Old 05-13-2014, 08:29 PM   #3751
Still Bill's Avatar
Originally Posted by TyoBBS View Post
Since 2 race ago my front/right foam:
With diferrent foam always the same. Why?
regards
Just noticed your front bumper setup...
With the 2S battery setup, you car is probably much faster than my 1S WGT; so, you probably have to deal with somewhat bigger impacts from shunts/accidents.
Consider grinding off the leading part of your Kevlar bumper so that the foam bumper extends beyond it. This will allow the foam bumper to absorb the initial impact to save your carbon fiber chassis plate and other parts.
This bumper arrangement works very well for me.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 05-14-2014, 12:22 AM   #3752
corally's Avatar
Of course it's better UFRA
1- Better grip
2- Better glue
3- Can use more time in good conditions
regards
I know...but suggestion to setup car on asphalt? i use 2s on 13.5 in blinky mode..
corally is offline   Reply With Quote
Old 05-14-2014, 05:43 AM   #3753
Thanks Bill for evolving my CRC better and better. I will test it
Yes. This year we only race in outdoor tracks (asphalt) between 10.5-4.5 with boost/turbo and 2S
regards
TyoBBS is offline   Reply With Quote
Old 05-14-2014, 08:12 AM   #3754
corally's Avatar
TyOBBS...
plse share your setup for SE on asphalt..
Old 05-14-2014, 06:54 PM   #3755
Still Bill's Avatar
Hi Corally,
Please post a picture of your SE car and I will comment about possible setup options.
And is a picture of your asphalt track available too?
Attached are a few pictures of my asphalt WGT 1S 13.5 Blinky SE. Same component layout applies to a 2S SE.
These pictures are a month old so a few changes have been made since.
Hope this helps.
Bill
CRC 1/10 Pan Car-wgt-asphalt-002.jpg   CRC 1/10 Pan Car-wgt-asphalt-003.jpg   CRC 1/10 Pan Car-wgt-asphalt-006.jpg   CRC 1/10 Pan Car-wgt-asphalt-010.jpg
Old 05-15-2014, 02:01 AM   #3756
corally's Avatar
Hello
this is track
http://www.rctrackcastelpasserino.com/la-pista
Car is without electronic..(like out of box) at now....but i follow your schema to place ESC ad so on...i read to place dumper on horizontal way..correct?
Link like manual or more straight? fornt spring? oil?....
What servo use you?
Old 05-15-2014, 07:54 PM   #3757
Still Bill's Avatar
Hello
this is track
What servo use you?
Picture SE 001 is the latest position of the side tubes at the rear of my asphalt WGT SE.
Picture SE 002 shows you how the foam bumper extends beyond the carbon fiber bumper to help absorb big hits.
Picture SE 004 shows the geometry of my steering while wheels are positioned straight.
Picture SE 005 shows the geometry of my steering while wheels are at full lock to one side.
Two of my cars have JR 3650 servos. One has KO KDS-951 servo. Both are high quality servos; but, the KO servo costs more.
Bill
CRC 1/10 Pan Car-se-001.jpg   CRC 1/10 Pan Car-se-002.jpg   CRC 1/10 Pan Car-se-004.jpg   CRC 1/10 Pan Car-se-005.jpg
Old 05-15-2014, 09:36 PM   #3758
TyOBBS...
I'm sorry but my new CRC is LE version because i don't use shorty lipo. Isn't the same setup but may be can use by starting point for oil and springs.
Old Still Bill setup:
If you don't find servos of Bill: I use Savox SC1251MG
Nice track corally but 1000km from Barcelona, isn't easy to go every weekend
regards
Old 05-16-2014, 04:06 AM   #3759
corally's Avatar
Thanks at all !
Still Bill i see on your car the position of rear link on internal hole..more staright vs manual indication..wath chenge on handling car?
Is short...is from xti?
Old 05-16-2014, 04:58 PM   #3760
First step, ready to test:
Inside holes on the steering blocks and reverse the ball stud from servo saver:
regards
Old 05-16-2014, 06:42 PM   #3761
Still Bill's Avatar
regards
Wow! Forgot I posted that setup back in 2011. Have to say that it is OLD...like ME...LOL
My only problem with the Savox servo is that I do not believe it can be positioned with its output shaft in the center of the chassis. It is a low-profile servo; but, you really need a mini servo for the best possible positioning.
Very nice track!
Bill
Old 05-21-2014, 01:41 AM   #3762
corally's Avatar
Thanks at all !!!
plse........
Old 05-21-2014, 06:45 PM   #3763
Still Bill's Avatar
plse........
As recommended by SG1. And I do like my side links to be straight.
Part number is: CRC #3280 - Clamping One-piece Links
These side links are 55 mm center-to-center. The links that came with the SE are 65 mm.
These are the only parts you need to move the springs to the outside position.
Bill
Old 05-24-2014, 10:52 PM   #3764
regards
My best lap did it last year with GenX10 - 6.5T = 22,7
This year with GenX10 LE - 5.5T i can't go faster than 23 until Bill help me with setup
22 New central shock
21,7 Inside holes on the steering blocks and reverse the ball stud from servo saver
1 second!!! I don't finished yet
THANKS and regards
Old 05-26-2014, 06:31 AM   #3765
Hi all, I want to buy an CRC Gen-X 10 SE.
I am a newbie, running only a Sakura Xi Sport at the moment at the local track.
Can I use the same lipo (Turnigy Nanotech 6600 2s2p) into the CRC gen-x 10 se ?
(then I would like to decide for proper ESC and motor..)
Thanks to all
coderzone77 is offline   Reply With Quote
