Old 06-13-2014, 04:36 PM   #3796
liljohn1064's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to liljohn1064 Send a message via MSN to liljohn1064 Send a message via Yahoo to liljohn1064
Originally Posted by NutDriver View Post
I generally only lurk on this thread, so I'm a bit behind. Which Serpent axle is the one you used? I would like to run my CRCs in the LM class, but it requires "single lug wheels" like the Speed Passion LM wheels in your pics. This looks awesome! I'll keep my eyes open for 200mm "P" bodies that will fit this wheelbase.
Scott
Originally Posted by liljohn1064 View Post
Sorry if it seams I'm harping on this...
Putting Metric rims with a 10mm bearing cup (F1, SP) on a 1/8" CRC axle is super easy: Boca bearing 3.175 x 10 x 4mm fishing real bearings. A 4 pack is a bit pricey at almost $32 per pack, but they are ceramic ABEC 5. But again, the option is out there if you have that pan car laying around.
Front bearings:
#FBK103-ZZ5/3.175 BORE Radial Bearings
Serpent parts for the rear by part number:
Rear axle cone and nut S100/120 (#411251) For the cone.
Wheelhub left F110 (#411289)
Diffhub F110 (#411290)
Diffhub insert F110 (#411301)
Diffhub lock pin F110 (2) (#411302)
Diff adjust nut F110 (#411306)
Rear axle F110 aluminum(#411309)
Rear axle F110 steel (#411318)
Can be taken from the CRC:
Diff spring washer (4) (#411166)
Diff washer S120L (2) (#411186)
2 M3X3mm set screws.
1/8 diff balls.
Spur of choice, SP 72 48P bolts right in as does any Kimbrough.
LM body.
SP mounted foam tires.
Conversion steps, Swap front wheels and bearings. Unclamp left side WGT hub. Slide out WGT axle with diff. Slide in LeMans axle with center single bolt hub. Set screw left side hub into place. Put on the LM body of choice. Keep the Imperial parts together to switch back and forth in minutes. Used CRC Pan cars can be had cheap and need very little bling.
This is from our local racing thread. WGT doesn't exist here in Madison, so LM is our local popular class. I tend to keep stuff around, so I'm showing the locals how easy it is to convert to this class with one of my WGTs and one of my F1s.
John Higgins
liljohn1064 is offline   Reply With Quote
Old 06-13-2014, 04:38 PM   #3797
Originally Posted by InspGadgt View Post
Some people used CRC front knuckle parts on the SP-1 due to the weak plastic on the SP-1...might be able to just use the SP-1 knuckles and axle on the front end to fit the metric bearings.
SP knuckles, king pins and axles or Serpent king pins knuckles and axles should work too. You might need the upper pivot ball too for either brand.
John Higgins
Old 07-15-2014, 01:56 AM   #3798
Can I install a standard servo (like the Savox SH1290MG) on this car ? or only mini size servos ?
coderzone77 is offline   Reply With Quote
Old 07-15-2014, 09:16 AM   #3799
I wonder if the WTF-1 parts will make this conversion easier.......I will have to ask the guy that has all of those parts in front of him....oh wait, that's me.
What are the rules for this class?
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 07-15-2014, 10:36 AM   #3800
The WTF parts would be the hot ticket. Those parts are for sale when??? Or just take a WTF and put the F103 special front bumper on it. TRG now makes a version of the bumper. http://www.ebay.com/itm/TRG-TRG5094-...-/130602955283
USLMP Rules per the USVTA website with a couple corrections/changes in red as we do not and may not ever run rubber tires.
Min ride height 3mm
Max width 205mm
Min wheelbase 255mm
Max wheelbase 275mm
Min weight 1200g
Motor limit indoor tracks 21.5, outdoor tracks 17.5
Esc ROAR approved blinky only
Battery 2S regular or shorty
Single nut wheel attachment
Rubber tires We run foams as rubber tires may never happen
Speedpassion Premounted foam tires, minimal truing allowed. Must be 4mm of foam on tire at the start of the race.
Speed passion premounts
Max wheel width front TBA
Max wheel width rear TBA
Min wheel width front TBA
Min wheel width rear TBA
Max wheel diameter 50mm
Max tire diameter TBA
Min tire diameter TBA
Only LMP, Group C, GTP, GT1, Can Am, Sports Prototype bodies are allowed
- If body comes with molded in kick up at rear, must be cut out to resemble separate wing as on full scale car
- If body come with separate wing, must be mounted in same location as full scale car
- No oval or TC style wings allowed
- Scale liveries encouraged and recommended, we will make fun of you if you paint a tribal flamejob-no exceptions
Qualifying format to be USSRCRA style, 3 min single qualifier using 5 fastest avg laps to seed your position for mains.
3 x 10 min mains for points to determine overall winner
- Option to use standard IFMAR qualifying and single main event (club choice)
Commercially available LMP chassis (SpeedPassion LM-1) or converted 1/10 pan chassis (WGT, Pro-10) pan chassis fitting the dimensions are allowed.
Body recommendations-
SpeedPassion LMA
Royce RM-1
Toyota GT-1 TS020
Rivall LMP1
Porsche 962
Nissan R91CP
Toyota Group C 88CV
Mercedes Group C CLR
Porsche 962C
Toyota GT1 TS020
Porsche 911 GT1
John Higgins
Old 07-15-2014, 10:49 AM   #3801
It will take a standard servo just fine.
John Higgins
Old 07-15-2014, 09:11 PM   #3802
Still Bill's Avatar
You won't be able to get the output shaft of any standard servo centered on the Gen-X 10 chassis; so, the geometry of your steering will be compromised a bit. A mini size servo will let you position the output shaft in the center of all CRC Gen-X 10 chassis. A mini will also allow you to do the reversed servo placement on the SE chassis. Can't do that mod with a standard servo.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 07-15-2014, 10:23 PM   #3803
Bill
If you use the stock servo mount holes it won't line up...but if you go old school and drill your own servo mount holes it should work...or just shoe goo the servo to the chassis. If you mount the servo to the front suspension plate you won't be able to get it to center.
Apex RC
www.apexrc.com - Hawaii's #1 RC Proshop
Share & Like Our Page:https://www.facebook.com/ApexRCProshop
Win free stuff!
Old 07-17-2014, 08:41 AM   #3804
so, what servo model would you suggest to me please ?
Old 07-17-2014, 09:19 AM   #3805
Futaba s9650 servo. And one of these Kimbrough Servo Savers.
John Higgins
Old 07-17-2014, 08:54 PM   #3806
Still Bill's Avatar
I have used the KO 951PDS and the JR Z3650 servos. For me the JR Z3650 is both cost effective and bullet proof for durability. I have hurt one KO 951PDS; but, not without great effort...LOL
Always match with a Kimbrough #201 (or #200) Mid-Sized Servo Saver. #201 is predrilled/#200 is without holes so you can customize hole locations.
Bill
Old 07-21-2014, 06:56 PM   #3807
Trader Rating: 19 (100%+)
Newbie needs help. Been running oval for years but want to try some road course. Figured a WGT car would be a good start since it only has 1 shock and I can use my 1c batts, tires, 13.5 motor, servo, esc, etc... from my 13.5 spec car. Have a CRC x10 and am trying to get it set up. So here is my question:
If you put it on a 4 scale board, wouldn't you want the weight on the rear tires to match and the weight on the front tires to match since you are turning left AND right? How exactly do you do that? The battery, servo and esc are centered. The only extra stuff is the receiver pack and the receiver and they don't weigh much. Also, with rear tweak springs set equal, car has a TON of tweak in it. What am I doing wrong? By tweak I mean when I lift the car from the front the right front wheel leaves the ground WAY before the left front. Car is right rear/left front heavy.
97806 is offline   Reply With Quote
Old 07-21-2014, 06:56 PM   #3808
Double post.
Old 07-21-2014, 08:08 PM   #3809
Still Bill's Avatar
Which model of CRC Gen-X 10 do you have? Makes a huge different between the old "Pro" version and the "LE/SE" versions.
Bill
Old 07-22-2014, 05:25 AM   #3810
Bill
LE with a 9650 servo, a 1 cell mounted forward, a Tekin RS Spec mounted behind the battery and a Revtech 13.5 mounted normal. All that's left is the receiver and receiver pack.
Took off the dampener tubes and unscrewed the tweak springs all the way up. Put the front wheels on scales and the left front is measuring 221 g and the right front is measuring 159 g. Going to pull the front end apart and rebuild tonight to see if I have something off/bent/binding etc. but that's still a pretty big difference. Even if I put the receiver and pack on the right side the balance on the front only changes about 5 g.
