Old 09-14-2008, 07:49 AM   #361
Still Bill's Avatar
Originally Posted by smyka View Post
all fixed speedo should of said left got ahead of my self their typing i will see if i can get some pictures up tonight
Mark,
Thanks for the quick response.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 09-14-2008, 05:17 PM   #362
smyka's Avatar
Send a message via AIM to smyka
no problem
Trinity, Proline ,EA motorsports, T.O.P Racing ,Futaba ,Bsr Racing tires ,Advantage racing products,Hot Bodies racing,Tq Wire ,REDS Racing, Orca ,Protoform racing
smyka is offline   Reply With Quote
Old 09-19-2008, 12:34 PM   #363
Regional Moderator
Darkseid's Avatar
Can somebody give me a list of all the hex head sizes from the kit.
TLR 22...Tamiya F104...
Old 09-19-2008, 02:24 PM   #364
smyka's Avatar
do you need to know what size wrenches you need ? if so
.05
1//16
3/32
5/64
Old 09-20-2008, 08:49 AM   #365
johnnywhopper's Avatar
...and a 2.5mm for the motor screws.
Team CRC, Spektrum, Hobbywing, JDJ Vinyl Graphics, Moby Graphix, Black Art, Power Push
johnnywhopper is offline   Reply With Quote
Old 09-20-2008, 10:16 AM   #366
skypilot's Avatar
Trader Rating: 14 (100%+)
i had to add 5.5 ounches to my car i had four on the right side infront of the link and 1.5 on left surrounding the speedo
was this to make weight or get the car to work??
#49, #25a, #91, #7, #12 the ones to watch.... UPDATE. #12 is your new AMA GNC #1
A Northwest Team of Positive actions
skypilot is offline   Reply With Quote
Old 09-20-2008, 01:53 PM   #367
@ IROCC we use a base weight of 1200 grams and the cars come in any were between 1200 and 1300. To make the car work with a lot of HP you need a body with a lot of down force. Almost all the cars have the 235mm kit install
-=light=-
light is offline   Reply With Quote
Old 09-20-2008, 04:10 PM   #368
V12
V12's Avatar
Originally Posted by trackdesigner71 View Post
I know that this is largely a discussion about the GenX10 but would it be possible to get some setup help for the Pantoura? Any of you CRC guys run the Pantoura before the GenX10 came out?
The Pantoura looks a little different than the Gen X-10 but actually work very similar. I just was building a 235mm Pantoura and Iīm using very similar setup than a friend with his 235mm Gen X-10. I donīt see why with 200mm this should be different.
Maybe you should change some things on the Pantoura what are outdated now.
I would go with the low rollcenter kit for rear pivots and change the position from the tubes so these are going to the outside on a straight line not at an angle.
V12 is offline   Reply With Quote
Old 09-20-2008, 04:24 PM   #369
V12
V12's Avatar
Yes downforce is important with highpower motors. We are running Lipo only with 4.5 to 5.5T motors on our 235mm cars. As bodies just the Porsche and Lola gas bodies are working with this power. The Peugeot is not enough.
Old 09-20-2008, 06:35 PM   #370
JB_catricala's Avatar
Default genx 10 setup
Hey guys
I have been racing this car for the last two weeks and i love it. this is the setup that i am running.
Front
.45 springs
10 deg caster block
1 shim in front
long ball
inline axles
shortest wheel base
middle width
4 shims on each side
1.5 camber
using 1/12 graphite steering arm thing
BSR dbl pink tires
Middle
hot bodies shock w/ 45 oil
shimmed up rear of shock 3 mm
battteries foward
esc mounted in the middle of the 5 and 6 battery positions on the bar thing
Rear
30 000 in tubes
red side springs w/ hardly any preload
BSR Pink Tires
added the weight beside the links to make weight
i really like the car if you have any questions just ask
Hi
Serpent
SMC
AKA
FarmCats
JB_catricala is offline   Reply With Quote
Old 09-21-2008, 08:30 AM   #371
Regional Moderator
Darkseid's Avatar
.05
1//16
3/32
5/64
Yeah, thats what I needed. Its been quite some time since I last used standard stuff instead of metric. So I wanted to get me some standard drivers before I start building the car. Want to avoid using those allen wrenches as much as possible.
Thanks.
Old 09-24-2008, 11:35 AM   #372
jag88's Avatar
Originally Posted by JB_catricala View Post
Hey guys
Front
.45 springs
10 deg caster block
1 shim in front
long ball
inline axles
shortest wheel base
middle width
1.5 camber
BSR dbl pink tires
Middle
battteries foward
Rear
30 000 in tubes
BSR Pink Tires
Do you have any pic's ?
jag88 is offline   Reply With Quote
Old 09-24-2008, 12:00 PM   #373
espresso1967's Avatar
Trader Rating: 18 (100%+)
Yes, picture please
www.cityofangelstshirts.com
espresso1967 is offline   Reply With Quote
Old 09-24-2008, 12:03 PM   #374
What body are you using? I just picked u a 3.5r Novak and running the 200mm lola by protoform. I have the saleen and corvette but for a fast track, the lola seems to be working for me. I was looking at the Mulsanne LMP but not sure if it can handle the 3.5 motor. Looking forward to some testing this weekend, will try to get some video if possible.
Old 09-24-2008, 02:20 PM   #375
V12
V12's Avatar
We are running 235mm cars where the wider bodies generate more downforce than 200mm anyway. But as highdownforce bodies are generating even more downforce we use Serpent Porsche 962 and Serpent/Frewer Lola as used with the old 235mm gas cars. OK gascar bodies are not the best looking ones but with an "optimized" colourscheme itīs not that bad, at least for the Porsche.
