Old 08-31-2008, 06:44 PM   #346
Ike
Ike's Avatar
Originally Posted by smyka View Post
i will send frank my set up so he can post it on the site i believe me frank and brian ran very simmilar setups
Did you end up having to add a bunch of weight? If so, where were you guys adding it?
Ike is offline   Reply With Quote
Old 09-01-2008, 12:44 PM   #347
smyka's Avatar
Send a message via AIM to smyka
i had to add 5.5 ounches to my car i had four on the right side infront of the link and 1.5 on left surrounding the speedo
Trinity, Proline ,EA motorsports, T.O.P Racing ,Futaba ,Bsr Racing tires ,Advantage racing products,Hot Bodies racing,Tq Wire ,REDS Racing, Orca ,Protoform racing
smyka is offline   Reply With Quote
Old 09-01-2008, 09:42 PM   #348
Ike
Ike's Avatar
Thanks Mark! If you happen to have any pics of your electronics layout that would be much appreciated.
Thanks Again,
Ike
Old 09-05-2008, 01:16 AM   #349
espresso1967's Avatar
Trader Rating: 18 (100%+)
For those that have not checked out the crc site, check it out, bumper for Gen X 10.
http://teamcrc.com/crc/
www.cityofangelstshirts.com
espresso1967 is offline   Reply With Quote
Old 09-12-2008, 10:26 PM   #350
Still Bill's Avatar
Default Gettin' there...
X-10 car is about 50% built...Now that I have progressed to the front end of the car, I sure could use some help with an asphalt setup.
Definitely getting the new bumper. Any other suggestions for support parts.
What is the weight of the Losi shock spring in the kit? Seems very stiff for asphalt.
Thanks.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 09-13-2008, 10:54 AM   #351
Thanks.
Bill
The two kits I bought had a little sticker in the shock bag parts for the spring weight. one was 30 and one was 25 I soon replace the 30 with a 25 also with this car the body has a lot to do with how the car will handle. If your going to run a lipo and a 10.5 you will need a body with a lot of down force like the 200mm lola or in 235mm the The Protoform “P905B. I found that for me a 13.5 and a lipo works better then the 10.5 as I can handle the speed. also make sure you sand the bumper edge then seal it with CA it will help it hold together when you hit the dots.
-=light=-
www.irocc.ca
light is offline   Reply With Quote
Old 09-13-2008, 01:09 PM   #352
I second the body. If you are going to be running fast motor and big track, a high down force body is called for. I tried the Saleen and Corvette at a big track and don't work for me. Put a lola body on it and big difference. Good luck on your build.
-=light=-
www.irocc.ca
Old 09-13-2008, 03:34 PM   #353
Still Bill's Avatar
My kit came with those two stickers too. They all say "30"; so, that must be it. I forgot that was how my JRXS springs were labeled a couple years back.
I plan to run an SMC 5000 lipo and a 13.5 BL motor. Meets the requirements for a local race series. Fast enough.
Did already buy the new Protoform Alfa GT body.
Was hoping a Futaba 9551 servo would fit...But won't. Any votes for best smaller servo to use:
Futaba 9650
KO 949
Airtronics 94141/94145
JR 3550/3650
Thanks.
Old 09-13-2008, 03:42 PM   #354
Futaba 9650
KO 949
JR 3550/3650
Thanks.
JR 3550/3650 I have used both of these and I like them both a lot they are a perfect fit
I run a MaxAmps 6000 2cell since we can run a soft cell pack on our local track. but I have a SMC 4000 and a steel plate for races that don't allow them
Old 09-13-2008, 04:07 PM   #355
a little pricey but super happy with it JR Z3650. You can't go wrong with this servo.
Old 09-13-2008, 05:39 PM   #356
smyka's Avatar
my electronics were like this reciever on the right side with four ounces of weight around it and speedo on the left with a ounce and a half placement was right in front of the links ..
as for out door set up i will see if i can get the firching brothers to post on here they are the only ones i know of that ran it outdoors
set up for me from iic
front .18 1/12 associated springs
10 degree caster
3 camber
no h brace
short ball
trailing axles
mid wheel base and mid width
mid
batteries forward
new crc center 1/12 shock copper spring 35 wt losi oil
1 mm pod droop
rear
200mm rear axle width
100 tooth spur
15000 losi diff lube in tubes
red springs 1.5 turns of pre load
should of gone to inline axles and try green side springs
Old 09-13-2008, 06:40 PM   #357
my electronics were reciever on the right side with four ounces of weight around it and speedo on the right with a ounce and a half placement was right in front of the links ..
Both receiver and ESC on the right side? Is that an oval setup?
Arn0 is offline   Reply With Quote
Old 09-13-2008, 09:11 PM   #358
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
I know that this is largely a discussion about the GenX10 but would it be possible to get some setup help for the Pantoura? Any of you CRC guys run the Pantoura before the GenX10 came out?
trackdesigner71 is offline   Reply With Quote
Old 09-14-2008, 07:16 AM   #359
Still Bill's Avatar
Mark Symka,
Can you please clarify or show a picture?
Many, many thanks.
Still "Building my X-10" Bill
Old 09-14-2008, 07:46 AM   #360
smyka's Avatar
all fixed speedo should of said left got ahead of my self their typing i will see if i can get some pictures up tonight
