Old 04-13-2016, 05:39 AM   #4126
johnnywhopper's Avatar
Originally Posted by tazfam2 View Post
Can someone tell me how to make the x10 into a 235mm car going to run it on asphalt. Need help. Running with new crc rubber tires. Thanks in advance
If you have either the original Gen-X 10 Pro or the Gen-X 10LE, this kit will work for you - http://www.teamcrc.com/crc/modules.p...prodID=7719021
Direct bolt-on and ready to go racing!
That kit will also fit the Gen-X 10SE, HOWEVER... You may run into some durability issues on the front as this chassis does not have the 3rd mounting hole for each of the front end mounting plates like the original and LE chassis'. CRC does not offer a specific 235 mm kit for the SE car. To do it with proper strength, you would want to have a new 1-piece front end plate made for the SE chassis as CRC does not offer this.
Team CRC, Spektrum, Hobbywing, JDJ Vinyl Graphics, Moby Graphix, Black Art, Power Push
johnnywhopper is offline   Reply With Quote
Old 04-13-2016, 12:13 PM   #4127
Trader Rating: 42 (100%+)
Originally Posted by Race19s View Post
Nope, there are a few changes on mine.
Front: Mounted in Rear most holes on X plate
4MM plastic blocks
2.0mm Roll Center shims
.50(10th scale & pins)springs
5* caster blocks
2 shims back, 1 front.
.5mm toe out
1* neg camber(have run as much as 1.5*)
.5mm droop
51mm tire size(Start-run til gone, swap new ones adjust RH according) CA around outer edge
4.2mm RH
Rear:
AE Red center spring
.50 side springs
Kyosho 30k tubes
1.5mm pod droop
51.5mm rear tire(usually lasts 3 sets of fronts, adjust RH as wear)
4.35MM RH
Body-Protoform Gianna GT
Ok so if I interpret this correctly you are running an all around stiffer setup then stock.
Is this with the stock short front upper arms and no brace?
Does the 5* castor blocks generate better steering than the 10* for you?
How about the short front wheelbase, does that make the car turn in sharper?
Just curious and might try your exact setup just to see what it does.
I like a very responsive front end with minor steering wheel input.
Aaron
Aaron Moore
Serpent America/Desoto Racing, McFactory Motorsports, Team Trinity, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 04-15-2016, 06:29 AM   #4128
Trader Rating: 30 (100%+)
Yes to everything except the 10* blocks. Moving the X plate to the rear holes with 10* was too much for my liking, therefore the 5*. Only thing I forgot to list was I'm also running the shock in the 2nd hole from the rear above the battery. Give it a try and see how you like it.
CRC WGT SE-CRC WC 12th 17.5-CRC WC 12th 13.5
LSRCC.COM genesisrcraceway.com/
Race19s is offline   Reply With Quote
Old 07-24-2016, 10:36 AM   #4129
Stuff Of Legend's Avatar
Questions??
What's the standard rear shock oil cst?
Stuff Of Legend is offline   Reply With Quote
Old 07-24-2016, 10:39 AM   #4130
Questions??
Lol model genx 10 se
Old 07-24-2016, 01:33 PM   #4131
Still Bill's Avatar
30 wt...Always per Dumper
Still Bill is offline   Reply With Quote
Old 07-24-2016, 05:30 PM   #4132
Thumbs up
Ok thanks
Old 09-16-2016, 12:18 AM   #4133
corally's Avatar
Hello
after some time i buy a new SE...start to build..and surprise the rear pod plate have only teh two external hole...on old car have used the couple of hole placed inside..
Someone know if other plate are useful fro have two couple of hole?
corally is offline   Reply With Quote
Old 09-16-2016, 06:06 AM   #4134
What holes are you talking about? There is no need for a different bottom plate....
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 09-16-2016, 08:12 AM   #4135
corally's Avatar
Hello
on my old car the rear plate have two hole on "side wing" now only one...
CRC 1/10 Pan Car-crc.jpg
Old 09-16-2016, 08:15 AM   #4136
Ok, you are correct. The other holes are not needed on the SE, that is why we got rid of them......
Old 09-16-2016, 08:34 AM   #4137
corally's Avatar
I try on asphalt and feel better than the outer hole,i use short link to have a straigth link between pod and chassis..
As you know some plate of other CRC car are usable?
Old 09-16-2016, 09:31 AM   #4138
There is nothing that will work without a massive amount of work or alter the wheelbase.
Old 09-16-2016, 02:47 PM   #4139
Airwave's Avatar
Small question:
I'm considering CRC as the top pan-car-type chassis producer. Is there a hope that in the future you design a new pod articulation, with V-link? I'm using a such system on my Pro10, and the benefit is huge....
Thx
Airwave is offline   Reply With Quote
Old 11-02-2016, 12:59 PM   #4140
ok this might be a dumb question but how do you make a se into wgt-r? just add tires..do you have to do any thing else?
TeamThibault is offline   Reply With Quote
