Old 02-02-2013, 08:16 PM   #3151
Still Bill's Avatar
Originally Posted by bigtee View Post
what should the turn radius be set at on crc wgt
Not trying to be a smart aleck...But, I suggest that you use whatever suits your track conditions and driving style. Try adjusting to what you find is best for you. IMO the testing process can be just as rewarding as the racing experience.
And, it is critical to get the left/right steering equal from side-to-side. Factors include: Lower front A-arms at exact same height when mounted to chassis plate; output shaft from servo centered in chassis; steering links equal length; same geometry side-to-side; etc.
Bill...sometimes a better tester than racer...LOL
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 02-03-2013, 06:30 AM   #3152
scootr117's Avatar
I set mine to the turn around in a little less than half the width of the narrowest lane on the track I'm at.
Scooter EXperimental
RK Designs
CD SuperPro Motors
Mike Pulfer is my HERO....
scootr117 is offline   Reply With Quote
Old 02-03-2013, 06:23 PM   #3153
Bigz84's Avatar
Trader Rating: 17 (100%+)
Default floating servo
question. i having trouble centering the servo. the manual states the servo saver should be centered with the center of the front end. I can't get mine to do so. for the time being, i am using a Futaba bls551. do i need to modify the floating plate? also, the manual states to use the lower holes outside holes of the saver, but i see people using the higher outside holes. Which is it?
need some help, thanks....
Airtronics/Sawna : EA Motorsports : Orca : Reflex Racing/RSD : Wild Turbo Fans : Franchise Racing Products : RCAmerica : Hudy : Xray : Diggity Designs: Motiv : Team Scream Racing
Bigz84 is offline   Reply With Quote
Old 02-03-2013, 08:17 PM   #3154
Still Bill's Avatar
That BLS551 Low Profile Servo is actually a good touring car unit; but, is a tad big for a WGT car. Someone may have made the mods to get one centered on their WGT; but, I have never seen anyone accomplish such successfully. You really need a "mini" servo like a JR3650, KO PDS-951, or Futaba S9650 to do it right.
With the Kimbrough Mid-Sized Servo Saver #201 and depending on your geometry, you can have steering link clearance issues by using the lower holes. Therefore, I use their other available Servo Saver #200 (comes without holes) and drill new holes in between where the inner and outer holes are located on the #201 unit. Takes some patience to get the holes exactly right; but, I do like the geometry of the steering links and the elimination of any clearance issues with the steeting links. IMO using those outside holes on a #201 poses other geometry/mechanical issues that I prefer to avoid...Been there, done that...
FYI...I run my JR3650 servos flat and reversed on both cars.
Bill
Old 02-03-2013, 08:50 PM   #3155
bkspeedo's Avatar
Congratulation to Brian Wynn for the TQ and win and Max for 3rd in 13.5 WGT at Snowbirds Nationals.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 02-03-2013, 10:07 PM   #3156
Still Bill's Avatar
Whooooo Hoooooo Dumper
Old 02-05-2013, 11:43 AM   #3157
scootr117's Avatar
I saw scales on my last trip to the Gate. What is the goal when using them for setting up a WGT?
RK Designs
CD SuperPro Motors
Old 02-05-2013, 11:59 AM   #3158
bkspeedo's Avatar
There used for setting tweak.
Brent Klingforth
Old 02-05-2013, 12:52 PM   #3159
scootr117's Avatar
I thought it may have something to do with weight balance front to rear. I've always used a tweek station (MIP) to set the side springs.
I could see it being used for that too
RK Designs
CD SuperPro Motors
Old 02-05-2013, 12:54 PM   #3160
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Like BKSPEEDO said tweek.
I also use them to balance the chassis prior to setting the tweek.
I have a 3/4" bar that the rear tires sit on then the front tires go on the scales.
With the dampening tubes off and side springs backed off I check the front weight. I move the electronics around till it's within a gram.
Then I bring 1 spring down till 1 scale changes a few grams then then the other spring down to balance it.
Easy as cake
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 02-09-2013, 08:23 AM   #3161
Jsaves's Avatar
Default slider pod
I saw on Brian's winning LE he had the rear slider pod, so look to the CRC website and they are selling it for the LE and others. No more plastic adjusters!
1768-Slider Pod Conversion for the-Gen-X,XL,Xi + Gen X10
I do like CRC so much.
SG1 what did you use for the alum. stand off to raise the graphite piece high enough to get the springs over the links?
Thanks and God Bless
Proud member of Magic City RC Racers
Magic City R/C (Facebook)
CRC GT-R
CRC WTF-1
Jsaves is offline   Reply With Quote
Old 02-10-2013, 03:19 AM   #3162
sg1
sg1's Avatar
I used CRC 5/8 standoffs with 1 #4 washer added to get the height to .65"
Some guys are seeing spring lengths a bit longer and went to 7/8" standoffs.
Old 02-10-2013, 05:28 AM   #3163
scootr117's Avatar
On my conversion.. I cut up two of the carbon fiber tweak spring plates and used them. It worked really well.
RK Designs
CD SuperPro Motors
Old 02-25-2013, 01:36 PM   #3164
Default crc wgt
what a good servo position angled or flat?
bigtee is offline   Reply With Quote
Old 02-25-2013, 06:43 PM   #3165
Still Bill's Avatar
Pass the popcorn...This should be good...
Response #1. I run mine flat/reversed on both carpet and asphalt. Had run angled for a long time prior to running flat; and, don't feel any significant difference in the steering. But, do like how flat/reversed cleans up the chassis layout. To a point, I can always move the 1S battery pack back in the chassis to bias weight rearward.
Bill
