Old 11-13-2012, 10:52 PM   #3001
Is it possible to run these types of bodies on the 10LE? Will it be impossible to drive? To be for track use but not racing. Only just for fun driving. Thanks.
1969 camero z28 (200mm)
1970 cuda (200mm)
one-nil is offline   Reply With Quote
Old 11-14-2012, 06:30 AM   #3002
For just having some fun, they will work fine.
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 11-14-2012, 06:39 AM   #3003
dumper: Fab! Thanks.
Old 11-14-2012, 06:58 AM   #3004
mkiiina's Avatar
Trader Rating: 69 (100%+)
1970 cuda (200mm)
I happen to race VTA and WGT and yes the Cuda fits just fine. I don't happen to have a camero on hand but it should fit as well but its a little more narrow in the back.
mkiiina is offline   Reply With Quote
Old 11-14-2012, 04:02 PM   #3005
Hi i have had a look but cant find a 2s tekin setup. I was wondering if anyone can share a tekin rs pro setup for an le on large asphalt track (moorebank)running 10.5 with 2s. i have played around with the settings but would appreciate some speedy setups to start .rollout at 76mm
thanks
ace955 is offline   Reply With Quote
Old 11-14-2012, 04:45 PM   #3006
BCbud's Avatar
Trader Rating: 37 (100%+)
thanks
You may find something in this thread as pro 10 ran 2 cell.
Pro 10: 235mm Le Mans Prototype Pan Car Discussion
Xray NT1 - Xray T4 2013 TC - Xray T4 2013 VTA - CRCgenX10 - CRCgenX - CRCgenXi - Slash 4X4 with LCG conversion -Associated RC8Be - Xray XB4 - DX3R PRO
Recycled teenager.
www.irocc.ca ; www.corvictoria.com ; http://www.wcics.ca/
I will not send Pay Pal as a gift or add fees to the price so DO NOT ASK!
BCbud is offline   Reply With Quote
Old 11-14-2012, 05:48 PM   #3007
BCbud's Avatar
Originally Posted by YoDog View Post
Hello Guys,
The prototype has been cut and fitted!
These will include a CF forward stop with hardware but I have yet to cut that part.
I am hoping to have the first batch done by Friday so if you are wanting a CF battery tray for your GenX 10 Legacy chassis, Please send $20.00 each + $4.00 flat rate for shipping in the Continental U.S.
I can only take PayPal at this time so I will have to eat the fees myself. Oh well...
Please PM me for my PP address.
Here is a pic of the prototype.
I'll have more pictures of the tray installed in the chassis tomorrow.
Payment sent for 2.
Thanks Neil.
Recycled teenager.
Old 11-14-2012, 06:36 PM   #3008
YoDog's Avatar
Trader Rating: 26 (100%+)
Originally Posted by BCbud View Post
Payment sent for 2.
Thanks Neil.
Thanks Neil,
I'll get those out to you on Friday.
Here's a few more pics. Kinda hard to see but they will do in a pinch.
CRC 1/10 Pan Car-imag0025-2-comp.jpg   CRC 1/10 Pan Car-imag0030-2-comp.jpg   CRC 1/10 Pan Car-imag0031-2-comp.jpg
YoDog is offline   Reply With Quote
Old 11-17-2012, 08:36 AM   #3009
scr8pn4205's Avatar
What are the benefits for the reversed servo vs the standard angled servo.
Airtronics M12
Team Xray XB2 2017 CE
TSR power
scr8pn4205 is offline   Reply With Quote
Old 11-19-2012, 01:21 PM   #3010
briankstan's Avatar
taken directly from the CRC site here
"These new reverse servo mount plates allow for more room to move the battery back and forth in the CRC Gen-X 10 and 10LE. The servo is now flipped to the front and mounted flat, lowering the CG and lightening the car. Also, more space is now open to put all the components inline and/or move the battery further forward."
www.slmini-zstore.com
www.saltlakemini-z.com/forum
www.howfastareyou.com
briankstan is offline   Reply With Quote
Old 11-28-2012, 07:11 AM   #3011
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Default Gen X10-LE set up info
Hey Guys,
I thought I'd post some set up info from my CRC WGT I ran at the US Indoor Champs over the weekend.
I TQ'ed and won the main with this set up:
2.01" tires front and rear
Long front arms
White front and side springs
side springs moved out to over side links
side tubes raised and 7K lube
30wt center shock with purple spring
4.5mm clearance all around
1.5mm droop in rear shock
.25mm droop front
1.25* camber
10* front blocks
inline axles
If you have any questions feel free to ask.
Here's a pic:
CRC 1/10 Pan Car-dscn9395.jpg
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 11-28-2012, 07:13 AM   #3012
mkiiina's Avatar
Congrats on the win, and with a DB9 body as well!
Old 11-28-2012, 07:34 AM   #3013
sg1
sg1's Avatar
Thanks! I don't think there were anyother DB9's in the main
Old 11-28-2012, 08:10 AM   #3014
Default crc wgt
would like to here more on your setup? i am jumping from 1/12 scale to 1/10 thinking i like it more. when say white front springs what are you meaning and how high did you raise your damper tubes and did you raise both ends? whats the purpose of putting the side springs over the side links?
bigtee is offline   Reply With Quote
Old 11-28-2012, 08:23 AM   #3015
sg1
sg1's Avatar
I used the 1/10 long kingpins on the front and ran the white side springs.
Some guys use the 1/12 kingpins and run .50 fronts.
I liked the feel of the bigger/longer spring.
The dampener tubes were raised 1/2" on the graphite side plates.
Then I mounted them on the top of the upper pod graphite plate.
The rear graphite side plates had to be raised to .65" in order to give enough room to move the side springs over the links. (you can use 5/8 standoffs and a washer).
To sum it up...
When I did this, the car would have alot of chassis roll, but wouldn't diff out or become upset in the turns on a high bite track. I can drive it like a 1/12
