Old 04-03-2016, 01:28 PM   #4111
I've been using the 1/10th kingpins and springs.Others have used the !/12th kingpins and springs. Your choice.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT Racing USA (17.5 foam), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 04-04-2016, 04:34 AM   #4112
I recently set my old Gen-X to the full narrow front setting (running rubber) and .50mm x 10mm springs. The car really responded steering wise. That was its last run on Fastrak carpet. This weekend we start running on the new Fastrak II so I start all over.
www.norcarracing.com
NORCAR @ The Gate
old_dude is offline   Reply With Quote
Old 04-04-2016, 04:38 AM   #4113
Trader Rating: 18 (100%+)
FYI i'm running 12th king pins and springs on my WGT
Originally Posted by Race19s View Post
I do 5 minutes on, then wipe, then a couple of minutes sitting before it goes on the track. Wiping before going out is the most important IMO, as the carpet wont soak it off the tires like the previous. I run full rear and 1/2-3/4 front.
With the new carpet your going to have to CA the outer edge of the front tires. Otherwise youll roll non stop.
this worked out pretty well for all of us. well i think all the pan guys glued the front tires. it helped my WGT from chattering around corners, allowing it to slide as it was. the 12th it helped with the car wanting to lift in hairpins. but the new carpet IMO is the shit for WGT. i've never had the perfect amount of steering in WGT. for the first time i really felt like it was a pan car the way it was wrapping around the corners
Destiny RX-10s | CRC XTI-WC | 2016 X1 F1 | SMC Totemic | Team Scream
phatboislim is offline   Reply With Quote
Old 04-04-2016, 06:27 AM   #4114
Trader Rating: 30 (100%+)
Glad it worked out for you, its nice to hear what works on my end is working for others! If you ever have other questions feel free.
CRC WGT SE-CRC WC 12th 17.5-CRC WC 12th 13.5
LSRCC.COM genesisrcraceway.com/
Race19s is offline   Reply With Quote
Old 04-04-2016, 06:31 AM   #4115
I think the 12th kingpins were the answer on the old carpet, for the new Ive been faster on the 10th pins/springs. I think with the combo of CA sidewalls the extra travel really helps the car rotate, again just my opinion.
Old 04-04-2016, 06:51 AM   #4116
Trader Rating: 42 (100%+)
You guys running stock setup on the new carpet?
I tried stock but with the long arm conversion and associated blue rear side springs.
Car traction rolled like crazy until I cut tires down to 52mm.
Then the car was driveable but the car didn't have enough mid corner steering.
This is with center 3/4 rear tires sauced and 1/4 front sauced.
I was afraid to sauce the front more so as to avoid traction rolling.
Ride height 4-4.3-4.5 front to rear.
Aaron Moore
Serpent America/Desoto Racing, McFactory Motorsports, Team Trinity, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 04-04-2016, 06:52 AM   #4117
I guess if i end up getting beat that bad i may try the 10th pins/springs combo. i'm kind of lazy/cheap with that respect. so i usually dont make changes unless getting my ass handed to me time and time again. sort of like what i did with my TC. but that's definitely in the back of my head now tho.
Old 04-04-2016, 06:57 AM   #4118
Ahh Aaron what's up man...i thought you were Jacob the whole time lmao. but i sauce my rears like Jacob mentioned....3/4 of the rears when it was called that it was 2 mins left in the main or qualifier before i got out there. i'd put my body and all on and right before i went out i'd do about 1/2 of the tire right down the middle of the front tire then i went out and ran. but yea i think your biggest issue was the height of the tire. i think those contact wheels have a bigger diameter wheel than the BSR...I THINK i'm going to check when i get home. but for optimal performance w/ WGT you have to cut them things down to AT LEAST 53mm. They last a long time TBH tho. i burn through my fronts faster than i do my rears. i'm on my 2nd set of fronts to the one set of rears i'm running.
tire diameter and ride height...crucial to rolling. keep your car at 4mm
my general setup is 12th scale king pins up front w/ 12th scale .45 springs, my side springs are purple and i'm running 10k lube. i dont even know what the droop on my pod is. i've never even checked it tbh. i just adjust the center shock to how much more steering i need. if you didnt have mid steering, you may need to check camber.
my board setup for my WGT is usually 0 toe and 1* camber unless i'm coning wheels bad and i'll just adjust camber to run the tires until they are completely done.
HOPEFULLY next i'm there i can run your car and see what you have. i didnt have much time yesterday
Old 04-04-2016, 10:26 AM   #4119
Nope, there are a few changes on mine.
Front: Mounted in Rear most holes on X plate
4MM plastic blocks
2.0mm Roll Center shims
.50(10th scale & pins)springs
5* caster blocks
2 shims back, 1 front.
.5mm toe out
1* neg camber(have run as much as 1.5*)
.5mm droop
51mm tire size(Start-run til gone, swap new ones adjust RH according) CA around outer edge
4.2mm RH
Rear:
AE Red center spring
.50 side springs
Kyosho 30k tubes
1.5mm pod droop
51.5mm rear tire(usually lasts 3 sets of fronts, adjust RH as wear)
4.35MM RH
Body-Protoform Gianna GT
Old 04-04-2016, 10:28 AM   #4120
Which Carpet do you have? If you have the new CRC black carpet if you true any bigger than 52mm rears youll traction roll. That said I start at 51.5mm r 51mm f. Youll use 2-3 sets of fronts to 1 set of rears. Just adjust ride height as you sway in the bigger fronts.
We addressed big tires on the new carpet awhile ago :P
Old 04-04-2016, 10:31 AM   #4121
Oh the only real change with the kingpins is travel. If you feel your car handles well then go with what works for you
Old 04-04-2016, 10:45 AM   #4122
Thanks again guys!
Aaron Moore
Old 04-04-2016, 11:46 AM   #4123
NP Aaron. I think i'm just missing speed/new motor so i doubt i'll work on mine as much as i did this weekend next time around so i'll have free time.
yea i agree...that's why i went w/ my exact same setup and no changes yesterday with WGT to see how the setup acts on the new carpet. i could have made the car work just as it was w/ my setup for the entire day. but the changes i made made the car work way easier. when the class continues to grow and guys get faster and i see that their cars are possibly handling better/faster, i'll probably look into working on setup changes. but other than tires, i'm using the same setup as at my home track
Old 04-04-2016, 06:13 PM   #4124
Whatever works for you. I've done both 1/12th and 1/10th I only use the CRC springs. you'll have to experiment with the tire sauce as I don't let it sit long before I wipe it off. Also experimenting with different bodys to see what works for me. For foam I like the HPI Porsche GT1 and the rubber the HPI C6 Vette. I've tired the protoform PF10 and Camaro Z28. I like the Z28 on Foam and waiting to try the PF10 on the new chassis. I did not like it before on either car. Have a Nissan Silva to try on Rubber. I won't have any results for a couple of weeks- till I return.
Old 04-13-2016, 03:15 AM   #4125
tazfam2's Avatar
Trader Rating: 39 (100%+)
Can someone tell me how to make the x10 into a 235mm car going to run it on asphalt. Need help. Running with new crc rubber tires. Thanks in advance
Xray x1 17 Xray t4 2017
T4 2017 tekno 48.3. Associated B6 B64
Leisure Hours Hobbies and Raceway
Fiercesolutions.com
Windy City RC raceway and hobby's
tazfam2 is offline   Reply With Quote
