Old 01-01-2015, 03:35 PM   #3931
rcgen's Avatar
I am running a Gianna. It was my first time running the car Sunday. Body felt good but then again I have not ran the other two bodies. I ran a R5 with a protoform corvette body prior.
rcgen is offline   Reply With Quote
Old 01-01-2015, 04:20 PM   #3932
I go back and forth with the Sophie and the CRC. Right now I like the Sophie better. Try it out and see what you like.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT Racing USA (17.5 foam), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 01-01-2015, 04:48 PM   #3933
waltss2k's Avatar
What about the Ginna. How does it compare. Are WGT Bodies Like Touring Car Bodies Where One Gives More Front Bite One More Rear Bite And So on.
waltss2k is offline   Reply With Quote
Old 01-01-2015, 11:01 PM   #3934
Still Bill's Avatar
Originally Posted by waltss2k View Post
So which is the better body to run on the SE. I'm running a Sofia right now. Been thinking about the CRC WGT body.
Just get the other two bodies and decide for yourself. I keep all three around.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 01-02-2015, 03:29 AM   #3935
MarkBurgess's Avatar
The Pf Corvette is a great scale shell, but will tend to understeer on a World GT compared to Sophia, Gianna or the CRC/BlackArt shell.
MarkBurgess is offline   Reply With Quote
Old 01-02-2015, 03:55 AM   #3936
In my experience the Sophia is a well balanced shell for a World GT. By that I mean it has more steering than older shells like the Corvette, and has good rear end bite. If the car does get loose then it will tend to slide in a controllable way.
The Gianna by comparison has a lot more front bite. If you'd have to lift for a sweeper with the Sophia, then you might be able to take it with more throttle with the Gianna. That can come at a cost if the car is edgy, as any slide will be quick and harder to catch.
I've not run the CRC/Black Art shell, but have raced against it. It looks to give a lot of steering, and more rear end bite than the Gianna.
You will find different sets up and driving styles will suit one or the other. I've adjusted my car to run the Sophia on medium grip tracks, which works well for me
Old 01-02-2015, 08:11 AM   #3937
waltss2k's Avatar
Good info. Thanks guys
Old 01-04-2015, 12:20 PM   #3938
IgorR's Avatar
Hello,
I'm planning to drive my CRC gen X10 SE on carpet. I'm looking for the best position for the electronic. Should the ESC be the closest to the rear pod or the battery?
What is the difference in terms of feeling?
Yokomo YR-X12
Shepherd Velox EC
IgorR is offline   Reply With Quote
Old 01-04-2015, 01:28 PM   #3939
Still Bill's Avatar
Originally Posted by IgorR View Post
Hello,
Having the ESC next to the rear pod allows you to run the shortest wires possible to the motor; and, having the battery connections facing towards the rear in the chassis gives you the shortest wires to the ESC.
And with the 1S ESC at the back there is plenty of room for the receiver being placed next to it.
Cheers!
Bill
Old 01-05-2015, 01:14 PM   #3940
IgorR's Avatar
Cheers!
Bill
Thanks,
So it sounds like there is no effects on the car handling.
Yokomo YR-X12
Shepherd Velox EC
Old 01-05-2015, 08:09 PM   #3941
Still Bill's Avatar
Thanks,
Igor,
Sorry for not answering that...And I prefer the slightly heavier weight of the battery being in the forward position. Most CRC WGT cars I have seen in the US are in this configuration.
The other WGT placement issue is whether to have the servo in the old style standard position or reversed and forward. I definitely prefer the reversed and forward position as how the SE kit now comes standard. CRC wins again by giving us such options to play with!
Bill
Old 01-06-2015, 10:15 AM   #3942
IgorR's Avatar
Igor,
Bill
Thank you
Yokomo YR-X12
Shepherd Velox EC
Old 01-06-2015, 10:48 AM   #3943
waltss2k's Avatar
Cheers!
Bill
Hey Bill can you send me a pic of your chassis so I can see the placement of the electronics.
Old 01-06-2015, 09:49 PM   #3944
Still Bill's Avatar
Here are a few pics of my Carpet SE...First one details most of the motor/ESC/battery wiring.
Bill
CRC 1/10 Pan Car-se-002.jpg   CRC 1/10 Pan Car-se-003.jpg   CRC 1/10 Pan Car-se-005.jpg
Old 01-07-2015, 06:50 PM   #3945
jetnjme's Avatar
Default Shock question
My wgt is the x10, I have the big losi TC style rear shock which is ok for running outdoor asphalt but should I get the smaller one used on the current cars for indoor carpet? Or is it preference?
jetnjme is offline   Reply With Quote
