Old 08-31-2013, 06:16 PM   #3391
Building my Gen X 10LE finally With the slider pod conversion do I need to go with the short ball cup on the shock? I notice with the shock built as per instructions there is a lot of rear droop. Built as per instructions with the slider conversion I have nearly 4mm of rear droop.
Also what weight shock oil does it come with? 30?
Old 08-31-2013, 08:28 PM   #3392
Still Bill's Avatar
OK Burt, I won't make any reference to your 'droopy pod'...
At the forward end of the shock for Part #52 on Page 7, the manual shows to use the 'closed cup' piece from the plastic shock parts tree. However, I used the 'open cup' piece (shaped rectangular as opposed to round bodied closed cup). Just a matter of preference here.
At the rearward end of the shock (towards the pod), I used the longer ball cup; BUT, CUT THE METAL SHOCK SHAFT BY WHATEVER WAS NEEDED TO BE ABLE TO ADJUST THE REAR POD DROOP TO A RANGE OF 0-2 DEGREES. Thinking I had to cut something like 1/16" off of the shock shaft to accomplish this. The droop of my rear pod is typically set at 1 degree; so, this gives me 1 degree of adjustability in either direction.
And I have also accomplished the same thing by adding a second Part #44 (small o-ring) inside the shock which acts as a shock travel limiter.
Aloha!
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 08-31-2013, 09:17 PM   #3393
Ok well I guess the instructions need a lil work there. I tried it with the short rod end and it is just about .5mm droop with the short one. Much easier to do than cutting the shaft.
Old 08-31-2013, 11:38 PM   #3394
Still Bill's Avatar
Burt,
Using the extra internal o-ring solution involves less "commitment"...LOL
Truly, I cut through the shaft in 1-2 seconds with a Dremel disk. Thinking that I trimmed it down twice until I achieved the proper length...Maybe it was like 1/32" at a time. Been a few years ago; and, you know how my memory can be...
Cheers! Aloha! Cha, cha, cha...
Bill
Old 09-02-2013, 08:20 PM   #3395
Yeah but cutting the shaft down seems so permanent...I'd rather go with the shorter ball cup.
What is the stock shock oil weight?
Old 09-02-2013, 09:16 PM   #3396
Still Bill's Avatar
Then the extra o-ring should handle the issue.
The stock shock oil in the kit is 30 wt. And there is no need to ever change the weight per Dumper.
Bill
Old 09-02-2013, 10:32 PM   #3397
Ok cool. I think I've got it set now
Old 09-03-2013, 09:26 AM   #3398
Still Bill's Avatar
OK. Then, how about a picture...or two...
Bill
Old 09-03-2013, 09:45 AM   #3399
I've only got the roller assembled right now. Still running my old car locally until the IIC so I figured I'd wait until I got the whole thing together to post pics.
Old 09-03-2013, 12:18 PM   #3400
Still Bill's Avatar
OK. I can wait.
Is it time yet...LOL
Old 09-03-2013, 04:55 PM   #3401
Cancun Tom's Avatar
Send a message via Skype™ to Cancun Tom
Smile VELODROME in Cancun!
I guess I'll never ceased to be surprised at what I find in Cancun. They have built a world class sports center a couple of years ago and no one knows about it. We were trying out a newly built outdoor off road track Sunday when one of my friends told me about this banked oval within eyesight. We drove over with my CRC LE and RC10LS pan cars to check it out. Two caretakers allowed us access. The complex is apparently only used on weekdays, so it was empty. We asked if we could run my cars and they said sure. Now we had a practice session earlier in the day so the batteries were not going to last long and they were geared completely wrong for a track that is aroung 400 meters in length. (1312 ft.)
check out the link to my very short goPro HD video of my first ever try at such a long track. Any tips on how to gear for this track would be appreciated. We are going back this coming Sunday with fully charged batts and a GPS to get an exact length.
http://youtu.be/NLgtLsQrrk0
Check out all our travel adventures on my Caribbean Webpage http://www.cancunTom.com
Cancun Tom is offline   Reply With Quote
Old 09-03-2013, 05:06 PM   #3402
NutDriver's Avatar
Trader Rating: 14 (100%+)
I don't know if they still can be found, but RPM used to make shock clips (that clip on the shaft) that MIGHT able to be used internally to "shorten" the shaft. If I recall correctly, I had to trim 1/32 or so off of the ends of the ears for the pliers so they would move smoothly inside the shock body.'
Scott
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 09-03-2013, 05:20 PM   #3403
Still Bill's Avatar
Too big a track for my old eyes...LOL
Interesting that it would be there.
Bill
Old 09-03-2013, 05:36 PM   #3404
howardcano's Avatar
Trader Rating: 35 (100%+)
It looks like it's time to put in the 2s LiPo!
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 09-03-2013, 07:32 PM   #3405
Still Bill's Avatar
And have a live camera in the car to see the mongo track...
