Old 03-28-2013, 12:50 PM   #3211
Default setting side springs and tweak
whats the best way to setting up side springs and tweak ?
bigtee is offline   Reply With Quote
Old 03-28-2013, 07:52 PM   #3212
303slowdown's Avatar
Trader Rating: 19 (100%+)
I normally screw the tweek screws down till the spring just touches the pod plate then tweek from there. I use the quarter method for setting tweek but without the quarters ,I'm not a fan of tweek bars cause the bubbles arn't always true. Hope this helps.
Ryan Borgheiinck
303slowdown is online now   Reply With Quote
Old 03-28-2013, 10:39 PM   #3213
Whats the quarter method?
Old 03-28-2013, 11:08 PM   #3214
Trader Rating: 49 (100%+)
I can't explain it in words here well, but I could show you at the track during the week sometime.
SpeedMerchant Rev7
oceanhighz is offline   Reply With Quote
Old 03-28-2013, 11:13 PM   #3215
Ok I will be at mrh on sat. Who is this
Old 03-31-2013, 09:58 PM   #3216
Location: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula
Trader Rating: 29 (100%+)
So I fixed my genx le.
Chassis was broken at the front bumper mount, ca the leftover bits and then jb-welded on a plastic front bumper and left it overnight on a clamp. Chassis looks straight, no tweak whatsoever. good as new and even took a few good impacts the next practice day!
Liked the car so much, I bought another new one off a member here.
lagcisco is online now   Reply With Quote
Old 04-01-2013, 02:16 AM   #3217
Has anyone tried to fit the sliding rear pod from the 12th Xti to the 10th LE?
sparkyboy22 is offline   Reply With Quote
Old 04-01-2013, 05:08 AM   #3218
the genXI pod (slider) is not a direct fit onto a WGT chassis. The spacing of the screw holes in the bottom of the slider side plates are different as compared to the older style side plates with plastic ride height inserts. Also, the dimension from the center pivot's screw to the axle's centerline is significantly shorter on the XTI's slider pod. On the bright side, CRC does offer a complete package of slider pod conversion parts for the WGT cars. It's however quite an expensive upgrade because it includes not only the fancy new side plates, but also new graphite pieces. So the slider conversion kit costs over $80. IMO, the fixed side plates are preferable anyway. But that's just my opinion. It's so quick and easy to swap out the ride height adjusters on the normal pod that spending $80+ just for the convenience of slightly easier ride height adjustment doesn't seem worth the cost. For those who must have the slider's convenience, CRC does offer the conversion. It may not be listed on the site yet, but if you call CRC, they will surely hook you up.
vafactor is online now   Reply With Quote
Old 04-01-2013, 05:50 AM   #3219
I believe the new rear pod moves the motor to improve pod balance also. You can bolt their rear diffuser on the new pod too.
www.norcarracing.com
NORCAR @ The Gate
old_dude is offline   Reply With Quote
Old 04-01-2013, 09:44 AM   #3220
The slider rear end for the LE is part #1768. It has been out for a little while, and is in stock now!
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 04-01-2013, 10:39 AM   #3221
I've purchased two of the new sliding rear pods, one for my gen XI and the other for my LE. Best upgrade I've done to each car, well worth the money
AL
www.carcar.ca / www.karz.ca
ALBOP is offline   Reply With Quote
Old 04-01-2013, 02:28 PM   #3222
I've had mine for awhile-works great!
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT Racing USA (17.5 foam), Formula 1 and Home Track is 386 RaceWay.
BullFrog is offline   Reply With Quote
Old 04-08-2013, 02:04 AM   #3223
After 1 year i need to change: Graphite Bottom Plate (part 1766).
Another driver in my track with the same problem (hole of Red pivot Ball (part 13615). Is normal to have to change in asphalt track with ride height (middle) 6.5 to 5.5mm?
thanks and regards
TyoBBS is offline   Reply With Quote
Old 04-08-2013, 10:44 PM   #3224
Still Bill's Avatar
thanks and regards
Depending on how much you run and/or how much you hit things, you probably should be replacing the Graphite Bottom Plate one or two times each year
And do use the #40194 - Hard Anodized T-Bar (center pivot) Balls and the #13616 - Hard Anodized side link balls (low roll center) for their smooth action (and durability) on all types of tracks.
Or, when using the standard red aluminum side link balls, make sure that the screws go in all the way to the top of the balls...for durability.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 04-09-2013, 01:48 PM   #3225
I just picked up a used CRC from eBay for some world Gt racing at my local southern California tracks just because its the class I haven't tried yet. I've done the dirt thing for years now and touring car is just so expensive to jump into again.
Both of the tracks I want to run at are asphalt (WCRC) and carpet (TQ).
What would be a good tire set up for these types of surfaces? I understand that asphalt and carpet tracks might require a different compound.
I have enjoyed cruising this thread for a while now
Thank you for all the info.
Spencer Beck is offline   Reply With Quote
SEO by vBSEO 3.5.0
