Old 12-01-2012, 01:25 PM   #3046
The car is done- Thanks Now I'm waiting for a new motor and battery. I'll post a picture later tonight of my conversion.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT Racing USA (17.5 foam), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 12-01-2012, 04:13 PM   #3047
CRC 1/10 Pan Car-001.jpg
Old 12-01-2012, 05:36 PM   #3048
Still Bill's Avatar
Originally Posted by BullFrog View Post
Seems like I am looking at the RF kingpin just above the lower arm. Shouldn't be able to see it. How far are your kingpins extending below the steering block?
That foam bumper would be most effective by hanging out over the front of the carbon fiber bumper plate by no less than 1/8". That will allow it to absorb the force of an initial hit in a shunt. With it placed behind the leading edge of the CF bumper, you might as well not use anything. And those CF bumper plates cost bucks...LOL
Cheers!
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 12-01-2012, 05:41 PM   #3049
thanks - got plenty of time to move it foward.
Old 12-01-2012, 06:02 PM   #3050
Still Bill's Avatar
Default Pics
Pics of my carpet version LE. All setup for IIC; but, didn't make it this year.
CRC 1/10 Pan Car-gen-x-10-le-001.jpg   CRC 1/10 Pan Car-gen-x-10-le-003.jpg
Old 12-01-2012, 06:18 PM   #3051
I guess I'll mount the servo back the way I had it. got talked into it.
Old 12-01-2012, 06:25 PM   #3052
Still Bill's Avatar
Do you mean flipped over to the right side...but still forward?
Old 12-01-2012, 07:01 PM   #3053
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Watch the gap between the stearing blocks and lower a-arm pivot.
With all the weight in the car you only want .01" gap.
If your track is low bite you can get away with a bit more gap, but it's a very sensitive adjustment with this set up. Also check to make sure the chassis is sitting level from right to left.
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 12-01-2012, 07:04 PM   #3054
sg1
sg1's Avatar
Looks good! How many grams of weight are on the front tires?
Old 12-02-2012, 08:00 AM   #3055
Nope- I'm going back to the way I orginally had it- just like what SG1 had.There are no local track to test on close. the closest is 3 1/2 hours away. Next race is Minregg on the birds track layout before the birds race.
Old 12-02-2012, 08:28 AM   #3056
Still Bill's Avatar
Wow! 3-1/2 hours away...You are dedicated!
So, you are running on carpet...With those white springs all around, I was thinking you were on low traction asphalt (outdoors). On good carpet, my typical initial springs are #50-55 1/12th springs in front, reds in rear and red center spring.
FYI...My closest carpet track is 6 hours...<cry>
Bill
Old 12-02-2012, 09:56 AM   #3057
sg1
sg1's Avatar
For those who asked about track size, layout, and grip I ran at, here's a link to the main run:
http://www.youtube.com/watch?v=WlAGbtfWSjk
Forward to approx. 31 minutes in, that's the start of the main.
I'm the pretty all yellow Parma body
Old 12-02-2012, 11:32 AM   #3058
Convert back to SG1 picture. No I've been running carpet last race and the next two races.I assummed that this was a carpet set-up. I ran the last race with Big Baby blacks .24 up front , 3500 on the tubes and in the center shock(45) and sides and 17# center spring. The only difference on a low traction(asphalt) track was the red springs center shock and sides.20,00 in the tubes
Old 12-02-2012, 03:26 PM   #3059
NutDriver's Avatar
Trader Rating: 14 (100%+)
Default w
Gentlemen,
Thanks for the awesome info on the CRC pan cars. I recently bought a CRC WGT car from this site. I thought I knew which one it was, but now I'm not sure. I haven't posted enough to insert a pic (according to the site). A pic of the car is an album on my page.
Any suggestions on hopups?
Thanks,
Scott
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 12-02-2012, 05:36 PM   #3060
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
Originally Posted by NutDriver View Post
Gentlemen,
Thanks,
Scott
If the battery mounts from the bottom it is a GenX10. If it mounts from the top it is an LE.
