Old 11-02-2016, 01:39 PM   #4141
Still Bill's Avatar
Originally Posted by TeamThibault View Post
ok this might be a dumb question but how do you make a se into wgt-r? just add tires..do you have to do any thing else?
Go to the string on this website titled "Team CRC Gen X 10 R/T" and read Dumper's posts on two ways to convert your SE. One way costs about $10 while the other is about $40. Easy!
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 11-02-2016, 01:42 PM   #4142
Trader Rating: 44 (100%+)
Just adding the rubber tires to a WGT makes the ride height silly high. You need to either shim front suspension arms and rear aluminum side plates or shim the front arms and buy the WTF-1 aluminum side plates.
biz77 is offline   Reply With Quote
Old 11-02-2016, 02:16 PM   #4143
Just add 4 1.5mm shims on the 4 screws up front. On the rear pod add 4 1.5mm shims and you'll need 4 longer screws. Upfront I think I had 5 and 3 up front. Simple.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT Racing USA (17.5 foam), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 11-06-2016, 10:16 AM   #4144
Stuff Of Legend's Avatar
Thumbs up Rear toe-in
Hello
Normally with nitro/electric touring cars i just add toe-in to gain rear stability.
How do you guys go about gaining rear stability/rear side bite with the solid axle cars?
My problem is high speed stability going into a sweeper
My setup so far
Boosted 10.5t
Body-------------- http://www.team-titan.com.tw/product...php?code=60120
Tires---------------40f/25r
Compound-----0%f/100%r (car park track, I need the rear traction/side bite)
Ride f/r-----------treads flush hub/max
Springs f/r------Kit/white(also have a blue spring to try)
Pod droop------1mm(measured @ rear of main chassis)
Side springs-----kit/flush
Side links/oil/angle-----kit/kit/+1.5mm outside
Gearing----------69t/23t 48p
Front toe-out-----0' or as close as I can get it
Camber----------0-0.5'
Active caster--0'
Caster------------kit
Ackerman------+2.0mm forward
Bumpsteer-----0mm
Shock Angle-----+2.5mm rear
Shock oil/holes-----kit/kit
Dual Rate--------------54 or 55%
Wheelbase------------long
Last edited by Stuff Of Legend; 11-06-2016 at 10:32 AM. Reason: Dualrate/Wheelbase
Stuff Of Legend is offline   Reply With Quote
Old 11-07-2016, 01:33 PM   #4145
Trader Rating: 31 (100%+)
Originally Posted by Stuff Of Legend View Post
Hello
My setup so far
Boosted 10.5t
Active caster--0'
Bumpsteer-----0mm
Is there a reason you have 0% Compound on your front tires? IMO I would do 1/4-1/3 of the inside of the tire and try that. At high speed you may be powering through the initial steering, and when the wheel gets cranked too far it tosses the rear over.
CRC WGT SE-CRC WC 12th 17.5-CRC WC 12th 13.5
LSRCC.COM genesisrcraceway.com/
Race19s is offline   Reply With Quote
Old 11-08-2016, 05:18 AM   #4146
Ok I will give that a try.
My reasoning at the time was I am using 40f/25r tires,
An I needed more rear traction so I didn't add any to the front.
Old 11-08-2016, 08:07 AM   #4147
Its a Balancing act. If something up front is out of wack, it could cause the rear to step out. Compound is the Easiest thing to change and try.
Old 11-13-2016, 07:09 PM   #4148
It worked
Camber was actually 1.75*
Added a better wing (more downforce)
Went back to the kit spring to support the additional downforce, and all is well with the world
Old 11-14-2016, 05:34 AM   #4149
If you can find them, Associated made some #4 rear ride height pills. These put a standard CRC pod at 5.5mm ride height without spacers under the pod plates.
www.norcarracing.com
NORCAR @ The Gate
old_dude is offline   Reply With Quote
Old 11-22-2016, 02:44 PM   #4150
Some Setup's talk about value side springs 2.x
Anybody know value of these springs?
- Soft Side Spring (Blue)
- Medium Side Spring (White)
- Firm Side Spring (Red)
- X-Firm Side Spring (Green)
- XX-Firm Side Spring (Purple)
TyoBBS is offline   Reply With Quote
Old 11-22-2016, 07:29 PM   #4151
Still Bill's Avatar
Go to http://slapmastertools.com and check out Brian Bodine's spring chart.
Bill
Old 11-22-2016, 10:22 PM   #4152
Bill
Great. Thank you
Old 02-19-2017, 03:05 PM   #4153
JEFFs SC10's Avatar
Trader Rating: 14 (94%+)
Hey guys,
Wha'ts a good standard setup to go off of, for Black CRC carpet, high bite, technical.
I have a Gen X SE. First time running on foam from rubber tire and I really love it.
XRAY 2017 T4
CRC Gen X SE- 17.5 GT
Xray X12-17' GT12
support your local tracks- Beachline Raceway-386-Full Throttle Raceway
JEFFs SC10 is offline   Reply With Quote
Old 02-19-2017, 06:38 PM   #4154
Still Bill's Avatar
Originally Posted by JEFFs SC10 View Post
Hey guys,
Honestly, the best thing to do would be to review this entire thread from the time that the SE model came out...and, then ask questions. Especially focus on posts made by Dumper (Brian Wynn of CRC). Dumper was great about passing on his WGT setups after the major races he had attended...and likely won. Plus, his setups are very driveable too.
Others likely have used a foam tired SE on the new black carpet and can comment further. All of my foam experience is on the gray.
Bill
Old 02-20-2017, 06:03 AM   #4155
Hey guys,
Front: Mounted in Rear most holes on X plate
4MM plastic blocks
2.0mm Roll Center shims
.50(10th scale & pins)springs
5* caster blocks
2 shims back, 1 front.
.5mm toe out
1* neg camber(have run as much as 1.5*)
.5mm droop
51mm tire size(Start-run til gone, swap new ones adjust RH according) CA around outer edge
4.2mm RH
Rear:
AE Red center spring
.50 side springs
Kyosho 30k tubes
1.5mm pod droop
51.5mm rear tire(usually lasts 3 sets of fronts, adjust RH as wear)
4.35MM RH
Body-Protoform Gianna GT
This works until the grip is extremely high, then you'll need to remove camber as well as move the caster block shims forward. If you have other questions, feel free. Good luck!
