Old 02-24-2015, 06:46 AM   #3991
Trader Rating: 30 (100%+)
LOL its all good. Ive never raced on asphalt so I'll leave those questions for someone who has.
Race19s is offline   Reply With Quote
Old 02-24-2015, 07:38 PM   #3992
Still Bill's Avatar
And that would be me...LOL
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 04-16-2015, 12:43 AM   #3993
Hi guys,
I run on asphalt since one year with my CRC Genx10.
I've converted it to 235mm with some custom modifications to let it run at 2S lipo and 4.0T star.
Set is the following:
Height: 5mm front and 5.5mm rear.
Drop: 1mm
Tyres: 30/34 rear and 37/40 sh front. (UFRA tyres)
Camber: 2.5
Caster static: maximum.
Caster dynamic: 0
Toe: -3.5
Body: BLITZ P908
fdr: 36mm
Side shocks: CRC encore with associated spring hard and 350 cst oil.
Center shock: Losi with 350 cst oil and standard spring.
Car is very fast (just a little bit slower than 1/8 track IC) and has a lot of traction. I use speedtech additive on all tyre's surface. Speed is around 110km/h.
RC_LMP1 is offline   Reply With Quote
Old 09-01-2015, 04:31 AM   #3994
Hi guys
I'm interesting to this model (SE), but there are so many opinions.
Someone in my country says that CRC is made for US tracks and motor with few Kv because it doesn't handle very well in the corners.
Others says is glued to the asphalt also with a 5.5T motor and large track.
So, where is the true ?
Is this a easy model to drive or not ?
maRRRco is offline   Reply With Quote
Old 09-01-2015, 04:35 AM   #3995
tdu verney's Avatar
Default CRC
This is a great car! I had a 13.5 in mine on carpet. Loved every minute of it! Only one way to find out?
tdu verney is offline   Reply With Quote
Old 09-01-2015, 04:55 AM   #3996
Yes but you refers to carpet and 13.5T motor.
Someone says it can't handle a 6.5T or 7.5T or 8.5T in large asphalt tracks, but other says the contrary. So I don't know how to think about that.
Old 09-01-2015, 08:11 AM   #3997
Still Bill's Avatar
Default Track prep matters...a lot
All depends on how well the asphalt track surface is prepared to handle the higher output of low wind motors.
Old 09-01-2015, 09:14 AM   #3998
Harold996tt's Avatar
Originally Posted by maRRRco View Post
Hi guys
Jmho...
I am predominantly a 1/8 ic driver. Experimented with this car with an irs and lajf 235mm conversion. Depends where you come from and what you want. I wanted an electric car that could run against the 1/8 ic cars. Put a 4.5 turn and 2s in. The car could not put the power down and ate spur gears no matter what adjustments I did. It was just too light for the torque and skipped all the way till the tires could finally find purchase.
Through chicanes it was better in 235mm form than 200mm but was still dead compared to my 1/8 car. And under steered like crazy (agin compared to my 1/8 gp). I ended up deciding to convert it back to 200mm and enjoying a higher turn motor at slower speeds with it though I have now converted to tri shock rear end and will see if that improves the responsiveness, and keep using my 1/8 ic car for all out speed and handling. Have since bought a true 235mm Vorlon and RC Devil and will try those. Note that I run on very fast 1/8 smooth tracks and not a tight track and the crc was in original form not meant for this sort of all out speed and all out handling compared with th tighter tracks in the U.S.
But in terms of design there is no more beautifully engineered 200mm car available than the crc.
Capricorn C802 1/8 GP, Mugen MGT7 1/8 GT.
Nostalgic collector of old Rc junk.
http://www.tamiyaclub.com/showroom.asp?id=44535
http://vintagerccar.blogspot.sg
Harold996tt is offline   Reply With Quote
Old 09-01-2015, 10:47 AM   #3999
YoDog's Avatar
Trader Rating: 26 (100%+)
If you are running on large 1/8 scale tracks, this is probably not the right choice for you. These cars were primarily developed for carpet racing. There are some manufacturers in Europe that specialize in running on these large tracks. It's not a matter of handling high Kv motors rather than applying the right design for the conditions.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 09-01-2015, 02:27 PM   #4000
Definitely. For example, the rear pod flexes far too much for the low turn motors given the relatively thin carbon used on the rear pod compared to heavy luminous for example on the Vorlon made for high speed, and the manner in which the motor mounts to the pod on the crc causes slip and movement on high torque motors... Which results in constant stripping of spur gears.
Old 09-04-2015, 11:43 AM   #4001
Nego's Avatar
Trader Rating: 72 (100%+)
questions guys,whats a good roll out for wgt track size 150x85 ?
Project X 1/10 pancar,17.5GT,BMI,yokomo,Associted F6.
Nego is offline   Reply With Quote
Old 09-10-2015, 05:43 PM   #4002
Still Bill's Avatar
To subscribe...again!
Old 09-11-2015, 01:10 AM   #4003
You can subscribe from the Thread Tools menu at the top of each page if you have been unsubscribed.
sparkyboy22 is offline   Reply With Quote
Old 09-25-2015, 06:55 PM   #4004
jiggen5354's Avatar
Questions??
Hi all. I just bought a Gen X10 SE and have a few questions. I have built the kit as per instructions and bolted on a new set of foams.
With new foams, it does not seem possible to achieve full steering lock without the tire touch the front bumper. Is this normal? I can see a few solutions being, true down the tires, trim the bumper or move front arms to the rear set of holes. Thought I should ask before I start chopping up the bumper.
Thanks in advance
CRC 1/10 Pan Car-1.jpg   CRC 1/10 Pan Car-2.jpg   CRC 1/10 Pan Car-3.jpg
jiggen5354 is offline   Reply With Quote
Old 09-25-2015, 07:40 PM   #4005
Still Bill's Avatar
Thanks in advance
Great pictures.
Yes, I always trim the foam part of the front bumper on both sides. Did not trim the carbon fiber. But, I also have my f/r tires trimmed down to the range of 51-54mm which adds clearance too.
Bill
