Old 09-15-2013, 01:17 AM   #3406
Originally Posted by Still Bill View Post
Have previously suggested a redesign of the #3373 pieces (into a u-shape) to include side-to-side bracing for the battery. Also, would like to see more battery positioning holes in the chassis plate to fine tune the fore/aft placement of the 1S battery pack.
Bill
Something like this? My last BMI used 4-40 screws to locate the plates the front suspension mounts to like the pins on the battery brace so I got the idea to cut one myself and use screws for the locator pins.
CRC 1/10 Pan Car-battery-brace.jpg
Old 09-15-2013, 08:42 AM   #3407
Since 2 race ago my front/right foam:
With diferrent foam always the same. Why?
regards
TyoBBS is offline   Reply With Quote
Old 09-15-2013, 09:05 PM   #3408
Still Bill's Avatar
Burt,
That's it. Maybe Frank or Dumper will see it and come up with a new plastic version so I can retire my present solution.
So, from now on...I will just make suggestions and you can implement them...OK by me...LOL
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 09-15-2013, 09:15 PM   #3409
Still Bill's Avatar
regards
Tyo,
Guessing that the line in the foam is coming from your body.
I don't recognize the wheel/tire. Is that a soft compound?
Do you have more pictures of the overall car and the body?
Bill
Old 09-15-2013, 09:31 PM   #3410
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
I'm pretty sure the outside line is a seam. As for the lip on the inside, I have seen it myself when running asphalt, but I haven't identified it cause or if I even care if it shows up. For all I know its a sign of proper camber.
Old 09-15-2013, 10:35 PM   #3411
SWTour's Avatar
that's a glue/seam line and the inside is from the tire feathering. the wear looks good, flat and even, but it may be a little pushy in that direction causing that tire to be slipping, scrubbing speed.
(All my tires generally wear like that w/ using RC4Less on Asphalt)
It wasn't a split compound was it? (those don't usually wear that even)
Joe Myers
R/C Racing since 1985 ~ Santa Maria, CA (Central Coast)
2001-2012 - South-West Tour R/C Oval Series...will the SWT be revived?
Things are headed towards a return of the SWT Series, but for
2017 the focus will be on the Encino Velodrome (and dirt oval racing)
SWTour is offline   Reply With Quote
Old 09-16-2013, 01:22 AM   #3412
regards
I had notice when my car push (hard front tires or harder front spring), will develop the "ring" at the inner edge of the tires......
beamcat is offline   Reply With Quote
Old 09-16-2013, 01:28 AM   #3413
Burt,
Bill
I heard Diggity Designs had one but looking at their website I don't see it.
Old 09-21-2013, 11:52 PM   #3414
Thank you for all answers.
I use BLITZ NEW P908 and RC4LESS C35-F
regards
Old 09-21-2013, 11:55 PM   #3415
I use BLITZ NEW P908 and rc4less C35-F
Old 09-22-2013, 06:41 PM   #3416
Tanis103's Avatar
My front end seems to chatter in the higher speed corners, what causes this? I know its not the body.
My setup is,
CRC Gen 10X pro with 1s lipo McKune chassis
1/12th scale front kingpins, .55 front springs
.407 kingpin length
Purple center spring, 30w oil
Red side springs 1 turn preload
10k in tubes
Reverse servo front plate mid track width
3.4mm rear ride height
3.4mm front ride height
Front and rear tires at 52mm
-.5 Camber
Also, the car turns very well, will post pic soon.
Tanis103 is online now   Reply With Quote
Old 09-22-2013, 06:50 PM   #3417
Tanis103's Avatar
CRC 1/10 Pan Car-image.jpg
Old 09-22-2013, 06:52 PM   #3418
Tanis103's Avatar
Old 09-22-2013, 07:59 PM   #3419
Still Bill's Avatar
My setup is,
.407 kingpin length
10k in tubes
-.5 Camber
Great specs above.
Thinking that the .55 front springs are a tad too stiff for your situation; so, you might drop down to .50 springs. I have only gotten up to a purple center spring on my carpet LE at the IIC when the track was off the hook.
And that your ride high of only 3.4mm might be on the low side. Most races require 4 mm ride for WGT anyway.
Did you buy that car used? I built and sold two McKune chassis set up that way to SF Bay Area locals. Including multiple sets of Jaco carbon fiber wheels...Hmmm.
Bill
Old 09-22-2013, 08:16 PM   #3420
Tanis103's Avatar
Thanks Bill, will make the changes and see if that will help. What center spring would you recommend?
I bought the car used from a local guy here in South Carolina, not sure where he got it though.
