CRC 1/10 Pan Car
#3453
#3454
So it's called the SE. I received mine a few weeks ago in a clear poly bag on a Thur night. Had it on the track Sat. Opened with a tq/win! Same thing happened on our season opener return to the Hangar on Wed night. This car is off to a great start. Out of the package with the slider pod, wow! I have a hunch it will come with everything it needs to win right out of the box. This car has a little smoother feel then the LE and a lot cleaner looking.
I do have the new side and center springs. I have worked a little on equivalency between old vs new. My methods are not scientific, but I feel it's close. One issue when comparing old and older, is there was a running change in the center spring wire thickness causing a rate change. My suggestion is to set aside all your old springs and pick up the new so that you speak the same lingo. I've found the .60 sides are similar to the reds. The older red center is similar to the new silver. There are far more new spring selections that are in between the old white and red, so great news there! I have been running the new .60 sides +2 turns and silver center (which is nearly identical if you ran red sides +1.5 turns and old red center).
I was first concerned about the narrowness of the new chassis, but once I received it, I gave it the good old flex twist test. There must be something to this new QHM carbon fiber. I felt it on the bench, but even better, I felt it on the track.
That's enough wind up Frank's kilt..... order one now! See everyone in Vegas!!!
Brian
Brian
#3455
Will you guys have the spring sets for sale at the IIC? I forgot to bring my center spring sets for my Xti and X10 LE...if so please hold 2 sets of the center springs and 2 sets of the side springs for me!
#3457
Ok I sent Frank an email...I hope he gets it in time.
#3458
#3459
#3463
I see. I was just trying to find out where locally to run on carpet. Or maybe you're opening something up.
#3465
I only saw Rear Bottom Plate for the CRC Gen-X 10 in aluminium hand made. Any place to buy this option in aluminium?
thanks and regards
thanks and regards
