Old 02-20-2014, 10:16 PM   #3631
el salvador's Avatar
Exclamation
Originally Posted by InspGadgt View Post
Where is this SG1 setup? All the ones on CRC's website are old.
Page 201 Post #3011
Ur Welcome!
ARC R8 X2/ Max RP9 or O.S. R2101 ,Capricorn LAB C02-TOP Elite R, ARC R11....
"Every Cemetery in Chicago Votes Democrat!"
el salvador is offline   Reply With Quote
Old 02-20-2014, 11:06 PM   #3632
Still Bill's Avatar
Originally Posted by sg1 View Post
Hey Guys,
I thought I'd post some set up info from my CRC WGT I ran at the US Indoor Champs over the weekend.
I TQ'ed and won the main with this set up:
2.01" tires front and rear
Long front arms
White front and side springs
side springs moved out to over side links
side tubes raised and 7K lube
30wt center shock with purple spring
4.5mm clearance all around
1.5mm droop in rear shock
.25mm droop front
1.25* camber
10* front blocks
inline axles
If you have any questions feel free to ask.
Here's a pic:
Attachment 997692
As posted by SG1 on 11/28/12. About page 200; but, also read the many posts that follow over the next several pages. Includes pictures of his car in a couple posts.
Easiest and most consistent WGT setup I have ever driven; but, I have to give the nod to Dumper for the fastest setups ever (usually harder for me to drive consistently at my skill level).
On asphalt, I continue to make changes to the SG1 setup. It is still on my sole remaining LE chassis; but, will be carried over to one of my SE chassis soon.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 02-21-2014, 04:28 AM   #3633
tdu verney's Avatar
Default SG1 Set up
It's on this thread
tdu verney is offline   Reply With Quote
Old 02-21-2014, 05:48 AM   #3634
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Bill
Hey Bill,
When I went over to the new WGT my setup took a big change.
I ended up with stock front arms, high roll center graphite shims, 1/12 kingpins with .50mm springs, 5* blocks shims back. I still raised the tubes and ran the springs on the links, but ended up with stiffer side springs (new .55mm) and heavier dampening (30k and 50k).
Keep in mind it's for very high bite carpet tracks.
I also had good luck with slightly narrowing the rear tires (from the inside), approx. 3/16" and running the rear tires .04 to .05" larger then the fronts. I typically start at 2.07" rears and 2.02" or 2.03" fronts. By the end of the day when the traction is very high my tires are about .02" smaller all around. I skim them each run.
-Wayne
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 02-21-2014, 05:55 PM   #3635
Still Bill's Avatar
Hey Bill,
-Wayne
Wayne,
Thanks for the update. On my asphalt LE, I recently switched to stock front arms with 5* blocks (shims 1 forward/2 back; will try your shimming). Plus, the new #3395 1/10th 8 x .55mm front springs on 1/10th king pins and #1795 tapered .55 springs at the rear. Again, this is for asphalt. Will be transferring the whole setup to my asphalt SE this weekend.
You skim your tires each run??? You are an animal; and, my hero of the week!!!
Headed down to TQ Raceway in SoCal for some testing on their rug next month. Will give it a go there too.
Again...The great thing about your setup is that it is so easy to drive. Something I well take advantage of...LOL And it will certainly be on one of the WGT cars that I take to the IIC.
Cheers!
Bill
Old 02-22-2014, 01:54 PM   #3636
reracer's Avatar
What's the typical race ready weight of a 10th scale WGT car?
reracer is offline   Reply With Quote
Old 02-22-2014, 03:07 PM   #3637
avs
avs's Avatar
930gm is the legal min weight. but most cars build light. mine is over 40gms light.
Tony Shimko
avs is offline   Reply With Quote
Old 02-22-2014, 07:16 PM   #3638
reracer's Avatar
So you're under 900 grams? Is that with a 1s or 2s battery?
Old 02-22-2014, 07:22 PM   #3639
Still Bill's Avatar
My LE is about 20-25 grams heavy; but, my two SE's are approximately 10-15 grams light. For the most part, weight variations between cars will depend on: chassis used; front end components; tire sizing; motor; size of wiring; how much paint on body; and, which lipo battery is in the car.
I use ROAR-legal 1S ESCs with a 1S battery pack. No need for a servo pack.
Bill
Old 02-22-2014, 11:11 PM   #3640
Odin544's Avatar
Trader Rating: 93 (100%+)
Ran my SE for the first time today. Easily Tq'ed and won the main. I haven't run any 1/10 pan car class in 20 years. That was sure a lot of fun! Unfortunately our local club racing ended tonight. So I need to do a little traveling to run it some more. We got a lot of people interested for next onroad season though so it should be a good class next year.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 02-23-2014, 12:41 AM   #3641
avs
avs's Avatar
1s battery, with ko servo, futaba 614 receiver and hobbywing 2.1 speedo. but this was with older batteries (4500 and 5000 ), the new 7000's are likely heavier.
Tony Shimko
Old 02-23-2014, 07:19 AM   #3642
LE 235mm and 2S = 1350gr!!!
TyoBBS is offline   Reply With Quote
Old 02-24-2014, 05:34 AM   #3643
Originally Posted by tudor_47 View Post
We, Lajf Racing are making a widening kit for the CRC GEN-X10.
yes it is 235mm conversion.
The kit is designed to use the IRS 235 rear axle.
Here is a picture of the rearend on a prototype, taken this sunday(19 of May).
http://lajf.se/en/nyheter/crc-gen-x1...breddningskit/
Original CRC Drive Hub need (+bearings):
Diff Spacer CLN4121
Spring Washer CLN4123
I want to upgrade (235 without extensions):
Drive Hub IRS2121 only need IRS527 (+bearings)?
Edited. Answer from irs:
You can use the CRC diff spacer and spring washer.
Old 02-25-2014, 06:45 PM   #3644
Odin544's Avatar
What is the difference in running the servo in front of the links vs behind them? Just weight balance? Does the car handle differently?
TriCitiesRC.com
Old 02-25-2014, 06:55 PM   #3645
Odin544's Avatar
Also what kind of spares or option parts should I keep on hand for my SE?
TriCitiesRC.com
