Old 10-21-2008, 06:42 AM   #436
johnnywhopper's Avatar
Originally Posted by Still Bill View Post
Are the 5/16" long allen screws (tweak) in the rear of the car long enough? I like being able to position the tweak springs closer to the bottom plate to get initial contact going all the time. Seems like these screws should be about 1/2" long. Thoughts? Thanks.
the problem with our side spring holders is that they do leave some room for varience between builders and how far the set screws get threaded into the spring holder. I've noticed before that most people thread them in until flush with the bottom of the holder. I only thread mine in about half way, or "flush" with the step between the smooth metal and the teeth for the spring. Just make sure to use thread lock when building them like this.
I normally run 1 - 2 turns of preload on my springs, and this method gives me enough length to do so.
John
Team CRC, Spektrum, Hobbywing, JDJ Vinyl Graphics, Moby Graphix, Black Art, Power Push
johnnywhopper is offline   Reply With Quote
Old 10-21-2008, 07:02 AM   #437
Still Bill's Avatar
Thanks for that detailed description. With how my car is built, I have NO potential for pre-loading the side springs. Hmmm....Need to look at it again...LOL
Sure enough the eyelet on the end of the Losi shock was only screwed onto the shaft half-way. That's perfect now.
Thanks John.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 10-21-2008, 08:08 AM   #438
cdee's Avatar
gen x-10 racers.... I am a bit new to the pan car scene and have not posted here before, but in skimming thru the thread there seems to be some discussion on the front bumper. Take a look at this, http://www.manutech.info/151101specs.html, I do still double it up with foam. I have run it two week-ends now at a track with wood 2x4 barriers, and it has held up quite nicely.... thanks cdee
cdee is offline   Reply With Quote
Old 10-21-2008, 08:21 AM   #439
FOXY923's Avatar
I'll be running on carpet with a novak 17.5 powered by an Orion 2400 lipo. What gearing/rollout should I start with? Thanks
Paris Junction Hobbies ~ RROL.ca ~ Lou's Speedway ~ SCAR
XRAY X10 Link ~ CVTA Sakura Zero S ~ XRAY X10 Custom Oval ~ Caster Fusion F18
RACE 4FUN
FOXY923 is offline   Reply With Quote
Old 10-21-2008, 03:07 PM   #440
ffactory666's Avatar
Trader Rating: 19 (100%+)
Guys i need some info .
I will be using the car for a 2 cell world speed run car and require batteries with at least 25c rating or more . I will be using the Orion Vortex 2.5t motor , a 200 amp esc and obviously gear as high as i can so the battery needs to be able to handle the amps .
I am looking at the SMC 28c 4000mah or 5000mah battery will one of these this fit ? . I would still like to know what the dimensions of the battery tray in this car is and how tall a battery i can fit in there so i can check out other battery options as well.
Cheers
ffactory666 is offline   Reply With Quote
Old 10-21-2008, 03:53 PM   #441
s13evo's Avatar
Originally Posted by Psycho_ View Post
Here is my CRC Gen-X 10:
Winner of the first race in my city on this category.
Awesome car, good performance, slightly better than RC10R5...
Have a nice day...
what body is that??
s13evo is offline   Reply With Quote
Old 10-21-2008, 05:02 PM   #442
Taz_S's Avatar
Originally Posted by s13evo View Post
what body is that??
http://www.prolineracing.com/p-587-p905b.aspx
It is a 905B HD
jake as one in stock or T-bang a them in stock too.
Jake's Performance Hobbies http://www.jphracing.com/
https://www.facebook.com/groups/757500284356171 Facebook Group for Pro 10
Taz_S is online now   Reply With Quote
Old 10-22-2008, 03:36 PM   #443
FOXY923's Avatar
Anybody?
RACE 4FUN
Old 10-22-2008, 08:31 PM   #444
Still Bill's Avatar
Did the maiden voyage with my Gen X-10 today on the carpet at NorCal Hobbies today. Car with 13.5 Novak and lipo pack was initially very good until I found a few assembly issues to straighten out. Got those worked out and the car was pretty good in only its third run.
Fortunately, James Arluck arrived before my last run and gave me some excellent suggestions. Voila...the car is now a rocket ship...on carpet. Now, I just need to set it up for the Asphalt Regionals at Ripon this weekend. Got a good start.
Thanks James...and OD Purple...and Crashby for all your help along the way.
Old 10-22-2008, 09:18 PM   #445
MikeXray's Avatar
Trader Rating: 73 (100%+)
Do share I haven't put much time into mine on carpet yet, it's ok, but it feels like its turning radius and low speed steering are lacking. Its pretty good on power, but I have to lift more than I would think I needed to for slow corners.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 10-22-2008, 09:22 PM   #446
hanulec's Avatar
Trader Rating: 27 (100%+)
Hey Mike - What side springs are you running on the 'links' of your Gen-X 10? If you haven't tried the red ones yet you should. Moving to the red side link springs on my SpeedMerchant really turned that car around.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 10-24-2008, 08:27 AM   #447
MikeXray's Avatar
I've only used the white one that come with the kit, I'll have to pick up the set and try them.
Old 10-27-2008, 09:43 PM   #448
FOXY923's Avatar
RACE 4FUN
Old 10-30-2008, 04:49 PM   #449
s13evo's Avatar
hello, i need help on whats the recommended roleout or Spur/pinion combo for a brushed 19T motor for this car?
thanks
Old 10-31-2008, 06:11 AM   #450
FOXY - we haven't done much LiPo racing with these yet, mostly all 4 cell. In 4 cell 17.5, we roll out around 3.30". If you can't get a better answer from someone that has actually been running that setup, start out by gearing down 10 teeth from where we run in 4 cell and go from there.
s13evo - what kind of batteries are you running?
