborhood.
Bill
Funny you should mention that...that is the indoor track I was talking about! Did I mention that I work there???
The problem, is no one at the shop has run their GenX with a 13.5. Kendall suggested that I get the 17.5, and I might at some point...but for now, I want stupid fast
If someone could just give me a number to shoot for as far as rollout...a ballpark...anything? I was talking to one of the guys there about it today, and he said that the 110 spur may be a little big, and I might not be able to get a proper mesh...he suggested I drop down to a 100.
EDIT: BTW, TIA meant Thanks in Advance...lmao
I live with fear everyday....sometimes she lets me race!!!!
No idea about what you need, but ...
I run outdoors with a 155ft main straight, run 2S LiPo and Sealed HPI Saturn 20T (#1136), and for my track the roll out is 59.5 to 60.
I also run a 90T spur with 26T - 29T pinions (64dp)
http://www.aldershotmodelcarclub.net/ : Next club race meetings - November 22nd / 29th
Classes run: EP Touring (10.5 / 13.5 / 17.5), Pan Car (2s 17.5 / 4c 10.5 / 2s Saturn 20T)
I use a 13.5 with a 78 spur and 23 to 26 tooth pinion depending on the size of the tire and temp of the motor for a rollout around 55
I want stupid fast
The faster guys all use a 10.5 with a roll out around 49 to 50
I agree with using a 98 or 100 spur for 13.5 or 17.5 motors. I alternate between these two spurs to get gearing where I want it. Suggest using Kimbrough gears because they are wider and can handle the power of the 13.5.
Initially had a 13.5 motor in my car and gearing was easy to determine (with a Sphere 07 ESC) after a few shakedown runs. Just kept checking motor temps after 2-3 minute runs. For the life of me, I cannot remember what I ended up with because 17.5 motors quickly became the standard for 2S lipos around here.
Too bad you have to "work" there...No point in traveling...
Bill
Who will be the next Matt Francis?
nice video light, does that track use traction additive on the track for more grip. its seems all the cars are on rails.
We use soda pop syrup and water mixed. It only takes one coat sprayed on to a clean surface. So we have a leaf blower go over the track 1st to get rid of the dust.
Funny you post this liink. From time to time I go through my old links and was watching this video last night. Good racing!
So what has been the turn out for pan cars lately? Do you see it growing, steady or the same?
Our out door is starting up on April 26th so we expect at least 12 to a max of 18 club pan cars. We did travel to a few away races and it seems we are the only club who has a lot of these cars.
We also will be holding our annual club race Speed Weekend on July 11/12 were there will be good turn out of cars. well worth the trip if you can make it up.
Traction Roll: glue up your sidewalls and don't use traction compound across the whole front tire - maybe 1/2 or 1/3 to avoid the traction rolls... shorter cut tires help a lot too.
Im new to pan cars so this might be a stupid question but i dont know the answer..Whats the 3.14??
Rui Goncalves
Jackson RC--Horsham RC--Blue Diamond--
Have you checked your droop today?
