Old 03-24-2013, 07:19 AM   #3196
Still Bill's Avatar
Originally Posted by scootr117 View Post
I ended up using Shoe Goo to glue the foam bumper to the CF. otherwise it only has the body posts keeping it in place. with the the glue it deforms rather than deflects on impact.
Good point! To maintain the position of my front foam bumper on the carbon fiber bumper, I have one 3/4" long 4-40 screw with washer and locknut positioned in the front center hole. Just that one addition made a world of difference to the integrity of the assembly in a hard impact.
Used to have three of these 3/4 screws in place when I ran a heavier 2S pack WGT; but, only the center screw was retained for 1S racing.
Shoe Gooing sounds like a good solution too; but, I wanted to be able to disassemble the parts.
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 03-24-2013, 08:25 PM   #3197
Location: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula, California, Unites States of America
Trader Rating: 30 (100%+)
I do have the foam bumper pad and it does overhand the cf plate a bit.
I just checked tweak in the chassis an it looks fine. I think I will epoxy the bumper plate to the chassis so I can save $50.
The car also came with manutech plastic bumper plate so I will try that too, epoxy that one on instead of stock cf one.
And yeah, it was the end of the straight at TQ.
lagcisco is offline   Reply With Quote
Old 03-24-2013, 08:53 PM   #3198
Still Bill's Avatar
Just checked my two LE cars again tonight. One has the single 3/4" screw in the front bumper and the other has all three of them. No breakage either way; so, maintaining the overhang at the front center seems to cover the issue.
And both of these WGT cars used to run a lot faster when we were using boosted/turbo modes on our ESCs in the pro class at the IIC.
Bill
Old 03-25-2013, 04:52 AM   #3199
Default info on gen 10 le
Hi guys ,looking at buying a gen 10 le, only i need your help on info on what parts i need to get going once i buy the new kit. Should i need springs, shock oil, bearings etc. You guys know what i need , thing is crc cars are not thick on the ground here in brisbane australia.Looking at maybe running it as a pro 10.I have learnt a lot from rc tech forums over the past few months.
Cheers mick
mick71 is offline   Reply With Quote
Old 03-25-2013, 05:23 PM   #3200
Jsaves's Avatar
Congrats to Randy Grosse of Sawyer, North Dakota.
The National ROAR WGT Champ!!!!
Proud member of Magic City RC Racers
Magic City R/C (Facebook)
CRC GT-R
CRC WTF-1
Jsaves is offline   Reply With Quote
Old 03-25-2013, 06:03 PM   #3201
scootr117's Avatar
Originally Posted by mick71 View Post
Hi guys ,looking at buying a gen 10 le, only i need your help on info on what parts i need to get going once i buy the new kit. Should i need springs, shock oil, bearings etc. You guys know what i need , thing is crc cars are not thick on the ground here in brisbane australia.Looking at maybe running it as a pro 10.I have learnt a lot from rc tech forums over the past few mouths.
Cheers mick
Extra bearings are always a good idea. A spring set would be helpful to tune it in for your track too. The only things I'd get as an option to start with are the Aluminum stand offs for the tweek plates and aluminum replacement for the plastic axle carrier on the left side.
Oils and damper lube should be common to what others are running in the class...the kit comes with 30wt oil and 20k lube (I think??)
Scooter EXperimental
RK Designs
CD SuperPro Motors
Mike Pulfer is my HERO....
scootr117 is offline   Reply With Quote
Old 03-25-2013, 08:29 PM   #3202
Thanks scootr117 for the info. I am using a old 235 pan car atm, running a 13.5 brushless set up. Very fast for me as i am use to a old brushed set up. Keen to get a new car , haven't driven a pan car for years.
Old 03-25-2013, 09:53 PM   #3203
Still Bill's Avatar
Plus...
PERFORMANCE AND DURABILITY PARTS
Front foam bumper #1759 (a must have)
Front ride height shims #4262
Rear ride height spacer set (all sizes) #3381
Option wide body mount #1771 (if not included in current LE kit)
Full box rear top plate #1763 (goes with the below)
Gen-X left bulkhead - red #3342 (goes with the above)
SPARE PARTS
Front steering blocks (both types to see which you like best) #3251 and #3221
1-piece clamping side links (65mm) #3281 (incorrectly described on CRC website)
Rear bottom plate Gen-X 10/12 #1766
Large D-ring Axle 10th/SS #1728
Rear bottom plate #1766
Large D Diff Rings #4201 (don't use the lightweight version)
And the list goes on...
Bill
Old 03-25-2013, 10:42 PM   #3204
YoDog's Avatar
Trader Rating: 26 (100%+)
Hey Bill,
What is the normal front track width that most setups use?
190mm Front?
200mm Rear?
I keep trying to look something up but pretty much all say "wide", "Middle" and "narrow". Looking at my LE chassis, it doesn't look like there are 3 choices.
Gonna run the Mile high race and I want to get my set up somewhat close.
YoDog is offline   Reply With Quote
Old 03-25-2013, 11:29 PM   #3205
Still Bill's Avatar
Originally Posted by YoDog View Post
Hey Bill,
190mm Front?
200mm Rear?
Besides the widths of the chassis setting, the spec tires come in different offsets making overall width change a bit (CRC/BSR is the wider track tire while Jacos are narrower). Both are still good depending on the situation. Cannot give you one specific width for either end because I considered them to be tuning options. CRC rears always ended up being in the range of 198-200mm; but, you could vary the front end width quite a bit using shims.
The narrow, middle and wide front chassis widths came standard with the original Gen X-10 Pro kit. There were two separate plates (mounted L/R) could be fastened to each side of the chassis plate in all three available width positions. These two plates could get tweaked in hard hits and were replaced by one-piece plates of two different widths.
You can rule out narrow right off. Never needed it for any carpet or asphalt setup.
With the reversed servo front ends (that I use), only the middle and wide settings are available width options. I would often run the middle width when looking for more steering; and, use the wide width for less steering on both carpet and asphalt. Fairly simple rule in my mind.
Cheers!
Bill
Old 03-26-2013, 06:29 PM   #3206
YoDog's Avatar
Something I've been working on for the GenX10.
It's a 1 piece Long arm, dual mount brace with a seperate adjustable servo plate for the forward laydown servo configuration. It has a landing for mounting the transponder as well. You can just remove the 4 main suspension screws and the whole front assembly comes off in one piece.
I had to compress the pics quite a bit to post so it's a little tough to see the details well.
CRC 1/10 Pan Car-20130326_175057comp.jpg   CRC 1/10 Pan Car-20130326_173841comp.jpg   CRC 1/10 Pan Car-20130326_174919comp.jpg   CRC 1/10 Pan Car-20130326_174902comp.jpg
Old 03-26-2013, 07:16 PM   #3207
NutDriver's Avatar
Trader Rating: 14 (100%+)
If you're going to make these to sell, put me down for two!
Scott
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 03-26-2013, 07:21 PM   #3208
YoDog's Avatar
Maybe a rendering is easier to see...
CRC 1/10 Pan Car-genx10-front-end.jpg
Old 03-26-2013, 07:27 PM   #3209
YoDog's Avatar
Scott
That's a possibility if there is enough intrest.
This one is the prototype and I will be putting it through it's paces at the Mile High race in Denver next month.
I will likely need to design up a medium and wide version. That's easy...
Old 03-26-2013, 07:39 PM   #3210
Still Bill's Avatar
Very kewl!
Thanks for sharing.
Bill
