Old 07-12-2012, 05:52 AM   #2911
The someone else that e-mailed you was also me.The Maxi-mod tire truers have not been made many years. They all have the same design.I've had mine since 1992 and it works great. Mine was a special one built to do many tires (the 1/8th motor edition) for 1/10th and 1/12th tires. I do have many different adaptor for my unit- I just liked the design of yours.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT Racing USA (17.5 foam), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 08-13-2012, 05:51 PM   #2912
ground-round's Avatar
Trader Rating: 14 (100%+)
Hey CRC guys. I have a parts lot up for grabs, really cheap. Check it out.
CRC WGT Parts Lot - cheap
ground-round is offline   Reply With Quote
Old 08-14-2012, 09:15 PM   #2913
Suspended
Trader Rating: 4 (75%+)
did anyone try the xceed wgt tires?
which degree is good for medium traction asphalt?
tryandfok is offline   Reply With Quote
Old 08-15-2012, 12:24 AM   #2914
M7H
M7H's Avatar
Soft Rear, and Medium front.
If you have inline steering, hard fronts will also do.
Serpent
M7H is offline   Reply With Quote
Old 08-27-2012, 12:00 PM   #2915
mkiiina's Avatar
Trader Rating: 69 (100%+)
Hi guys, I recently picked up a X-10 and wanted to see how you were mounting the battery?
We are running 13.5 and 1s lipo, it looks like the stock tray is a bit too narrow but after a little work with my soldering iron I was able to widen it up some and make it work. I also removed the nuts to lower the top deck some and now the battery fits snugly top to bottom, just need to address the front to back!
mkiiina is offline   Reply With Quote
Old 08-27-2012, 12:14 PM   #2916
CypressMidWest's Avatar
Most run the battery as far forward as possible.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 08-27-2012, 02:32 PM   #2917
joeymdz's Avatar
Send a message via MSN to joeymdz
^^^ also most have upgraded the chassis to the LE
RC Plus*McKune Designs*NW Hobbies*Premier RC Raceways*Daves Tracks
joeymdz is offline   Reply With Quote
Old 08-27-2012, 04:58 PM   #2918
Andy w's Avatar
We are going to try 2s for 10th pan this winter but I can't figure the best way to mount in the chassis. The batteries are too thick compared to 1s and wont fit under the top deck. Are people shimming up the top deck or are other hex stands needed? If anyone has a pic that would be great.
Andy w is offline   Reply With Quote
Old 08-27-2012, 06:55 PM   #2919
True, but the original X10 pro is still a potent ride, especially in lower grip situations.
Old 08-27-2012, 06:57 PM   #2920
Still Bill's Avatar
Are you talking about the new shorty 2s packs or the full-size 2s packs (in an LE)?
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 08-27-2012, 07:01 PM   #2921
joeymdz's Avatar
shim the stand offs or find the part from mcmaster
for 1s i found it easier to have the LE chassis compared to the x10 (less weight and battery adjustments in the LE)
Old 08-27-2012, 07:13 PM   #2922
Andy w's Avatar
Full size packs and LE. And if shimmering up the top deck is the answer then should I shim the shock on the rear pod also?
Old 08-27-2012, 07:25 PM   #2923
Still Bill's Avatar
When I ran 2S in the original Gen X-10 kit, the instructions did not call for shimming the shock on the rear pod. I would call it a minor tuning aid; so, do it after trying unshimmed.
And shimming the side links front or rear is another option to consider.
You are definitely in for a ride with a 2S pack...LOL
Bill
Old 09-03-2012, 05:02 PM   #2924
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Originally Posted by CypressMidWest View Post
Loosening of all the screws in each bulkhead after every big shunt will make this piece (1766) last a lot longer. I've actually been loosening all the bulkhead screws and re-tightening after every run lately. Really helps prevent tweaking of the 1766.......
Kewl idea. Have not tried it; but will...When I go 400 miles to the nearest carpet track...<sniff>
See ya at the IIC.
Bill
I have also had a few get tweaked. That's a good tip!
Rui Goncalves
Reds Racing USA|Hot Race Tyres USA|Team CRC|Team Trinity|
Jackson RC|Horsham RC|Floyd Bennett|Blue Diamond
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 09-03-2012, 06:51 PM   #2925
wingracer's Avatar
Trader Rating: 22 (100%+)
Very true. I wanted to upgrade mine but the damn thing is near perfect as is. Stock original X10 except for longer links and an encore shock. TQ'ed and won at MRH with it last weekend.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
