Old 02-17-2015, 03:08 PM   #3976
YoDog's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Teodoras View Post
Got my Goteck mini servo, but already faced a problem... servo's spline is 4.8mm diameter and it is too small for my servo saver. Servo has 25 teeth spline, but it is small enough to fit in to 23 teeth saver. Is there any adapters from 4.8mm to bigger? Or should I buy another servo? I'm budget tight, so I cannot afford these high end JR's, Futaba's and Hitec's
Hobby King has a nice mini servo for 1/12 - 1/10 pan cars. it really fast and holds center really well. The best part is that it's like $20 and uses a 25t spline. I have been testing one on my WGT and so far has been great!
http://hobbyking.com/hobbyking/store...ckStar%20servo
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 02-17-2015, 03:37 PM   #3977
Josh-n-ya's Avatar
Trader Rating: 73 (100%+)
Backordered.
Josh-n-ya is offline   Reply With Quote
Old 02-17-2015, 06:09 PM   #3978
YoDog's Avatar
Originally Posted by Josh-n-ya View Post
Backordered.
Unfortunately...yes. That just goes to show how good they are.
Old 02-22-2015, 06:41 AM   #3979
Hi all, I am going to get a CRC Gen-X10 SE
can I use shorty or full size 2S lipos ?
Or do I have to modify something to fit them ?
coderzone77 is offline   Reply With Quote
Old 02-22-2015, 10:23 AM   #3980
Send a message via Skype™ to asalk
Default Gearing for 13.5 blinky 1S?
Could someone recommend gearing for 13.5 blinky 1S?
I will use it in X-10 SE with Trinity Epic D3.5 on 30m x 15m carpet.
Thanks.
asalk is offline   Reply With Quote
Old 02-22-2015, 02:15 PM   #3981
WIITA's Avatar
Trader Rating: 42 (100%+)
Thanks.
Between 82mm and 86mm with 25* of timing and the HT rotor.
Team CRC / Sanwa / Team scream / Genesis RC / Hobbywing / TQ Wire / Schelle / MIP / RC^2 / TEKNO / BoomRC
WIITA is offline   Reply With Quote
Old 02-23-2015, 08:12 AM   #3982
tdu verney's Avatar
Default 13.5
I ran my 13.5 Fantom at 84 with just about the same timing, and rotor. You won't be disappointed... These are excellent motors.
tdu verney is offline   Reply With Quote
Old 02-23-2015, 09:20 AM   #3983
To what gear ratio this translates with 56mm wheels?
Old 02-23-2015, 10:38 AM   #3984
howardcano's Avatar
Trader Rating: 35 (100%+)
Gear Ratio = Tire Diameter * pi / Rollout
Fir 56mm tires and a rollout of 84mm, the ratio is 2.094.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 02-23-2015, 10:41 AM   #3985
Trader Rating: 30 (100%+)
80 spur 38 pinion with a 56mm tire.
Race19s is online now   Reply With Quote
Old 02-23-2015, 10:42 AM   #3986
Bigger question is why on earth you'd wanna run such big tires? On any kinda grip that car is going to traction roll like crazy.
Old 02-23-2015, 11:21 AM   #3987
howardcano's Avatar
2.20" is well within the usable range on low-traction asphalt, like a parking lot.
Howard Cano
Old 02-23-2015, 04:25 PM   #3988
WIITA's Avatar
I was suggesting this for carpet, not sure about asphalt. If running on carpet like originally stated, 56mm is way to big IMO. 52.5 would be a max start IMO.
Old 02-23-2015, 07:26 PM   #3989
He asked for a carpet setup
Old 02-23-2015, 11:39 PM   #3990
howardcano's Avatar
Yup, I should have read a little further. Call me "Mr. Short Attention Span".
P.S. I'll blame it on lack of sleep.
Howard Cano
