Old 12-25-2014, 11:04 AM   #3901
I have a different set-up. But yours will work just fine but you might need a softer center spring since we will try the spec tires all around for the Spec175GT. I'll have tires and everything else you might need with me. The Outlet should have the protoform Camaro in stock. If I get my new body painted I'll have a used Porsche GT1. You could try your car out tommorow at the outlet.
Other than that-call Superior for a body.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT Racing USA (17.5 foam), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 12-25-2014, 11:15 AM   #3902
Still Bill's Avatar
Originally Posted by rcgen View Post
Oh I looked back and looked at some of the posted pictures and noticed the links were inboard with the springs outboard. The opposite of the manually. What's the difference? Also, there is no graphite piece for the frontend that connects the two top arms.
The SE kit comes with CRC #3281 clamping side links that are 65mm long (C-to-C). These are the ones that attach at the forward hole position on the main chassis plate and are angled when connected to the rear pod plate. With these links the rear side springs are normally inboard.
To get the side links parallel and the springs to the outside, use the shorter CRC #3280 side links which were used on the original GX10 chassis. I believe these are either 54mm or 2-1/8" long (C-to-C).
All three of my WGT cars are setup to have the springs outboard. I consider this to be a minor improvement for most carpet situations; but, a significant improvement for asphalt.
Normally, I have a feeling that longer links can be a positive; but, placing the rear springs outboard is the more important change.
Of course, all of my experience is with pure WGT cars; but, I assume it should be positive for your spec racing too.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 12-25-2014, 11:35 AM   #3903
Originally Posted by wingracer View Post
It seems to mainly be a Florida class. They are running it at the birds this year. It's basically WGT but with 17.5s, a different body list (HPI vettes, 911s, Lexus ISF, Viper, Protoform Camaro, LFA, etc.) and a gear rule. It's pretty fun. I run it at Jeff's RC studio in Fort Meyers, FL. Looks like he's in Jacksonville so I guess he's running it up north somewhere.
rcgen, you coming to minnreg on the 11th?
I didn't see a 17.5 wgt class on the snowbirds web site?
Racer649 is offline   Reply With Quote
Old 12-25-2014, 11:51 AM   #3904
wingracer's Avatar
Trader Rating: 23 (100%+)
It's called Spec 17.5 GT. It's the expo class, last one on the list.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 12-25-2014, 12:05 PM   #3905
Thanks.
We just switched to 17.5 for wgt about track. Lots of fun. What spec rules do you guys use?
Old 12-25-2014, 12:20 PM   #3906
wingracer's Avatar
https://www.facebook.com/61061442564...type=1&theater
Team Shepherd USA
Old 12-25-2014, 11:30 PM   #3907
slowpoke68's Avatar
Trader Rating: 28 (100%+)
Default crc se
i donn't know if anybody tried to run a car in short wheel base configuration and narrow(196.34mm) but let me tell you it was interesting at the least. i got the car used from a local person that i thought it was set up ok but not. luckily i got the car working allot better by the main by widening the rear out to 201mm and lengthening the car to settle it down a little.looking for the next club race
coyote hobbies raceway,tq raceway,kenon hobby.apex speed shop
Airtronics m12s,hobbywing,schuur speed,associated b6 b5m t5m sc5m,mini z,ta05 v2,some rock crawlers,and still counting....
slowpoke68 is offline   Reply With Quote
Old 12-26-2014, 07:35 PM   #3908
Still Bill's Avatar
I agree that the longer wheelbase does settle the car down; but, I usually run a width of just under 200mm. Handling gets a tad lazy as it gets wider; and, something like a 198mm width provides good clearance with all of the available WGT bodies.
What body are you running?
Bill
Old 12-27-2014, 09:09 AM   #3909
waltss2k's Avatar
I got to run my Gen X10 SE last night for the first time, and it was amazing.
waltss2k is offline   Reply With Quote
Old 12-27-2014, 10:12 AM   #3910
rcgen's Avatar
Here's mine and almost ready to hit the track tomorrow. Just need to add a motor and receiver. It's basically set up per the book with 10* and long wheelbase.
CRC 1/10 Pan Car-image.jpg
rcgen is offline   Reply With Quote
Old 12-27-2014, 03:20 PM   #3911
Still Bill's Avatar
What ESC is that on the car?
What weight lube in the side tubes?
Going to run the front foam bumper? If so, use the #1760 Trimmed Foam Bumper and support it with at least two more of the #1262 short (1/2") standoff posts like you have in the center.
You are almost there...
Bill
Old 12-27-2014, 03:44 PM   #3912
Nego's Avatar
Trader Rating: 74 (100%+)
Question guys, i have 2 crc genx Le,i was thinking if i could change the rear pod to a SE?
if so could i get some help on parts number thanks.
Project X 1/10 pancar,17.5GT,BMI,yokomo,Associted F6.
Nego is offline   Reply With Quote
Old 12-27-2014, 04:23 PM   #3913
Still Bill's Avatar
The whole rear pod is offered as a conversion kit.
http://www.teamcrc.com/crc/modules.p...prodID=7719471
Bill
Old 12-27-2014, 04:33 PM   #3914
rcgen's Avatar
Bill
I am running a GTB. I used the lube that was included with the kit and foam bumper is now on. It will hit the track tomorrow morning. Bullfrog and maybe two other racers with CRC cars will be there for me to pick their brains.
Old 12-27-2014, 04:48 PM   #3915
Still Bill's Avatar
A Novak GTB only comes in a 2S version. Is that the battery to run for your Spec 17.5 GT class?
