Old 05-31-2013, 08:05 PM   #3271
HeliYogi's Avatar
Trader Rating: 16 (100%+)
Default Le Mans and F1 Los Angeles SFV Race
More F-1 RC action? RCTECH Formula-1-RC-Northwest & FB @WhatBrakes
HeliYogi is offline   Reply With Quote
Old 06-01-2013, 08:47 PM   #3272
espresso1967's Avatar
Trader Rating: 18 (100%+)
Is WCRC still running World GT? I'm getting ready to get back in and pick up a Gen X 10 kit.
Originally Posted by Spencer Beck View Post
I just picked up a used CRC from eBay for some world Gt racing at my local southern California tracks just because its the class I haven't tried yet. I've done the dirt thing for years now and touring car is just so expensive to jump into again.
Both of the tracks I want to run at are asphalt (WCRC) and carpet (TQ).
What would be a good tire set up for these types of surfaces? I understand that asphalt and carpet tracks might require a different compound.
I have enjoyed cruising this thread for a while now
Thank you for all the info.
www.cityofangelstshirts.com
espresso1967 is offline   Reply With Quote
Old 06-01-2013, 10:23 PM   #3273
HeliYogi's Avatar
For WCRC you will need rubber, depending on your chassis the brand and type.
At TQ foam works the best, however check the class you want to run before before you purchase.
In our Le Mans class(see ad above) you could run a pan car 1/10 chassis such as the CRC with foam tires or any formula 2wd (tamiya F103/f104) chassis on rubber tires.
Hope this helps.
Cheers
Old 06-01-2013, 10:36 PM   #3274
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
World GT is strong at TQ, no one runs pan cars on a regular schedule at WC
Yogi
Rubber in WGT ? ? ? what
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 06-01-2013, 10:37 PM   #3275
Sorry guys TQ? It's been a bit around here.
Old 06-01-2013, 10:41 PM   #3276
www.tqrcracing.com
Old 06-01-2013, 10:49 PM   #3277
HeliYogi's Avatar
Yogi
WGT? I never said rubber at WGT I wrote rubber at our Le Mans class P-2.
Mr.. B had one to many glasses of wine tonight Just kiding
Old 06-01-2013, 10:50 PM   #3278
CRC thread dude
Spam somewhere else
Old 06-01-2013, 10:52 PM   #3279
HeliYogi's Avatar
CRC thread dude
Spam somewhere else
Ups! Cheers "dude"
Old 06-01-2013, 11:23 PM   #3280
Ok thanks for the replies. Again like I said it has been at least 4 years since I last played with the first Gen X 10. I'm looking at the crc site and see there is a new LE version. What are folks running at TQ? Should I stick with the first version or the new LE version?
Old 06-02-2013, 06:01 AM   #3281
avs
avs's Avatar
at TQ we run the WGT spec:
1s, 13.5, blinky (fixed timing esc, no boost, turbo etc),
spec body and tires
only jtg or sxt3 traction compunds allowed.
the early genx wasn't laid out to handle 1s easily. tq's owner (Sean) runs a CRC in wgt, you could compare your car's layout to his. i don't know what else changed beside ease of battery installation.
Tony Shimko
avs is offline   Reply With Quote
Old 06-02-2013, 06:26 AM   #3282
avs
avs's Avatar
Hope this helps.
Cheers
heliyogi, the question was about WGT at WCRC, not F1 or LMP or whatever.
Tony Shimko
Old 06-02-2013, 01:25 PM   #3283
Ok sounds like WGT runs at TQ and sounds like WCRC occasionally. Does any one have the specs of WCRC when you guys do run WGT there? Just trying to have the right specs/equiptment for both tracks.
and a listing of when WGT runs at both tracks.
Thanks everyone
Old 06-02-2013, 03:57 PM   #3284
avs
avs's Avatar
Thanks everyone
i don't know of any wgt class running at WCRC.
i tried 1/12 and wgt cars at WCRC when they first opened, and found carpet tires to work best (black/yellow on 1/12 and greens on the wgt)
i gave up and ran rubber tire TC ( WCRC).
at TQ there is usually a good number of pan cars on Sunday, and certainly for the series races (next sunday june 9 will be a series race)
if you want see what the turn outs are like, Sean posts all the race results on his website, www.tqrcracing.com
Tony Shimko
Old 06-03-2013, 02:42 PM   #3285
Cancun Tom's Avatar
Send a message via Skype™ to Cancun Tom
Default Help needed with 1 cell pan car gearing???
I have a new CRC X10 LE.
I want to run a single cell LiPo in it. I have a HobbyKing EZ Run BL B1 Combo sensor-less motor and ESC in it. I use a Spektrum DX3S transmitter with a Spektrum SR300 receiver. The rear tire diameter is: 2.43 BSR rubber capped. I know how to gear this pan car when using a 2S lipo, but need advice on how to gear it for a 1S lipo? I race it on a outdoor concrete basketball court that is approx. 15 meters wide by 28 meters long at it's extents. The racing line for oval races is approx. 30 meters long. When I power up the car on my workbench the 1 cell is very slow compared to using the 2 cell so I must find out how to gear the 1 cell for a 5 min. oval race. I'm using a 88T, 64pitch spur that came with the kit but I do have others. If anyone can help with either the gear ratio and or the rollout I would very much appreciate it. Also do I need a voltage booster?
Here in Cancun, Mexico we do not have any hobby shops and most of my fellow racers are about 10 years behind in their knowledge. Thanks.......Cancun Tom
Check out all our travel adventures on my Caribbean Webpage http://www.cancunTom.com
Cancun Tom is offline   Reply With Quote
