Old 12-03-2008, 07:54 AM   #526
Trader Rating: 14 (100%+)
Hey tfirsching do you have links to the stiffener plate (p/n 1785)and the wide body mount plates (p/n 1771). I searched CRC's website and could not find them.
rushrush1 is offline   Reply With Quote
Old 12-03-2008, 02:51 PM   #527
Dasmopar's Avatar
Send a message via AIM to Dasmopar
Motor? Battery location? Gearing?
Thanks for the set up. I will try and get mine up here next week after I run it.
Dasmopar is offline   Reply With Quote
Old 12-03-2008, 03:11 PM   #528
I guess those parts are not on the website yet. They were just released, and should be on the website in the next few days.
My battery was all the way forward. I ran a Putnam tuned trinity duo with a 2.60 rollout.
Gotta thank wait a minute woods for the motor, I went to the race planning to buy my motors and there were no 13.5's available. Woods let me borrow that motor and I ran it in both classes. It was dialed. Thanks woodsy!
Team CRC - Spektrum - CRC Raceway
tfirsching is offline   Reply With Quote
Old 12-04-2008, 06:30 PM   #529
wvince's Avatar
Location: Tupperville, Ontario, CANADA - like tupperware but with a population of 450.
The Champs was my first big race with the GenX10. With a motor and body that I've never used before in this car, a 5th place finish in the A was very pleasing. The car drove easy and felt stable. My setup was similar to Tom's with the exception of 1 spring rate higher all around and slightly thicker oil in the damper tubes.
I am more than happy with the car.
www.gsrhobbies.com
hudy
Novak
CRC
wvince is offline   Reply With Quote
Old 12-05-2008, 12:38 PM   #530
i think i forgot to tell u tommy there was a rental charge by the lap on it. i guess i will have to collect it another time.
wait a minute is offline   Reply With Quote
Old 12-05-2008, 09:06 PM   #531
Still Bill's Avatar
The new wide body mount plates (p/n 1771) are now on CRC website for ordering.
No stiffener plate yet.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 12-05-2008, 10:16 PM   #532
The stiffener plates were at the hobby store in Cleveland for the champs. I can't think of the part number off the top of my head right now (1785 I think. I will confirm this weekend.) But they do exist, because I packed them I will make sure that they are the website next week. You can call and order them.....
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 12-06-2008, 02:13 PM   #533
Bill
Hi Gang,
Both are now on the site and in stock.
Thanks!
Frank
Team CRC is offline   Reply With Quote
Old 12-06-2008, 05:18 PM   #534
Still Bill's Avatar
Originally Posted by Team CRC View Post
Hi Gang,
Thanks!
Frank
Thanks Frank.
Just remind John to add the stiffener to my order for the extension plates.
Pleeeeeeeeeeeeze..LOL
Bill Deras
Old 12-07-2008, 09:54 AM   #535
I picked one of these cars used and I need to know what the stock center spring rate is.Also are the springs the same as the Losi JRX-S type R springs shock springs. Thanks Dave.
Dave Walton is offline   Reply With Quote
Old 12-07-2008, 10:58 AM   #536
alan1467's Avatar
Having problems with my diff. I fitted 3 bevel washers to help but it has not. even if i have it very tight (can not turn nut any more) the diff still slips!!!!
Have i got soemthing built wrong? If I release the nut 1/4 turn it slips really bad!!!
Alan
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
Old 12-07-2008, 01:33 PM   #537
Still Bill's Avatar
The rate for the spring that comes with the kit is 30#. Looks to be the same as those used in my old JRX-S.
CRC is stocking Losi shock parts. You might be able to get a selection of individual Losi center springs with different rates from them.
Old 12-07-2008, 01:47 PM   #538
Still Bill's Avatar
Alan
Alan,
If not already done, upgrade from the standard 8-ball spur gear to a 12-ball one. The extra 4 balls helps.
Also, consider changing the plastic axle locknut over to an aluminum one. I get better consistency with my adjustments with the aluminum ones.
Bill
Old 12-07-2008, 02:11 PM   #539
alan1467's Avatar
Alan,
Bill
Hi Bill
Thanks, already using an alloy nut but only 8 balls, It just appears that I have no fine adjustment. It's either lots of slip or a little and the nut is locked solid with no more adjustment. this make me think I have something wrong somewhere
Tamiya TRF - Tekin
Old 12-07-2008, 04:27 PM   #540
Jin
hey guys almost done with my gen 10 and need help on motor choice. i will be running 7.4 lipo and was wondering is the 17.5 fast enough on a large outdoor track or is the 13.5 just too much for the gen 10 to handle?
thanks in advance.
Jin is offline   Reply With Quote
