Old 09-04-2012, 06:34 AM   #2926
long time post but I have finally got round to doing an update on my blog:
http://rcgtpancars.blogspot.co.uk/
http://rcgtpancars.blogspot.com/
chris_blakey is offline   Reply With Quote
Old 09-12-2012, 06:25 AM   #2927
http://www.teamcrc.com/crc/modules.p...rticle&sid=167
anyone at CRC tested the rear pop parts on their WGT cars??
Old 09-12-2012, 04:02 PM   #2928
Any idea if they are coming out with the slider pod for the 1/10th cars?
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT Racing USA (17.5 foam), Formula 1 and Home Track is 386 RaceWay.
BullFrog is offline   Reply With Quote
Old 09-13-2012, 05:35 AM   #2929
nitrobeast's Avatar
Trader Rating: 40 (100%+)
Ill take a guess and say yes. They just realease the 12th scale so give them some time. They usually release new parts around this time.
Rui Goncalves
Reds Racing USA|Hot Race Tyres USA|Team CRC|Team Trinity|
Jackson RC|Horsham RC|Floyd Bennett|Blue Diamond
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 09-19-2012, 05:43 AM   #2930
scootinround's Avatar
Default Crc Gen-X 10LE
Hey Guys i have looked everywhere and can't find anything....I am wondering what pinion gears I should buy and if I should run the stock spur gear--I am going to be running a Viper 1cell and Viper 13.5t motor in the WGT class...thanks in advance
Matt Scott
Special thanks to: VIPER RC SOLUTIONS---PRO-LINE RACING---
RЯE Models at RREmodels.com for all your heli and RC car and truck needs---UPGRADERC.COM
Florida Indoor R/C Complex--Indoor Carpet Onroad and Fri Night Carpet offroad Racing--
scootinround is offline   Reply With Quote
Old 09-19-2012, 07:28 AM   #2931
Mid to high 40's on the the pinion. 88 tooth spur. 2.08 CRC WGT tire to start.
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 09-24-2012, 11:20 PM   #2932
Last race removed center shock. I checked and is very easy to dismount/mount. I want to change Female Hex ballstud (1407) and this part of center schock:
But i don't find it in spare parts list (or a complete center shock).
Thanks and regards,
TyoBBS is offline   Reply With Quote
Old 09-24-2012, 11:41 PM   #2933
Still Bill's Avatar
Thanks and regards,
#3293 - Encore Plastic Parts
http://www.teamcrc.com/crc/modules.p...prodID=7719086
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 09-25-2012, 01:58 AM   #2934
303slowdown's Avatar
Trader Rating: 19 (100%+)
If your running no timing.
Your going to want to run a different motor, I have tried a couple of the viper motors and they are waayyyy off pace. They work ok in off road but not onroad. With a proper motor(thunder power, epic, reedy) you will want to run an 80-85mm rollout so if the stock spur is an 88 then you'll want pinions between 40-45 (depending on tire size). I have nothing against viper or their products just letting you know my experiance.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 09-25-2012, 02:01 AM   #2935
Originally Posted by Still Bill View Post
The pic he's showing is not the encore shock its the losi shock so the ball studs won't work (shaft size is different) the shock is from the losi jrxs type r.
Ryan Borgheiinck
Old 09-25-2012, 02:27 AM   #2936
Perfect, thanks
regards
Old 09-25-2012, 02:34 AM   #2937
The pic is the Assembly Manual Gen-X 10 (Original shock center)
regards
Old 09-25-2012, 02:39 AM   #2938
Origional gen-x 10center shock was from the losi touring car. The LE comes with the encore shock(1/12 size shock)
Ryan Borgheiinck
Old 09-25-2012, 02:54 AM   #2939
Is possible to buy this spare part?
Thanks regards,
Old 09-25-2012, 07:38 AM   #2940
Thanks regards,
Send an email to john@teamcrc.com. He will get you what you need.
SEO by vBSEO 3.5.0
