Old 02-24-2016, 09:46 AM   #4081
Trader Rating: 42 (100%+)
Great advice thanks a lot!
Aaron Moore
Serpent America/Desoto Racing, McFactory Motorsports, Team Trinity, Pro-Line/Protoform, Hobbywing North America/FalconSEKIDO, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 02-24-2016, 10:47 AM   #4082
Trader Rating: 30 (100%+)
Anytime, whens your next event? Curious to see if it works for you.
CRC WGT SE-CRC WC 12th 17.5-CRC WC 12th 13.5
LSRCC.COM genesisrcraceway.com/
Race19s is offline   Reply With Quote
Old 03-18-2016, 10:23 AM   #4083
Sorry for the delay! Setup changes worked ok but the biggest factor was again saucing time. Car was pretty good in heats but tires started gumming in the non-sauces portion up front. So I sauced full front and that ruined the setup. Car was over steering and traction rolling in the heats. Going back to all stock setup and 1/2 front tire and full rear tire sauce total for ten minutes and go from there.
Aaron Moore
Old 03-18-2016, 11:24 AM   #4084
YoDog's Avatar
Trader Rating: 26 (100%+)
You may just need a little less camber up front. The lack of friction over the width of the tire may be causing the gumming problem. Still sauce 1/3 to 1/2 of the tires to get the initial grip then the overall grip should stabilize in a few laps.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 03-18-2016, 12:38 PM   #4085
Get yourself some ride height shims. They go between the caster block and the lower a frame. That will calm the camber gain that your getting mid corner. Also do you clean your tires? A little bit of motor spray and a rag before you sauce. Should eliminate the gumming you speak of. I personally sauce 1/2-3/4 of the front tire and have never had an issue.
http://www.amainhobbies.com/rc-cars-...ln3279/p243507
Old 03-24-2016, 07:27 AM   #4086
I'm looking at building a car for our local 21.5 Oval rubber tire 1s class. Was looking at the Gen-x SE with CRC rubber tires and also see they are coming out with a new rubber tire car shortly.
Would this make a decent oval car, I'd like to also be able to use it onroad not just oval. Should I wait for the new rubber tire specific car? Or a buddy says not to get these as I would not be competitive on the oval and need an oval specific chassis.
Back in the day I ran an Associated 10L and TRC Spec 10 cars on both oval/roadcourse and didn't feel any huge disadvantage
Any thoughts?
DougH is offline   Reply With Quote
Old 03-24-2016, 07:47 AM   #4087
Its about weight distribution. The SE car is designed with a center mass. Most oval cars are designed with a heavy left side distribution, as well side shock and spring combos vs dampening tubes the SE would have. Will it work for oval racing, Sure. Will it be anywhere near as fast as a purpose built car, IMO No.
Old 03-24-2016, 09:08 AM   #4088
There is a reason why the oval chassis is designed the way it is. The SE would work- sort of. But a real oval chassis would work 100% better on any given track.Go to and oval event and see what everyone is using. Also parts availablity locally.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT Racing USA (17.5 foam), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 03-24-2016, 09:40 AM   #4089
Trader Rating: 18 (100%+)
what bull said
Destiny RX-10s | CRC XTI-WC | 2016 X1 F1 | SMC Totemic | Team Scream
phatboislim is offline   Reply With Quote
Old 03-24-2016, 02:00 PM   #4090
1spunspur's Avatar
Hi DougH, obviously a LTO car works best for LTO. You can use a on road car on a LTO track with a good out come by adjusting weight and suspension. But if you take a LTO to an on road track it's difficult to have a good out come.
P./
1spunspur is offline   Reply With Quote
Old 03-30-2016, 07:32 PM   #4091
Thanks for the advice guys!
Ordered these and I also installed the long upper arm conversion.
Our track just got the new CRC hi grip carpet so I think all these changes will help make it able to drive into a turn as hard as I want but not traction roll or snap oversteer. I hope at least!
Aaron Moore
Old 03-30-2016, 07:58 PM   #4092
Still Bill's Avatar
Anti,
I have done either the long upper arms or the shims; but, never really needed both at the same time. Both together take away all your camber gain when the suspension moves.
Totally agree with YoDog. What degree(s) of front camber are you using? Excessive camber will lead to traction rolling when the traction comes up during the day.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 03-31-2016, 04:37 AM   #4093
i'm usually running only 1*..2 at most. If my tire is coning I'll then camber it as needed just to use the rest of the tire (i'm a cheap @$$) lol
Old 03-31-2016, 07:37 AM   #4094
With the new carpet your going to have to CA the outer edge of the front tires. Otherwise youll roll non stop.
Old 03-31-2016, 07:52 AM   #4095
Ok cool I'll start with 0.5 degree negative camber and glue the front sidewalls along with just the long arm conversion.
Aaron Moore
