Old 10-16-2008, 07:28 PM   #421
Still Bill's Avatar
Originally Posted by Darkseid View Post
Got the car built, wired up and finished. Impressions of the build:
-Waaaaay too many different hex head sizes required for my taste.. If I can build my Tamiya 4wd sedan with a 2mm driver for all the car screws and a 2.5mm driver just for the motor screws, theres no reason I should have to have 3-4 drivers and a super micro sized allen wrench around just to build a pan car.
-Couple missing items from my kit. One FH red screw for the rear pod and the lower rubber seal for the losi shock.
-More shims should have been included for the front wheels. Awful lot of play side to side there.
-I know that its not a traditional thing to do with pan cars, but the car really should come with the new foam bumper.
-Some of the screws didn't exactly thread perfectly into the aluminum parts. And because it aluminum into aluminum, your afraid to really crank them. This occured primarily when installing the top plate onto the rear alum motor mount, but also occured at other times.
-Where the heck were the set up instructions? The manual kept saying "just get it close, we'll set that later", but then you get to the end of the manual, and theres nothing there but the parts listing???
Other than that, it was a cool build. The diff was prefect without any ring sanding or any special tricks to smooth it out. Man, I need some of these bearings for my other cars. You can spin those front wheels and they'll just go forever. And the car looks amazing with the graphite pattern Jaco spec foams mounted up.
Overall, great looking kit, can't wait to get it out and try it.
Wow! A description of my build is nearly the same...including the one missing red screw...
Good job Darkseid...
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 10-16-2008, 08:41 PM   #422
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I run a Speedmerchant Formula 10 and am working with a fellow racer to help him get his CRC up and running well. The two cars are disimilar enough that I am not sure the set up info I apply to my SM will transfer to his CRC; especially for the front end. Does anyone have a set up for carpet with the Jaco Spec tires? I looked through the thread a bit to see if I could find one, but I don't frequent this thread much so I may have missed it. I read the set up on the last page with BSR pinks, but there was a lot of info about shims and such on the front end that I was unclear about. Maybe someone could translate it a little for me? Thanks!
Old 10-17-2008, 06:09 AM   #423
Regional Moderator
Darkseid's Avatar
Well I don't want to name names, but to be fair to "TF" (the person who packed my kit), the screw wasn't exactly missing, "TF" just substituted a red button head in place of a red FH. So "TF" didn't completely forget a screw, "TF" just got the wrong screw. So it wasn't completely bad for "TF".
But you know, I won't name names...its just not my style to do that to "TF".
TLR 22...Tamiya F104...
Old 10-17-2008, 09:51 AM   #424
Regional Moderator
Darkseid's Avatar
A look at my set up. The wiring is likely temporary. I almost never leave the first wire job on my car as the permanent lay out. I just wish that the 17.5 novak had the same 'wrap' around the sensor wire that some of their newer motors do.
Old 10-17-2008, 01:35 PM   #425
johnnywhopper's Avatar
World GT spec tires are now available from CRC! - http://www.teamcrc.com/crc/modules.p...category_id=71
Team CRC, Spektrum, Hobbywing, JDJ Vinyl Graphics, Moby Graphix, Black Art, Power Push
johnnywhopper is offline   Reply With Quote
Old 10-18-2008, 05:08 AM   #426
s13evo's Avatar
does anyone know if i can use NOVAK's 1/12th scale brushless motor gearing chart for the 1/10th DB10R?? or is the the 1/12th scale gearing totally different compared to 1/10th?
s13evo is offline   Reply With Quote
Old 10-18-2008, 08:34 PM   #427
Thumbs up Re...rollout
Go to Gear chart .com, create your own roll out chart....
THEBIGBULL is offline   Reply With Quote
Old 10-19-2008, 08:47 PM   #428
Still Bill's Avatar
I will be debuting my Gen-X 10 this coming weekend at the Region 12 Asphalt Regionals at Ripon Raceway. The car will be setup with a Novak 13.5 motor, SMC 5000 lipo, Alfa Sophia GT body and Jaco Purple/Pinks.
Does anyone have any initial setup suggestions for this package on asphalt? Currently, all springs installed are the stock ones that came with the Gen-X 10 kit.
I am particularly concerned about the stock spring on the Losi center shock. It appears to be too short for this application; and, easily gets cockeyed when the suspension unloads. Any suggestions?
Many thanks.
Old 10-20-2008, 12:36 AM   #429
s13evo's Avatar
which Spur/Pinion gear will you be running?
Old 10-20-2008, 06:36 AM   #430
Still Bill's Avatar
Starting with 29/98. Have tires cut to 56/58 too.
Old 10-20-2008, 06:39 AM   #431
Many thanks.
Hey Bill, the first thing i would do is to check your rear pod droop. you only want 1 - 2 mm of droop at the most. i believe, with the stock ball cups, the shock allows the pod to travel farther than that. you may want to thread the ball end farther up the shock shaft to reduce the droop and then the spring won't leave the cup as much.
I don't know if i can help you in regards to a good asphalt setup. i only have one race on the car on asphalt and that was with the 235mm kit, lipos, and a 4.5 motor.
for 200mm, on medium bite carpet, we haven't been changing that much on the stock setup. mainly, we swap the white and red springs, so white is in the front and red is in the rear, and we run max caster on the front end (shims all the way back). 4 cell pack all the way to the front, or in the middle for a little more steering. running it all the way back seems to make the car really aggresive and swings the rear end of the car around in the corner.
hope this helps...
John
Old 10-20-2008, 12:15 PM   #432
Here is my CRC Gen-X 10:
Winner of the first race in my city on this category.
Awesome car, good performance, slightly better than RC10R5...
Have a nice day...
ARC R11 - LRP Powered
Find RC news on: http://www.rcelectrico.es
Psycho_ is offline   Reply With Quote
Old 10-20-2008, 06:58 PM   #433
Still Bill's Avatar
John
John,
That's it! Headed out to the garage to change that right now...Be back in an hour for more asphalt setup ideas....Pleeeeeeeeze...
Old 10-20-2008, 07:01 PM   #434
Taz_S's Avatar
Have a nice day...
look great
Jake's Performance Hobbies http://www.jphracing.com/
https://www.facebook.com/groups/757500284356171 Facebook Group for Pro 10
Taz_S is offline   Reply With Quote
Old 10-20-2008, 08:46 PM   #435
Still Bill's Avatar
Default 5/16" tweak screws
Are the 5/16" long allen screws (tweak) in the rear of the car long enough? I like being able to position the tweak springs closer to the bottom plate to get initial contact going all the time. Seems like these screws should be about 1/2" long. Thoughts? Thanks.
