Old 11-23-2015, 05:51 AM   #4021
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Originally Posted by Wedgeman View Post
Try 1 hinge shim fwd and 1 toe out for better cut in. Set 1.5mm rear droop, 50k tube lube, maybe 40wt oil. From Chang's 1/12 cheat sheet: "In general anything that stiffens rear end, adds steering". How is the diff adjusted to traction? I thought it just has to be very tight and very smooth.
Is it a good idea to try straightening a bent left clamp hub? Last crash tweaked it about 0.2mm, wondering if it will hold or has metal already gotten too weak..
I went up to 30k in the damper tubes and it helped. It's just odd as I run F1 cars including the WTF-1, 12th scale and WGT cars and all work great. I thought downforce wouldn't be an issue at these speeds, but it is. New body time.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 11-23-2015, 07:12 AM   #4022
I'm interested in building a crc pan car can someone tell me what hex drivers I'll need?
Plumcrzy is offline   Reply With Quote
Old 11-23-2015, 07:30 AM   #4023
hello, is there a way to use 2S 7.4v Shorty lipo packs in the GenX 10SE ? how to put the battery in place ?
coderzone77 is offline   Reply With Quote
Old 11-23-2015, 09:06 AM   #4024
Airwave's Avatar
Just use 26mm standoff and you're well
Airwave is offline   Reply With Quote
Old 11-23-2015, 09:16 AM   #4025
johnnywhopper's Avatar
.050", 1/16", 3/32", 2mm, and 2.5mm You will also use a very small .035" for assembling the damper tubes, but an "L" key comes with the kit that is sufficient and no need to have a "handled" wrench for this.
CRC P/N 1537 - 1" standoffs from the F1 kit meant for using that exact battery.
John
Team CRC, Spektrum, Hobbywing, JDJ Vinyl Graphics, Moby Graphix, Black Art, Power Push
johnnywhopper is offline   Reply With Quote
Old 12-09-2015, 08:31 AM   #4026
Thanks boys !
Old 12-09-2015, 09:47 AM   #4027
swerv512's Avatar
can the crc GenX-10 SE World GT car kit accept standard-sized 2s (not shorty) Lipos? If so, will i need any special parts?
swerv512 is offline   Reply With Quote
Old 02-04-2016, 06:51 AM   #4028
Stuff Of Legend's Avatar
Questions??
I have 2 questions after receiving my SE last week
1. I would like to know is there a problem if the servo splines are not center of the chassis?
2. Is it normal for the side tube balls to break during installation? I'm not pissed just annoyed
Why not just use the red balls that are all over the car
CRC 1/10 Pan Car-dsc_0457-1280x720.jpg   CRC 1/10 Pan Car-dsc_0403-1280x720.jpg
Stuff Of Legend is offline   Reply With Quote
Old 02-04-2016, 07:13 AM   #4029
Trader Rating: 18 (100%+)
anyone have any ideas on how to gain more steering? my WGT is pushing pretty tough. i switched out my caster from what i believe was 10* and now i'm running 0* and it's still pushing. i'm also running 12th scale .45 front spring. i range from 10k-22k on tube lube w/ white side springs. i run 1* camber and 1* toe out on each side. i kind of figured anything anymore aggressive than 1* toe out would be masking another issue that i have with my vehicle. anyone have any suggestions?
phatboislim is offline   Reply With Quote
Old 02-04-2016, 08:04 AM   #4030
how much tire additive are you using on front tires?
Liudas is offline   Reply With Quote
Old 02-04-2016, 08:18 AM   #4031
full front right before i come out generally. sometimes i'll let it sit like half a qualifier before i have to go out
Old 02-04-2016, 08:42 AM   #4032
Still Bill's Avatar
Hello Legend,
Your pictures are great and really helped me understand your issues.
1. I do not believe that the Savox unit is one of designated steering servos for the car. The location of its output shaft does not allow for centering of the output shaft in the chassis. I use either the JR3650 or KO PDS951 steering servos in all of my CRC pan cars for perfect alignment. But, I have seen some WGT cars successfully use non-centered servos by making minor adjustment to the steering output of their transmitters to handle the small difference in steering you will have going from left-to-right.
2. Aluminum ball studs won't thread into the carbon fiber; so, CRC uses smaller steel studs. I assume the small side tube ball stud was possible defective; so, contact John Firsching at CRC for a solution. He may be reached at john@teamcrc.com (or call). John is the best!
Glad to see that you are joining the WGT group. Great class!
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 02-04-2016, 08:45 AM   #4033
I assume you use strongest additive available.
I and other fast guys in our club let additive sit on tires from 10 to 20 minutes (First time up to 30 minutes - if tires were not used for a week or so). Most of the time 3/4 - sometimes full. Side walls are glued. Contact RC or BSR spec tires. Additive CS-High Grip or Spider Grip - Green.
Are your tires wearing flat?
Old 02-04-2016, 08:47 AM   #4034
Still Bill's Avatar
For what kind of surface?
On carpet, it usually varies from 3/4 to 1/2 of the front tire (from the inside to the outside).
On asphalt, it varies between full to 3/4 for most situations I have experienced.
Rear tires are always full coverage for both scenarios.
Bill
Old 02-04-2016, 08:48 AM   #4035
Wade....'s Avatar
Wade Huesman, TCORC Secretary/Pencil Pusher
Wade.... is offline   Reply With Quote
