Old 09-30-2013, 02:06 PM   #3436
Just looking to see what wheel base people are running ?
Friulimotosport is offline   Reply With Quote
Old 09-30-2013, 03:03 PM   #3437
The car is super smoothe and easy to drive with either wheelbase option, so I typically stick with the shorter setting as it feels slightly more responsive.
vafactor is offline   Reply With Quote
Old 10-01-2013, 10:18 AM   #3438
dubble-m's Avatar
Hey guys,
Just wanted to give a shout out to SG1 (Wayne) who had posted his Cleveland set-up on here last year sometime.
I used it with some small iterations this weekend to win the WGT class at Lou's Speedway Fall Fiasco (narrowly missed TQ as well)
The car was dialed all weekend and it felt like driving a TC through the chicanes! It wouldn't diff out at all!
I attached a pic of the chassis layout.....I'll see if I can get some side shots of the link set-up.
MM
CRC 1/10 Pan Car-10017611643_e7abe2fd57.jpg
dubble-m is offline   Reply With Quote
Old 10-01-2013, 01:40 PM   #3439
Just curious if anyone in here has a gen x le for sale. I miss wgt, and it's picking back up locally..
X-ray T4'16 stock TC, Xray T4'15 mod sedan, Xray xb4. Xray, Motiv, Team debit card.
Boostinswifty38 is offline   Reply With Quote
Old 10-02-2013, 01:15 AM   #3440
Originally Posted by dubble-m View Post
Hey guys,
MM
Is your servo as far off centre as it looks in the picture?
sparkyboy22 is offline   Reply With Quote
Old 10-02-2013, 02:50 AM   #3441
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Hey guys,
MM
Nice job!
What springs did you run with the stock upper a-arms?
-Wayne
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 10-02-2013, 12:13 PM   #3442
Boom!
http://www.teamcrc.com/crc/modules.p...rticle&sid=183
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 10-02-2013, 12:16 PM   #3443
Saw the car this last weekend in blocks hands Brian. Looks sick! When ya gonna send me one?!
Old 10-02-2013, 12:58 PM   #3444
joeymdz's Avatar
Send a message via MSN to joeymdz
when are they available Dumper?
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 10-02-2013, 01:33 PM   #3445
Shipping this week!
Old 10-02-2013, 02:03 PM   #3446
Tanis103's Avatar
We should start a new thread
Tanis103 is offline   Reply With Quote
Old 10-02-2013, 05:05 PM   #3447
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
So it's called the SE. I received mine a few weeks ago in a clear poly bag on a Thur night. Had it on the track Sat. Opened with a tq/win! Same thing happened on our season opener return to the Hangar on Wed night. This car is off to a great start. Out of the package with the slider pod, wow! I have a hunch it will come with everything it needs to win right out of the box. This car has a little smoother feel then the LE and a lot cleaner looking.
I do have the new side and center springs. I have worked a little on equivalency between old vs new. My methods are not scientific, but I feel it's close. One issue when comparing old and older, is there was a running change in the center spring wire thickness causing a rate change. My suggestion is to set aside all your old springs and pick up the new so that you speak the same lingo. I've found the .60 sides are similar to the reds. The older red center is similar to the new silver. There are far more new spring selections that are in between the old white and red, so great news there! I have been running the new .60 sides +2 turns and silver center (which is nearly identical if you ran red sides +1.5 turns and old red center).
I was first concerned about the narrowness of the new chassis, but once I received it, I gave it the good old flex twist test. There must be something to this new QHM carbon fiber. I felt it on the bench, but even better, I felt it on the track.
That's enough wind up Frank's kilt..... order one now! See everyone in Vegas!!!
Brian
Stay dialed my friends!
www.slapmastertools.com
Team Roche USA
Team Orca orcharc.com
Slapmaster6000 is offline   Reply With Quote
Old 10-03-2013, 07:51 AM   #3448
al dente's Avatar
i also received mine a few weeks ago. we have been running the same layout since the MHIC, so we have a pretty solid base line for what times should be. since the move from the LE to the SE, i have eclipsed both the fast lap and the fastest run. there is no doubt that this is a major improvement to what was seemingly a perfect car.
Team CRC / Dumper's Speed Shop / Team Scream Racing / Black Art
RC America / FB/FX / Colorado On Road RC Club
5280 Raceway (5280raceway.com) home of the MILE HIGH INDOOR CHAMPS April 20-23, 2017
al dente is offline   Reply With Quote
Old 10-03-2013, 09:26 AM   #3449
Trader Rating: 14 (100%+)
Is there going to be a conversion kit for GenX10LE owners to convert to SE?
Codfather is offline   Reply With Quote
Old 10-03-2013, 09:51 AM   #3450
Can't speak for CRC, but if you don't have the slider pod, there wont be much you can swap over in a cost effective fashion. That said, I donated one of my many Xti's to make up a SE. I needed a rear axle n hubs, body posts, cf front bumper.
Team Roche USA
