Old 12-11-2014, 06:20 AM   #3871
rcgen's Avatar
First couple of races will be on carpet: FSEARA race and hopefully the Spec17.5GT class at the Snowbirds. After that mostly asphalt.
I have oval cars that use the CRC links and do the same to get them free.
I like the Shoe-goo underneath the servo.
rcgen is offline   Reply With Quote
Old 12-11-2014, 06:53 AM   #3872
Here at the factory, we are running our cars pretty stock.....
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 12-11-2014, 10:16 PM   #3873
slowpoke68's Avatar
Trader Rating: 28 (100%+)
Default tabs on axles
Originally Posted by Cancun Tom View Post
I noticed a tab of some kind on the end of the axles. Would they be some kind of quick mount for the front wheels? Also where to find them? Thanks
that looks like a 1/8 scale gas car with quick release wheels.i had that on my old mugen 1/8 scale car.hope this helps
coyote hobbies raceway,tq raceway,kenon hobby.apex speed shop
futaba 4px,hobbywing,schuur speed,associated b6 b5m t5m sc5m,mini z,ta05 v2,some rock crawlers,and still counting....
slowpoke68 is offline   Reply With Quote
Old 12-16-2014, 03:40 PM   #3874
YoDog's Avatar
Trader Rating: 26 (100%+)
You are correct sir... at the moment I only have the 1/8 nitro axles for this front end. I have a more conventional pan car front end in the works that is much simpler and lighter.
R-Factor RC Products
AE- TC6.1WC, TC6.2, RSD6, B5M
CRC- GenX10 WGT & Pro10 Prototype, WTF1, Xti 1/12
R-Factor RC- TC4-R, P8 PanCar
Not as Fast as I want to be but too old to Whine about it... 8-)
YoDog is offline   Reply With Quote
Old 12-17-2014, 03:29 PM   #3875
waltss2k's Avatar
I have a Gen X 10 SE on the way. Can't wait. I will be new to WGT but not to pan cars
waltss2k is offline   Reply With Quote
Old 12-17-2014, 03:53 PM   #3876
BadSign's Avatar
Trader Rating: 15 (100%+)
Good, mine will be ready by next Friday. That's 6-7 if we all show up at once.
This is the day the Lord has made, I will rejoice and be glad in it- Psalms 118:24
World Champion Turn Marshall
BadSign is offline   Reply With Quote
Old 12-17-2014, 05:34 PM   #3877
waltss2k's Avatar
Where at ? Indy or Columbus
Old 12-18-2014, 06:49 AM   #3878
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
Originally Posted by Harold996tt View Post
Well noted and a great explanation. Much thanks. I assume is one applied next to the lock. Nut of the diff. I note that there are different axle spacings available... What width should one be using and how do we determine what width to use please -Much thanks again.-
If you get kit #134 with all 3 spacer types, you will be ready for any size differential balls you use, 1/8 or 3/32.
John Higgins
liljohn1064 is offline   Reply With Quote
Old 12-20-2014, 08:23 PM   #3879
waltss2k's Avatar
New to WGT, what's a good tire diameter and roll out to start off with. I have a Gen X 10 SE and will be running on a 80 X 40 track size.
Old 12-20-2014, 11:30 PM   #3880
Still Bill's Avatar
The smaller the better; but, make it affordable too.
Probably, something like...
- Club racing 54mm
- Going faster 53mm
- Big meets 52mm
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 12-21-2014, 08:00 AM   #3881
waltss2k's Avatar
- Club racing 54mm
- Going faster 53mm
- Big meets 52mm
Bill
do you run both front and rear at the same sizes?
Old 12-21-2014, 08:22 AM   #3882
Still Bill's Avatar
I do. But, I run two sets of WGT fronts to one set of rears because the fronts wear about twice as fast as the rears. So, I buy double the fronts when ordering tires.
Also switch side-to-side as the more used tires wear down (whichever side is considered outside on the track). This is usually more pronounced on the fronts than the rears; so, I time my front swaps to when I am changing the tires from one set to the other.
Following these directions, I seldom have to re-true my tires. But, would if necessary.
Hope this helps.
Bill
Old 12-21-2014, 08:32 AM   #3883
waltss2k's Avatar
Sure does. Thanks Bill. What about Roll out?
Old 12-21-2014, 08:39 AM   #3884
Still Bill's Avatar
And I have dozens of 52mm tires properly stored for practice...LOL
Old 12-21-2014, 08:45 AM   #3885
Still Bill's Avatar
With a ROAR legal setup, I am usually between 83-88mm. Whereas, I see others getting up to 90'ish on larger tracks with a 100' back straight.
What motor and ESC do you run?
Bill
