Like Tree2Likes
Old 09-25-2012, 09:46 AM   #2941
Originally Posted by dumper View Post
Send an email to [email protected]. He will get you what you need.
Thanks. Waiting answer...
regards,
TyoBBS is offline   Reply With Quote
Old 09-25-2012, 10:19 AM   #2942
AdrianM's Avatar
It would be cool to see a Gen Xti 10. The inline chassis design would actually work better on a WGT than on the 1/12th car.
Adrian Martinez
Old 09-25-2012, 08:58 PM   #2943
Still Bill's Avatar
Dumper and John to the rescue...!!!!
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 09-25-2012, 10:48 PM   #2944
al dente's Avatar
Um.......... The 10th scale car has always been inline. Since day one.
Team CRC / Dumper's Speed Shop / Team Scream Racing / Black Art
RC America / FB/FX / Colorado On Road RC Club
5280 Raceway (5280raceway.com) home of the MILE HIGH INDOOR CHAMPS April 19-22, 2018
al dente is offline   Reply With Quote
Old 09-25-2012, 11:05 PM   #2945
AdrianM's Avatar
I meant in relation to the chassis design on the new 1/12th car. The Gen X10 chassis is funky looking. I would be more sleek if it were like the Xti.
Adrian Martinez
Old 09-26-2012, 09:59 AM   #2946
ChestyV32's Avatar
Trader Rating: 32 (100%+)
Couple of questions,
When the battery is in the forward inline position how do you keep it from moving side to side? Or do you even worry about that?
In 1/12 I always ran the servo flat on carpet, Should I run it flat in WGT as well?
Thanks,
Cheston
SXT Tire Additive
www.SuperiorHobbies.com
ChestyV32 is offline   Reply With Quote
Old 09-26-2012, 11:15 AM   #2947
Default 3277 - Gen-X Graphite Cross Brace for Pro-Strut FE ???
How does this brace affect the front end on a WGT, if you stay with short arms???
Does it raise inner pivot up?
alien too is offline   Reply With Quote
Old 09-26-2012, 12:01 PM   #2948
bkspeedo's Avatar
Thanks,
Cheston
the standoffs for the top X brace keep the battery from moving side-to-side.
Either way, tilted using the servo mounts or running flat seem to work. If running angled mount it like in the manual or your ackermann will not be correct. when mounting flat keep the steering links slightly angle forward.
I personally like the flat position.
This brace is for the 12th scale. To use on the WGT you need to cut the center. Since it raises the inner attach point of the arm higher, making the upper arm flatter, it will lower the role center on the car. making the front end roll a little more in the corner. It will also reduce camber gain slightly.
On WGT this brace is mostly used when long arm is needed.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ Montech ~ WTF ~ BSR Racing Tires ~ 2mm Design ~ Helix Designs
5280 Raceway
MILE HIGH INDOOR CHAMPS April 19-22nd 2018 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 09-26-2012, 04:21 PM   #2949
Is the a diagram of the long arm set-up anywhere? I like to see what it looks like before I start cutting things.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT-12 Racing USA (21.5 ), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 09-26-2012, 08:51 PM   #2950
Still Bill's Avatar
Thanks,
Cheston
Cheston,
To hold the battery in place, I installed two more of the CRC Part #3373 Molded battery position pieces (2) - Gen-XL on my chassis. One on each side of the pack. Only had to drill two holes and countersunk them for the flathead screws that fasten them in place.
Get the CRC Part #17403 Reversed servo mnt front plate - Wide width and Part #3315 Molded Servo Mounts-flat to run your servo flat and reversed on your LE.
Bill
Old 09-27-2012, 07:45 AM   #2951
http://www.teamcrc.com/crc/images/st...Dumper-car.jpg
Here is a picture of my car with it on.
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 09-27-2012, 09:55 AM   #2952
YoDog's Avatar
Trader Rating: 26 (100%+)
Hey guys, have a look at this for fun.
Trying to stir up some interest.
Will there ever be a 1/8th scale Electric onroad car
I love my genX10 and got me thinking about going bigger.
Hey Dumper, think CRC might be interested in going into something like this?
YoDog is offline   Reply With Quote
Old 09-28-2012, 11:43 PM   #2953
al dente's Avatar
WOW DUMPER. THAT IS A GREAT PICT!!!!!!!!
who does your paint. that thing looks boss!
Old 09-29-2012, 10:10 AM   #2954
Still Bill's Avatar
Yes, it does raise the inner pivot up giving you less camber change as the front suspension works. A very good tuning mod for high traction conditions.
Old 10-26-2012, 02:56 PM   #2955
Default WGT Front End Adjustment
How does the long wheel vs short wheel base (2 Hole Adjustment on Front Plate) affect Gen X10 LE WGT's handling?
