Old 04-09-2013, 12:51 PM   #3226
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Spencer Beck View Post
I just picked up a used CRC from eBay for some world Gt racing at my local southern California tracks just because its the class I haven't tried yet. I've done the dirt thing for years now and touring car is just so expensive to jump into again.
Both of the tracks I want to run at are asphalt (WCRC) and carpet (TQ).
What would be a good tire set up for these types of surfaces? I understand that asphalt and carpet tracks might require a different compound.
I have enjoyed cruising this thread for a while now
Thank you for all the info.
Mr Bill should have a good setup for you
And, he has run his CRC at TQRC
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 04-09-2013, 02:30 PM   #3227
Originally Posted by Still Bill View Post
Depending on how much you run and/or how much you hit things, you probably should be replacing the Graphite Bottom Plate one or two times each year
ok
And do use the #40194 - Hard Anodized T-Bar (center pivot) Balls and the #13616 - Hard Anodized side link balls (low roll center) for their smooth action (and durability) on all types of tracks.
I have 13616 because original is easily broken and last week i bought 40194 because my original center pivot hasnīt the same shape...
One question... If you will buy a new crc what optional parts you will change?
THANKS and regards
TyoBBS is offline   Reply With Quote
Old 04-09-2013, 02:37 PM   #3228
CRC 1/10 Pan Car
Old 04-09-2013, 04:46 PM   #3229
Default Showing CRC some lovin'
Hey guys just wanted to share this.
Mid last month I bought a new Gen-X10LE to add to my collection of CRC cars, my first WGT. As I was putting it together a ran into a problem, the side links included weren't long enough. I emailed John at CRC and included a picture of the links. I received a quick reply from John telling me that they were shipping out new links right away.
Today I received the links, not just one set but two! I really wasn't expecting this, I would have been happy with just the single set. This is a big deal for me, and it really shows that CRC are committed to keeping their customers happy.
Thanks John and everyone at CRC!!!
AL
www.carcar.ca / www.karz.ca
ALBOP is offline   Reply With Quote
Old 04-09-2013, 08:22 PM   #3230
Still Bill's Avatar
Hi Spencer,
I have run my CRC Gen-X 10 LE's on both carpet (TQ, NorCal Hobbies, Carpet Nats, IIC) using either the CRC/BSR or Jaco Spec Tires (lilacs) without issue.
For asphalt, I have been able to use the same WGT spec tires most of the time. Suggest that you stay with these tires on asphalt; unless, for a low traction situation, you need to go with softer compounds.
The class of WGT is based on everyone using the recognized spec tires. But, some people at various tracks use other compounds out of necessity...like low traction asphalt.
See Dave Berger at TQ for help with getting yourself up to speed using WGT spec tires. Dave is 'da man' at TQ with his WGT...Even if he drives the other car...LOL
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 04-09-2013, 08:26 PM   #3231
Still Bill's Avatar
That is the way John, Dumper and Frank C rolls... Great guys!
Bill
Old 04-09-2013, 08:45 PM   #3232
Still Bill's Avatar
Originally Posted by TyoBBS View Post
ok
THANKS and regards
This is a complete list of what I have on my LE cars
• CRC front foam bumper
• CRC long front arms (less camber change than stock arms)
• CRC Gen-X cross brace (modified to use the long front arms)
• CRC titanium pivot balls (luxury item)
• CRC Pro-Strut alum 10 degree A-arm mounts (luxury item)
• CRC adjustable front brace (stiffen up front end for carpet)
• CRC reverse servo mount (biases weight to front end and clean layout)
• CRC aluminum stand-offs (more durable)
• CRC hard anodized link balls (smoother action)
• CRC Left side rear bulkhead (less flex)
• CRC full box top plate (less flex)
• CRC wide rear body mounts (like the way the Sophia body fits with these)
• CRC 16-ball 88T spur (smoother)
• CRC 41-47T pinion gears (nice pinions)
• CRC 6300 battery pack
• CRC WGT spec front and rear tires
• JR Z3650 Steering Servo (the best available micro servo per Frank C)
• AMB MyLaps Transponder (small and light weight)
• Hobbywing Xerun 120A 1S ESC with built-in DC booster (specific for single cell 3.7V)
• New Trinity D3 13.5 from Eric Anderson (the best)
• Slapmaster Thrust Bearing (on rear axle)
• Lunsford titanium screws (about $75 worth)
• Lunsford titanium motor mount screws (about $10)
• Lunsford titanium steering rods (about $15)
• Protoform Alfa Sophia body (until something better comes out)
And my car does not want for any other parts...LOL
Bill
Old 04-09-2013, 09:33 PM   #3233
out)
Bill
THANKS. I will put a lot of parts
regards
Old 04-09-2013, 09:50 PM   #3234
Still Bill's Avatar
regards
And I forgot to include front and rear springs...
Fronts: usually 50 or 55 (12th) for carpet; or, red or white (10th) for asphalt
Rears: usually red or white for carpet and asphalt
Old 04-18-2013, 10:07 PM   #3235
Hello RC Racer
URC V Raceway
Metro Link Parking Lot
8775 Wilbur Ave. SF Valley CA 91324
http://www.mapquest.com/#f41a628ba7a4ee69f1bc0ef4
ZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ
NEW VIDEO UPLOADED
IN OUR URC CLUB VIDEO LIBRARY
SEE IT!!!!
http://youtu.be/vVRF3_xiQdU
asphalt racetrack for WGT & Pan 10 Pro
Marvin
RC Race Coordinator
URC Valley Raceway
8775 Wilbur ave.
SF Valley CA 91324
AMB/MyLaps transponder
Marvin Alfaro is offline   Reply With Quote
Old 04-19-2013, 02:00 PM   #3236
Another WGT Spec Tire that works great both on carpet and asphalt- GQTires.You can contact Gordon at GQtires@comcast.net. I run mostly on asphalt but we are getting a carpet track sometime soon.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT Racing USA (17.5 foam), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 05-07-2013, 07:42 PM   #3237
Anyone know if Randy Grosse's setup from the ROAR Nats is posted online?
AL
Old 05-09-2013, 04:20 AM   #3238
FL_SilverEvo8's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to FL_SilverEvo8
I picked up the CRC Gen-X 10 LE kit last week (Wednesday). Put it together for me to run WGT class at Nats. Get to Nats on Wednesday to practice with this. We got rained out for practice. I have never driven a WGT car. People told me it is like driving the F-1 cars. But more controllable. Well I had problems with the car spinning out or traction rolling. Friday and Saturday, same problems. Till Saturday a Bullfrog(Bill Fraden) in shining armor came to my rescue.( NO HOMO ) He was in the same class as me (WGT). He went through my car. We found a lot of problems. He help fix them and even gave me some pointers. Get this I was 7th in qualifying and ended up finishing out in 4th(A main). This was my first ever Nats. I even beat Bill the nice guy that helped me fix my car. I guess every dog has his day. So everyone out there if you ever get a chance to run at a big event do it. It is fun and great. Also there are people there that will take the time to help you fix your car and get the bugs worked out of it. Sorry Bullfrog that my bugs hoped from my car to yours in the finals. But thank you for getting me to be more competitive in the finals and also your great help. Oh yeah I think this is going to be my new favorite class next to F-1 and VTA.
Off-Road - Durango:DEX210R(2wd Buggy), DESC210R(2wd SCT), DESC410R(4wd SCT)
On-Road - CRC: Gen-X 10 LE(WGT), X-Ray:T3 2011(VTA), X-Ray:T2 009(USGT) TRF 101(F-1), AE: RC10R5.1(Spec17.5)
Jeff's RC Studio Video>> http://www.youtube.com/watch?v=WtZ8-TV8Fs8&feature=share
FL_SilverEvo8 is offline   Reply With Quote
Old 05-09-2013, 06:29 AM   #3239
mkiiina's Avatar
Trader Rating: 69 (100%+)
Glad to see new people picking up this great car! We just had a 9 car class this last weekend for WGT.
One thing I have learned in running mine these last few months is the importance of good batteries! Don't skimp.
mkiiina is offline   Reply With Quote
Old 05-09-2013, 08:49 AM   #3240
No problem with the help- looking back now it was fun helping you get your car right. As for those bugs in my car that's racing. I'll see you at a race real soon. Have fun.
